12-18-2015, 04:52 AM | #267 | |
12-18-2015, 05:09 AM | #268 |
You need a '-' minus sign in your post start ignition timing you got +4 instead of -4 :-)
your post start maf corrections look a bit agressive, it might have problems , after start on rearly cold days, not sure it never gets cold where I am. try the ones below from wayno,s thread do you need it to idle at 800 ?? when its fully warmed up, im back down to 700 . |
12-18-2015, 05:13 AM | #269 |
mod your cold/warm/hot injection ration tables as per below
ie zero port in the 0.2 load column will smooth idle a lot |
The Following User Says Thank You to steve99 For This Useful Post: | Yobiwan (03-08-2016) |
12-18-2015, 05:42 AM | #270 | ||
Thanks! I have edited my Values to match Waynos, as well as the injection ratio tables as you suggested, as for the idle stock before the edit it was at 750 RPM so I put it back to that. Also why does waynos car have -6.99 vs the -0.04 post start ignition timing I was supposed to have before? Thanks again for checking these:
12-18-2015, 07:36 PM | #271 | |
If you need more knock resistance above 4800 then change the pi\di ratio rpm scaling in the last two rows like waynos tables from 4800, 5200 to 7000,7200. This will hold full di to 7000 instead of 5200. Not rearly needed if you have good 93 usa fuel but works on our crap 98 and your 91 Last edited by steve99; 12-18-2015 at 08:35 PM. |
The Following User Says Thank You to steve99 For This Useful Post: | FRSBRZGT86FAN (12-18-2015) |
12-18-2015, 09:42 PM | #272 |
I will make a note for others that I noticed if I used any advanced timing at all during my cold start in cold weather, I could occasionally get knock during cold start ups (lowering the adv multiplier). I have since reverted back to a retarded post ignition start (also around -6) and lowered the cold idle RPM to max at 1100 to help keep the noise down. Due to this, I also had to reduce my MAF tables even more (or else it kinda just idles at a higher RPM anyway).
Steve, could you explain how a lower MAF offset results in it being "more aggressive"? From what I understand, it should make it less aggressive. The RPMs will dip heavily initially if the MAF offset after start is too low, but comes right back up to the desired RPM as necessary I found. Or are you saying that it may not draw enough air during initial cold start and flood/stall the engine? |
12-19-2015, 12:33 AM | #273 | |
So all in all what I have looks good correct? Just loaded it onto my oft and will flash it onto the car after I install the berk muffler delete
12-19-2015, 02:32 AM | #274 | |
12-19-2015, 02:35 AM | #275 |
Thanks Again! It's surprisingly easy to use romraider, so easy it might lull one into a false sense of security when messing with things
12-19-2015, 02:47 AM | #276 |
Also another curious question, does changing the PI/DI ratio tables @ 0.20 g/rev simply make it so that only DI is used at idle? Does this help a bit o acceleration as well?
12-19-2015, 02:48 AM | #277 | |
the maf offset adds fuel to heat up cats its probably possible if maf offset is left high ie lots more fuel and advanced timing it may knock but seems unusual at such low rpm. like most stuff it a bit od a balancing act, just make small changes and log results. true if you dont back off the maf offset a bit it will jyst idle high anyway. you need enough maf offset to tichen it up a bit for rearly cold mornings else it may stall |
12-19-2015, 07:30 AM | #278 | |
except at startup i believe engine uses 100% port for initialt startup\warmup then start to use those tables for pi\di split. the idea behind using 100% di was to stop the two intecion system having to inject small amounts of fuel, just let one system do it all for more idle stability. |
12-21-2015, 12:26 AM | #279 | |
Drives: 2013 WRB BRZ
12-21-2015, 01:22 AM | #280 | |
http://www.ft86club.com/forums/showthread.php?t=83945 once you load up wayno's defs for your rom those tables will show up in romraider The tables are always in the tune its just that those tables were not indexed in the standard oft definitions |
Similar Threads | ||||
Cold start question | retrosmiths | Scion FR-S / Toyota 86 GT86 General Forum | 106 | 11-15-2016 02:14 PM |
Cold weather knocking during start ups. | JDMenrique | Issues | Warranty | Recalls / TSB | 38 | 01-12-2015 11:53 PM |
backfire at cold start | FreaQshoQ | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 10-16-2013 06:21 AM |
White Smoke cold start up in Cold Weather (turbo cars) | whitefrs | Forced Induction | 17 | 09-25-2013 05:05 PM |
Loud cold start and mpg drop since new | be6sti | Issues | Warranty | Recalls / TSB | 7 | 11-28-2012 01:35 PM |
