#267 | |
Drives: GBS BRZ Harrop SC/PTuning Header
Their lines do not kink if you properly clock everything.
#268 |
Drives: none
What have people been doing for headers?
Can anyone share experience with different header options? I know Harrop suggest the ACE 400 but considering that's three times the price of the popular Gruppe-S UEL header... Is it REALLY that much better? I'm currently bone stock aside from the Harrop kit so I'm looking to take the next step. Headers seem to be the best option. I've been looking at catted options since I would prefer not to have obnoxious rasp and drone. However, I'm not sold on the idea that a catted setup will provide any significant gains over stock. Yes, I know there are dozens of threads out there debating the merits of different header setups but I'm curious what would be the best match for this kit and a stock header-back exhaust.
Thanks! |
#269 | |
I'm running the PTuning header without issue. I can't really say it's a "better" option pricewise when you're looking at least 1k for a header, but the power is there. A header does not matter as much in SC FI applications over NA applications. JDL does have an EL header that Michelle Abbate used at the track professionally until she switched recently to the Ace Header. |
#270 | |
Drives: '14 981CS, '99 NB1
Do not run a header with a cat on it. I'm kinda surprised you're running the SC with the stock header. It's a really bad idea. A close coupled cat is terrible with a supercharger and can be dangerous for both the cat and the motor (the EGTs skyrocket). I would recommend swapping out the stock header asap. |
| The Following User Says Thank You to johan For This Useful Post: | Irace86.2.0 (07-09-2017) |
#271 | |
Drives: Q5 + BRZ + M796
#272 |
Drives: FRS, Supra, Colorado D, GLC63
| The Following User Says Thank You to The Racers Line For This Useful Post: | johan (07-12-2017) |
#273 | |
As far as I know, ACE, JDL and PTUNING are the only header manufactures that build a header specifically for FI, that is why they are typically recommended; in the case of Harrop, they run an ACE header on their time attack car with good results. |
| The Following User Says Thank You to The Racers Line For This Useful Post: | armstrom (07-10-2017) |
#274 | |
Drives: none
-Matt |
#275 | |
Better Volumetric Efficiency = better FI and NA performance. The main way to optimize VE change on this car is to ditch the crummy stock design for an optimized header system. |
#276 | |
Drives: UK GT86
.: Stealth 86 :.
#277 | |
Drives: none
Perhaps I should provide some context: My car is bone stock aside from the Harrop SC kit (w/ 90mm pulley rather than the 95mm) and a Delicious F&G Ecutek tune. The next logical step seems to be a header so I'm weighing my options but can't find much in the way of real world comparisons between different headers in supercharged applications. I understand Harrop run the CS400 and recommend it, but that's quite vague. If something is "optimized" for a specific setup it would be nice to know HOW it is optimized.. what benefit does it provide over some, presumably, "less" optimized options. |
#278 | |
My understanding is that with SC, optimized headers do not serve a purpose other than handling the increased airflow. In a turbo application, you naturally want as efficient thermal and pulse routing as possible to impart more energy into the turbine side. With a supercharger, that pulse and thermal energy is just dumped over the side of the platform to come out as noise, just like NA applications do. I don't think it's warranted to fret over the difference between $600 vs $1500 headers if you're looking at a budget and using the vehicle for personal enjoyment. |
#279 | |
Drives: Toyota GTS 86
I did some research on the Harrop and the advice I got was the 350 is best as it has the best balance of low end torque and power at higher revs: but doesn't fit my RHD vehicle. So had the choice of either better high-end revs (ACE250) or better low end torque (ACE400). ACE use the overpipe to extend the distance before the 2:1 merge on the 4:2:1 design. I don't have first hand experience on how big a difference this makes though, but that is the principle. In terms of cost remember this includes the overpipe so when you do your $ for $ comparison you should include the cost of an overpipe in the equation. (sources: conversations with Harrop, emails with Delicious and forum post with CSG). |
#280 | |
Drives: none
-Matt |
| JDL turbo kit owners thread | yomny | Forced Induction | 1352 | 01-08-2025 05:20 AM |
| HKS Supercharger owners thread | wbradley | Forced Induction | 1054 | 10-26-2024 02:18 PM |
| P&L Turbo kit Owners thread | Hawaiian | Forced Induction | 73 | 07-07-2018 03:31 AM |
| Harrop car lip kit? | djdnz | Cosmetic Modification (Interior/Exterior/Lighting) | 15 | 12-15-2015 03:50 PM |
| **Offical 213/323/626/818 owners thread** | mr. slim | Southern California | 71 | 10-07-2013 01:58 PM |
