#267 |
Hotlink Terrorist
Drives: 2015 WRB BRZ Spec S
This says a lot. Opinion can't stand up to science; I've heard that before.
![]() How much of my money will you be needing for this "miracle?"
#268 | |
Drives: Asphalt Scion FR-S
#269 |
Hotlink Terrorist
| The Following User Says Thank You to themadscientist For This Useful Post: | raven1231 (05-26-2015) |
#270 |
Drives: GT86
| The Following User Says Thank You to GT86_PRAGUE For This Useful Post: | themadscientist (05-25-2015) |
#271 |
Drives: 2013 ultramarine Scion FR-S
But what is the benefit/cost ratio? Is it more than the battery?
#272 | |
Pros: Dropping weight off front passenger corner to shift center of gravity rearward to the driver side of the car Mass is high relative to the car's center of gravity, so removing would lower it slightly Cons: Lower capacity battery May require a special charger to balance charge Driveshaft Pros: Dropping weight in rotational mass Carbon driveshaft helps reduce shock to drivetrain Cons: Dropping weight from the lowest most central part of the car, so should in theory slightly raise the car's center of gravity Aluminum driveshaft transmits shock and vibration through the drivetrain. Would dropping 25 lbs in a battery be equivalent to dropping 12 lbs with a carbon drive shaft? Could you even feel either modification? You would more likely feel the effect of a lighter driveshaft did than you would the effect of a lighter battery. I'm not sure what battery and if you were thinking about an aluminum or carbon shaft. I'll assume its a Ballistic life pack that weighs 3 lbs. Battery (3lbs, 28-3lbs = 25lbs savings) - $250 Aluminum shaft (13.2lbs, 24.2-13.2lbs = 11lbs savings) - $420 Carbon shaft (12.1lbs, 24.2-12.1lbs = 12.1lbs savings) - $1000 Battery would net you most static weight drop per dollar 25 lbs / $250 = 0.1 lb/$ 11 lbs / $420 = 0.026 lb/$ 12.1 lbs / $1000 = 0.0121/$ Dropping rotational mass will make the most noticeable effect, but it would be to a very small magnitude still and difficult to quantify. If you were looking to drop rotational mass, get a lightweight clutch and flywheel to get mass that is rotating faster, and then get a driveshaft. If your battery needed to be replaced, then it would be a great time to get a lightweight battery. I have a lightweight battery and honestly didn't notice much of a difference in handling. Then again I haven't had the car corner balanced since installing it so that may have a part. FWIW, I plan to get a carbon driveshaft in the future.
| The Following User Says Thank You to JDKane527 For This Useful Post: | Strife26 (04-17-2017) |
#273 |
Drives: 2013 GBS BRZ Limited
You asked a question, I answered with a fact.
If you cant handle the answer, dont ask the question. YES a CF driveshaft will make a difference - less than 1/10th APPARENT hp. Reducing rotating mass DOES NOT increase horsepower in any way. PERIOD. FACT. Can it result in faster acceleration - yes. Can it provide Higher engine RPMs - yes. Do you think the engineers that designed the space shuttle tested the whole assembly before they launched it the first time, or did they CALCULATE the total thrust of all three SMEs + SRBs? GUESS WHAT - THEY CALCULATED IT and ... wait for it.... they were RIGHT. Last edited by stugray; 05-25-2015 at 01:56 PM. |
#274 | |
Junior
Drives: a car
#275 | |
Drives: GT86
| The Following User Says Thank You to GT86_PRAGUE For This Useful Post: | Strife26 (04-17-2017) |
#276 | |
Junior
Drives: a car
1. Being an engineer is being an applied mathematician. We go to school to get it right, over and over and over again. Eventually it becomes second nature to us, thus doing the math for a real world problem (LIKE THIS ONE) give numbers that (when all other factors are negligible) will give you minimal difference. 2. I still think you fail to understand, experience is biased no matter how hard you try and make it not be. 3. Here's a question from my physics textbook chapter 8 rotational kinematics, (the same principles used to do all this fancy unicorn work with the driveshaft); The angular speed of an automobile engine is increased uniformly from 1170 rev/min to 2880 rev/min in 12.6 seconds. a) find the angular acceleration in rev/min^2 b) how many revolutions does it make in this time? can you see how the math can numerically quantify a real world problem? 4. You're looking for approval for buying the driveshaft. You keep wanting someones experience review for it, yet this thread basically disproved its ability to significantly, even minimally improve acceleration. You've already made up your mind about it and refuse to believe that it doesn't do any good.
#278 |
Junior
Drives: a car
Here's a great idea, how about instead of looking for someone else's experience about the driveshaft, why not buy it and make your own experience. Don't look for approval in the internet.
#279 |
Drives: 2013 FR-S Whiteout MT
just get both and be happy!
When in doubt, throttle out!
#280 | |
Hotlink Terrorist
| The Following 2 Users Say Thank You to themadscientist For This Useful Post: | cdrazic93 (05-26-2015), Ultramaroon (05-26-2015) |
| Lightweight aluminum drive shaft installed. | stockysnail | Northwest | 18 | 02-05-2020 12:18 AM |
| Driveshaft Shop Aluminum Drive Shaft. | FT-86 SpeedFactory | Engine, Exhaust, Transmission | 40 | 10-15-2015 10:11 PM |
| Invidia N1 interference with Driveshaft Shop aluminum shaft. | xkalelx | Engine, Exhaust, Transmission | 6 | 03-03-2015 10:43 AM |
| Scion FR-S / Subaru BRZ Drive Shaft Shop Carbon Fiber Drive Shafts In Stock | Anthony@RWHP | Transmission and Driveline | 4 | 12-25-2013 09:09 PM |
