#267 | |
Drives: Vortech Supercharged FR-S
I think it is because the front Brembo piston area is larger than FR-S oem caliper. But the rear Brembo piston area is smaller than the FR-S oem caliper.
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me. Your car is your story, so don't let someone else write the book. ( White Tiger ) - FiGo's 車誌. |
#268 |
As I've said throughout this thread, Brembos front and rear gives you a big shift forward in brake bias...
You could try different pads front and rear. If you call Carbotech they may have some suggestions. - Andy |
#269 | |
Do you have any other street performance pads combination recommended?
#270 |
Hawk has 2 new pads that I've heard surprisingly good things about.
They have a new HPS 5.0 and a new "Street Race" compound. That might work out. - Andy |
| The Following 2 Users Say Thank You to Racecomp Engineering For This Useful Post: | chanomatik (11-03-2014), Figo (10-31-2014) |
#271 |
Snow Don't Hurt!
High Performance Street/Race Hawk Pads, built to take more consistent abuse.
or High Performance Street 5.0 Hawk Pads, so not necessarily for racing application, just better than OEM daily driver street use. I don't know the meaning of restraint, so I'd be all over the racing ones to maybe offset the front bias.
#272 |
Drives: Toyota 86 TRD Version AT
So would I be better off with STI brembos in front and stay with the stock rear calipers?
#273 |
Senior Addict
Drives: 86 GT
FWIW I'm currently running Brembo's front and rear, and they're brilliant for street use. Initially I had stoptech pads all round and found the front bias a little too strong, so switched rear pads to project mu and the 'balance' improved noticeably.
Mind you, I only felt the strong front bias when doing long hard braking.....which is rarely happens on public roads. Otherwise they felt fine. Now if I were to track the car (which I don't) I'd probably remove them and go with a more performance focused package. Also bear in mind that rotors and pads for brembo's are rather pricey. I dare not imagine the cost of regularly replacing pads all round if I tracked the car with them. |
| The Following User Says Thank You to Fizz For This Useful Post: | chanomatik (11-24-2014) |
#274 |
| The Following 2 Users Say Thank You to Racecomp Engineering For This Useful Post: | chanomatik (11-24-2014), Tye300 (11-24-2014) |
#275 | |
Snow Don't Hurt!
#276 |
I finally joined the club!
![]() Pardon the dirty car, it's been raining here the last few days...
| The Following 2 Users Say Thank You to Tye300 For This Useful Post: | chanomatik (12-01-2014), SkAsphalt (12-05-2014) |
#277 |
Drives: FRS, Supra, Colorado D, GLC63
Finally got my set on. Installed them sunday, went to the track monday. Very happy with them! Im running a slightly more aggressive stoptech pad in the rear and the brake bias is really negligible. On the street you don't notice it at all actually and on the track I only noticed it when I was braking VERY hard from about 110+. Pedal is super firm and predictable.
Got the calipers, rotors, lines, hardware, pads and fluid for less then $2000.00. [IMG]http://i326.photobucket.com/albums/k409/wiebtechperformance/65A871CF-AA26-49A5-BE53-F6BAA674F687_zps4hb***wx.jpg[/IMG] ![]() ![]() ![]() ![]()
| The Following User Says Thank You to The Racers Line For This Useful Post: | chanomatik (12-03-2014) |
#278 |
Snow Don't Hurt!
So many nice setups in here! I've been waiting to reveal mine for over a year now. The project has only just now reached its finality. Here's a sneak peek for y'all, not shared anywhere else!
![]() They should be mounted tomorrow, so I'll have more pics then. Beyond excited!
| The Following User Says Thank You to chanomatik For This Useful Post: | MooseWRX (12-03-2014) |
#279 |
Snow Don't Hurt!
Only fronts right now, but rears should be installed next week.
#280 |
Ridge Racerrrrrrrrr
Exactly why I am not installing rear brembos
| will the sti brembos fit fr-s/brz? | driver01 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 51 | 04-12-2014 03:25 PM |
| Those Brembos, fixed caliper? Or not? [Patent inside!] | madfast | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 155 | 12-08-2011 03:06 PM |
