Old 08-18-2023, 05:45 PM   #267
dynarun55
Drives: 2015 midnight blue limited edition.
Originally Posted by Ignore Your Doctor View Post
2015 BRZ
JRSC C38 w/ HBP
Walbro 450 pump
ID1050x
Delicious tuning e85 kit 68-70% ethanol
JDL 4-2-1 EL headers w/ Nameless combo pipe and perrin 3" CBE
Nice! Did you measure on pump gas as well ?
Sent from my Pixel 6 Pro using Tapatalk
dynarun55 is offline   Reply With Quote
Old 08-20-2023, 12:54 AM   #268
tomm.brz
Drives: brz 2017 hksv2
e85 coul give you a lot more gain than +20hp peak
Old 08-22-2023, 12:05 AM   #269
Ignore Your Doctor
Ignore Your Doctor's Avatar
Drives: 2015 BRZ WRB
not with the hbp, new injectors, and pump. it was making around 290 with the c38 and headers + exhaust
Ignore Your Doctor is offline   Reply With Quote
Old 08-22-2023, 08:56 AM   #270
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
either something is wrong with your car or the dyno
Breadman is offline   Reply With Quote
Old 08-22-2023, 10:22 AM   #271
Ignore Your Doctor
mustang dyno so these numbers are at the wheels not the crank. I promise its accurate lol. I have dynos from every time I got it tuned. From 168hp stock all the way to this most recent one.
The Following User Says Thank You to Ignore Your Doctor For This Useful Post:
Breadman (08-24-2023)
Old 08-24-2023, 11:03 AM   #272
Breadman
Breadman's Avatar
Missed the mustang dyno part. Makes sense when you add 5-10% to get dynojet numbers. Taking the base run numbers and doing back of the napkin fast and furious math also pretty much matches
Old 09-12-2023, 11:00 PM   #273
canyons
canyons's Avatar
Drives: 2013 Supercharged BRZ, E85, Ohlins
JRSC, low boost pulley, E85 on DynoJet.
JRSC, low boost pulley, E85.
canyons is offline   Reply With Quote
Old 09-12-2023, 11:04 PM   #274
dynarun55
Attachment 222349
Nice!! Time for HBP
Old 03-26-2024, 10:41 AM   #275
Eaton PSI
Drives: 2013 86
Harrop supercharged
-Rod/Eaton PSI
-Harrop SC
-98ron
-9psi
-85mm pulley, billet 90mm 11.5:1 pistons (2.2L), custom LAsleeve liners, forged rods, lightened OEM valves, lightened OEM flywheel, WRX oil pump, minor head porting, fully balanced.
Stock exhaust, airbox/filter, injectors. ECUtek tune.
Eaton PSI is offline   Reply With Quote
The Following User Says Thank You to Eaton PSI For This Useful Post:
tomm.brz (03-26-2024)
Old 03-26-2024, 12:57 PM   #276
B T
IAG Closed Deck Block
Cometic Head Gasket (lowering compression to 12.2:1)
Edelbrock Supercharger with 2.70" pulley
E80 Fuel with Ptuning flex kit
Radium in tank pump with Warlbro 450
Radium parallel feed fuel rails
IDX1050 injectors
JDL 4-2-1 headers
CSG 70mm exhaust
Built heads with Ferrea oversize valves and springs, ported/polished/radiused
Fluidampr Harmonic balancer
ACT clutch/flywheel
3.7 Final Drive
B T is offline   Reply With Quote
The Following 3 Users Say Thank You to B T For This Useful Post:
brandonblt2 (05-17-2024), dpfarr (09-14-2024), tomm.brz (03-26-2024)
Old 05-16-2024, 12:35 PM   #277
M0nk3y
330.5 whp/228 Ft-Lbs
Mainline Hub Dyno
IAG 600 12.5 Compression
86.25mm Bore
GSC Valves and Valve Springs
Fluidampr
SouthBend Stage 2 Endurance Clutch, 4140 Billet Flywheel
Harrop SC with 85mm Pulley
E70 Fuel with PTuning FF Kit
Radium In Tank Hanger with Walbro F90000267
Radium FPR Surge Rank with Walbro F90000267
IDX 1050 Injectors
JDL 4-2-1 Headers
JDL FP/OP Dual Resonated
Perrin 2.5" Resonated Exhaust
3.91 22+ Auto Diff
Kyle H. - #89 STX
The Following User Says Thank You to M0nk3y For This Useful Post:
StraightOuttaCanadaEh (05-16-2024)
Old 05-16-2024, 01:00 PM   #278
Wes
interesting that you went with 12.5 compression, usually people go in the other direction and get 10.1 iirc
Instagram: @gt86ws
Old 05-16-2024, 01:33 PM   #279
M0nk3y
Power numbers are still relatively small, for what it is. 10.1-10.5 just gets to you to the point of requiring more boost and further increasing lag. etc
Kyle H. - #89 STX
Old 05-16-2024, 03:32 PM   #280
Wes
Oh and I see they were able to get around the recent ecutek restrictions? Or is this dyno plot from before the changes?
Instagram: @gt86ws
Dyno numbers list from Evasive Motorsports Meet/Dyno Fish Southern California 29 02-24-2013 04:16 AM
Dyno Compilation - dyno testing results and recommendations Illusive Engine, Exhaust, Transmission 82 02-08-2013 08:00 PM
Bolt-ons dyno comparisons thread? seven Engine, Exhaust, Transmission 6 11-25-2012 11:28 PM
Base line dyno figure (dynapak Hub dyno) gtauto AUSTRALIA 16 10-08-2012 09:06 AM
