#15 |
Why isn't it being drilled and retapped? Oil pan sounds expensive. Oh well, you'll get the hang of it. I've twisted off many bolts and broken many sockets on bolts that wouldn't twist. It happens. Just never tighten steel fasteners(drain plug) too tightly in an aluminum part(oil pan) because aluminum threads aren't very strong
| The Following 2 Users Say Thank You to Ashikabi For This Useful Post: | Golevka (12-29-2015), Summerwolf (12-29-2015) |
#16 | |
FYI ...... since you have a "history" of over tightening bolts ( ) ...... if you ever decide to tighten the bolts on an oil pan ...... just snug them up and do a gentle 1/4 turn more.Yep, they twist off real easy ...... which begs the question "how many crankcase pan (oil pan) bolts can you twist off and the pan still won't leak ..... ?? ANSWER: about every other one .... if you have a thick gasket and use lots of Permatex........ ![]() How do I know that ?...... I don't wanna talk about it ...... humfrz |
#17 |
| The Following User Says Thank You to humfrz For This Useful Post: | Golevka (12-29-2015) |
#19 | ||
Drives: 2005 Toyota Camry
Absolute worst case scenario, I would've used no more than 3/8" (and even 1/4" drive if it was a super sensitive bolt so I don't accidentally overtorque it). Quote:
http://parts.subaru.com/a/Subaru_201...10-031-01.html |
#20 |
Drives: MDX, Camry
i can feel your pain ...
i started working on my cars after reading lots of online chats. One of the key insight is that a good torque wrench is a very expensive tool and needs to be frequently calibrated. so the cheap stuff we buy are not going to be useful, except for tightening lug nuts. for anything less than 40 lb ft, just hand tighten. a good rule i use is that i use a short 3/8 wrench with a short pipe. i use both when removing nuts and only use the short one when tightening. this way i won't strip a nut/bolt and i can always remove them later. hope this helps. |
| The Following User Says Thank You to qqzj For This Useful Post: | Golevka (12-29-2015) |
#21 |
Drives: 2015 Lightning Red BRZ
A bad borrowed torque wrench bent the swingarm on the motorcycle I used to have. Invest in a good torque wrench or tighten by feel. Don't rely on a cheap torque wrench. Since then, I've bought a Precision Instruments torque wrench and it's worked well for me. I'm a fan of torquing to specs, but if you don't have a good wrench, go until it stops and then 1/4 to 1/2 turn more. Be extra careful if anything is aluminum.
Sent from my SGH-T999L using Tapatalk |
| The Following User Says Thank You to zberz For This Useful Post: | Golevka (12-29-2015) |
#22 |
Like others have said, don't let it discourage you. You learned a valuable lesson on something that isn't super expensive. That's a win in my book.
#23 |
The Fail Boat
Drives: CWP S.B.
Hey op it's the prefect chance for you to get fumoto valve. Change oil is easy with that!
#24 | |
#25 |
Drives: 2013 Subaru BRZ
I've always went with the "hand tight" method with my oil changes, no leaks or issues. I can't imagine the drain plug over time suddenly loosening itself?
#26 | |
It does make it easier to overtorque, but the more important part is using the right tool for the right bolt. 1/2" is too much for a simple oil drain plug. -alex |
| The Following User Says Thank You to mav1178 For This Useful Post: | Cole (12-28-2015) |
#27 | |
![]() humfrz |
| The Following 3 Users Say Thank You to humfrz For This Useful Post: |
#28 | |
The Tekton ones are very similar to that (purchased off amazon) I wouldn't doubt they are from a similar manufacturer
| Tags |
| damage, oil change |
| FR-Sandwhich: Total or not total? | Joshwahhhs | Scion FR-S / Toyota 86 GT86 General Forum | 51 | 10-03-2015 09:11 PM |
| Looking for a set of OEM BRZ DRL Strips | s0sl0w | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 04-13-2015 10:18 PM |
| What headlights to pair with LED strips? | l0aded | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 06-24-2014 05:37 PM |
| Rubber Strips on the top of the car | zackcp04 | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 05-31-2014 11:44 PM |
| RGB LED strips help | BadLuckZN6 | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 01-21-2014 02:21 PM |
