Old 01-15-2016, 01:38 PM   #15
bhmax
Drives: 13 BRZ, 17 Focus RS
Here's the numbers I used for stock.
bhmax is offline   Reply With Quote
Old 01-15-2016, 02:10 PM   #16
toast
Drives: 14 BSP Edelbrock BRZ
According to FSM, front pistons are 42.8mm, front rotor effective diameter is 247mm
Rear piston is 38.1mm, rear ED is 254mm. Converted to inches that is 1.685 front and 1.5 rear. I don't know how ED correlates with diameter, so I just used outer diameter which for stock I thought was 11.5 front, not 11.58.
Regardless, both of our calc's show a tiny shift forward which can easily be offset with rear pads if necessary.
toast is offline   Reply With Quote
The Following User Says Thank You to toast For This Useful Post:
bhmax (01-15-2016)
Old 01-15-2016, 02:27 PM   #17
bhmax
Interesting how the FSM shows those piston sizes. Mine are what I measured with a caliper. I guess by using effective diameter for rotor, pad height maybe wouldn't be as important for a comparison.
Keep us updated if you get the Wilwood kit. I'm thinking about staying stock for a while but increasing pad friction in rear to move the bias by about 5%.
WTB: Shifter Linkage Dust Boot & Shifter Dust Boot Erick.Hnandez Want-To-Buy Requests 6 01-27-2021 06:58 PM
OEM Springs and Dust boots - Free Shipping stefmiesterb Brakes, Suspension, Chassis 4 03-31-2015 08:03 PM
Shifter dust boots - $15.00 Shipped SilentMike Transmission and Driveline 4 05-18-2014 03:43 PM
Brake dust or rail dust? Dealership bs? Muskokan Issues | Warranty | Recalls / TSB 12 12-21-2013 10:30 AM
