Old 09-26-2017, 12:30 PM   #267
blkwrxwag
Drives: DS FRS
Originally Posted by DaWorstPlaya View Post
Hopefully they allow a catted header and a Vishnu OFT, that might be enough for me to make the switch. The lack of umph is really starting to bug me. That way if there aren't any local competitors, locally I could go play in STX (and lose less horribly) until we get more folks.
To me, the only way you can do a tune, is using OFT as they are standard tunes for all years that are readable. Write your letters explaining why you are for that.
-Max H.
blkwrxwag is offline   Reply With Quote
Old 09-26-2017, 12:32 PM   #268
M0nk3y
I've expressed my hate in a header and tune for a Spec class, as you leave it open to vulnerability and removed the one thing you were trying to accomplish.
I've already written my letter against that.
Kyle H. - #89 STX
Old 09-26-2017, 12:37 PM   #269
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
Yeah, I'm also in the anti-header/tune for spec camp.
I'm wary of the Stage 3 spec tune, but will reserve judgement until a determination is made and more details are released. I highly doubt it will be OFT, since they're not a TireRack supplier. My best guess is that they are talking/working with Cobb to see about developing a flash tune for the platform, since Cobb is both a well-known entity within the Subaru community and a supplier for TR.
If they can slightly reduce dip and, more importantly IMO, do something with the rev limiter/fuel cut, it might actually be pretty nice on an otherwise "stock" engine.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 09-26-2017, 12:37 PM   #270
blkwrxwag
Drives: DS FRS
I can see it both ways... it's something I think would make the car more fun and is something I want to do, but it does make everything less spec and more expensive. I think it might not be good for year #1, but should be looked at for year #2.
-Max H.
Old 09-26-2017, 12:41 PM   #271
M0nk3y
Going down the tuning path IMO is not the greatest of options. I've written it out pretty much my thoughts on tSB so I'll just copy and paste it over.
A 2013 tune vs a 2016 tune are completely different animals. Even a 2016 to a 2016 tune can be different in the parameters that are used due to how the ECU adapts to what's there.
My example, which is what I also sent to the SEB regarding my stance against headers and a tune.
Run 1 - was a baseline dyno WITH a canned tune that Moto-East has used regularly to send to his customers. If you were to order a tune from him and wanted it done remotely, this is what you'd get pretty much. Blue Line Run 1
As you can see, with WITH a tune, Headers, OP, Exhaust...the torque dip is still very much there. It took 8-9 runs later to end up at the final pull numbers as seen. For what it's worth, this particular dyno runs 5% short of other dynometers. As well, if you compare my tune to say a 2013, you'd see that the 2013s are able to pull harder up in the redline band and not have much of a drop-off at high RPM. I can fix this by running 100 octane when available, but still knock protection on a 2016 is much more intrusive than a 2013.
If you to take my tune, load it onto another car with exact same mods, you'd probably discover different results.
Kyle H. - #89 STX
Old 09-26-2017, 12:45 PM   #272
blkwrxwag
Drives: DS FRS
OFT has tunes for 2013-2016 based on ECU type. Are you saying that their tune will net better results on one year vs another?
I have an OFT Stage 1 map I run for street driving - it definitely helps with the torque dip. Not a lot, but enough to make it worthwhile. I'm not sure it would make much difference at autocross as I don't feel the dip there very often.
-Max H.
Old 09-26-2017, 12:51 PM   #273
M0nk3y
Not the tune per say, but more so the ECU with that associated car.
Pallotta and Simmons for example, they could run their car and never encounter engine knock on ECU side and they netted some serious gains up top.
My car has a lot more inherit knock encoded within the ECU which needs to be corrected w/protection. Talking with Moto-East, along with my own research, as the years for the FRS/BRZ go from 13-16, the ECUs have changed and such that more protection is coded within.
So, the amount of actual knock hasn't really ever changed between a 2013 and 2016. But the ECU has become more precautionary with sensing knock and correcting it. So, yes I could probably turn off knock protection and be gain a couple horsepower...but I'm doing so now at the risk of my engine.
If a spec tune came out with obvious knock protection, a 2013/14 would benefit more so over a 15/16.
Make sense?
Kyle H. - #89 STX
Old 09-26-2017, 12:53 PM   #274
blkwrxwag
Drives: DS FRS
Understood - thanks for the explanation.
-Max H.
Old 09-26-2017, 01:02 PM   #275
M0nk3y
Is half of me making sure SSC doesn't get too close to STX in terms of rules? Yea probably.
But IMO, just from the side of competition aspect - Stock Tune is about the closest you can get for driver against driver.
Kyle H. - #89 STX
Old 09-26-2017, 01:08 PM   #276
blkwrxwag
Drives: DS FRS
But I want the sound of a UEL header, dammit!!
-Max H.
Old 09-26-2017, 01:11 PM   #277
M0nk3y
Funny, they make a class like that...
Just buy your car back already
Kyle H. - #89 STX
Old 09-26-2017, 01:13 PM   #278
chucky12012
Drives: 2013 Asphalt Scion FR-S
I like the idea of running header and tune in the class from a benefit to the car, but I think for health of the class and keeping it in a nice healthy place further from STX, I prefer they steer clear of it.
chucky12012 is offline   Reply With Quote
Old 09-26-2017, 01:13 PM   #279
blkwrxwag
Drives: DS FRS
I made an offer. They laughed.
-Max H.
Old 09-26-2017, 01:34 PM   #280
imnotsureaboutbrz
Drives: between cars...
I'm also doubtful of the header and tune combo. If you are gonna buy a header mind as well go STX.
imnotsureaboutbrz is offline   Reply With Quote
Upgrading brakes on the lower spec GT86 (the standard spec outside of US market) OnionTou Suspension | Chassis | Brakes -- Sponsored by 949 Racing 55 07-01-2016 01:36 AM
what's the difference between twin screw, centrifugal, single turbo and twin turbo? warplane95 Forced Induction 86 04-17-2014 02:36 PM
my twin RWDGUY Mid-Atlantic 2 04-08-2013 09:23 PM
JDM Spec-C V9 Twin Scroll VF36 complete Nico TURBO Engine, Exhaust, Bolt-Ons 0 12-05-2012 11:20 AM
