Old 05-19-2014, 09:52 PM   #267
NYC BRZ
AutoX Addict
NYC BRZ's Avatar
Drives: 08 Pontiac G8 GT,13 GBS BRZ Limited
Originally Posted by toeout View Post
The stock bushings have a slit forward, so that's how installed mine. I also tried them the other way just for kicks and it seemed the same.
Also bought the collars mentioned on page 11. Rotating the bar around, the collars didn't make any contact with the bushing brackets
Have the collars helped the feel? Any walking issues anymore?
2013 BRZ Limited- GBS - 6MT -VIN #0937
~~NYR SCCA # 18 C Street R (CSR)~~
"But there’s no mistaking the noise. This car is loud, and not in a particularly nice way. There’s no crisp exhaust note, no induction wheezing. It’s just the sound of petrol exploding in a metal box." - Jeremy Clarkson
NYC BRZ is offline   Reply With Quote
Old 05-19-2014, 11:43 PM   #268
toeout
I don't have the front sway connected at this time, because I was troubleshooting an unrelated noise. But I also don't see how it could possibly walk with these collars.
toeout is offline   Reply With Quote
Old 05-20-2014, 09:31 AM   #269
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
I bought the ones pictured above but they didn't arrive before I put the bar on so I used the ones Sam provided and gave them about 1/2" gap to the mounts. Haven't bothered putting the round stops on because the bar has been working fine for me, no rubbing, no noticeable walking and no binding/interference. Bar has been great although it must be said I think it's noticeable this bar was developed for FR-S spring rates, I haven't been able to dial out/drive around corner entry push on concrete thus far, though still very early in development, still have a long way to go.
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop
2007-08: #54 STX 05 WRX Sedan
2009-12: #92 BSP/ASP 07 Solstice GXP
2013-14 : #192 CS 13 Subaru BRZ
Sccabrz192 is offline   Reply With Quote
Old 05-20-2014, 10:52 AM   #270
SubiePig
Drives: -'02 PSM WRX, '94 Miata, '13 BRZ
What are you using for a rear bar? I was fighting front end push as well most of the beginning of the season. I was following Andrew's setup from nationals last year but ended up going in my own direction. I feel that the increase in roll stiffness in the front is to unbalanced to keep the stock rear bar with the Stranos bar. I went to a 18mm whiteline rear on medium stiff (75% increase) to even the front and rear out. Car is MUCH easier to drive. I realize my car being in STX the spring rates become a factor but with the BRZ being a bit pushy from the start I wouldn't want to increase that further with a bigger bar and no rear.
Sponsered by:Chasebays/Corr Performance Tuning/KartBoy/Bad Panda Motorsports/Racer-X Fabrication
STX Build thread 14th/67 SCCA Nationals (2014)
SubiePig is offline   Reply With Quote
Old 05-20-2014, 11:03 AM   #271
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
I Run C-Street so I'm running OE rear. Did you change front to rear spring balance, or just increase proportionally?
Old 05-20-2014, 11:43 AM   #272
SubiePig
I am pretty close to the stock frequency ratio front to rear. Not the numbers I would like but I am going to wait to worry about that for now.
Old 05-20-2014, 02:12 PM   #273
Aznsky
Drives: Nissan 350Z (sold) 13' Whiteout FRS
I and a few friends like my setup so far with the Strano front bar and 16mm wrx rear bar. Spring rates are the Feal 7k-Fr 6k-Rr
Aznsky is offline   Reply With Quote
Old 05-20-2014, 02:38 PM   #274
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
@Sccabrz192
You know that this is the second softest aftermarket bar on the market right? It works great for my BRZ, no one that drives my car has understeer issues (it's always oversteer if anything).
What tires and pressures are you running? Also, what shock settings, assuming you're on Konis?
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 05-20-2014, 02:53 PM   #275
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Originally Posted by Kido1986 View Post
@Sccabrz192
Yup, that is why I went with it.
Here is my short build thread so far:
http://www.ft86club.com/forums/showthread.php?t=63918
So far my concrete settings are:
Front:
1/2 from soft
1/8 toe out
~1.15 degrees neg camber
33.5 PSI 235/40R17 ZII
Rear:
3/4 from soft
0 toe
~.85 degrees neg camber
29 PSI 235/40R17 ZII
At this point I still feel the pushiness has as much to do with my corner entry as it does with the car and it's setup. I am still carrying in a bit too much speed when I initiate the turn, and the car seems to punish you when you go in even just a little bit too hot. It washes away and even reducing steering angle and applying throttle doesn't seem to get it to neutralize out, just more and more push.
Quick comparison video of myself and co-driver from last weekend's Toledo event... my apologies, I had a little too much fun with iMovie.
Old 05-20-2014, 03:15 PM   #276
Kido1986
Dodging cones
Kido1986's Avatar
That's so odd. I have same tires, bar, shocks. I use 38F/33R, more rebound all around than you and slightly less toe out Front, and a good bit toe in in rear.
Only difference is I have just a slight bit more camber up front.
Here's me in Atlanta (pavement at ~55f, though decently sticky) this weekend. [ame="https://www.youtube.com/watch?v=eDd33VDpxRI"]BRZ at Atlanta Match Tour, Saturdy 5-17-14 CS #99 - YouTube[/ame]
Old 05-20-2014, 03:54 PM   #277
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
yea it is interesting... my car is extremely loose on power exiting corners on asphalt, but it's so pushy on corner entry on concrete I cant really get to apply throttle early because I'm waiting for the car to get pointed.
Autocross video of Strano Performance Parts FR-S, first time out. Sam Strano Tracking / Autocross / HPDE / Drifting 18 10-02-2014 10:01 PM
Lutz Performance | Performance parts SALE Diego@lutzperformance Engine, Exhaust, Bolt-Ons 8 10-08-2012 11:09 AM
TRD/STI & Performance Parts newft86 Australia Classifieds 31 08-27-2012 08:17 AM
Strano Performance Parts making use of Suspension and Brakes Sam Strano Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 08-11-2012 08:52 PM
