Old 12-06-2015, 11:30 AM   #15
stevesnj
stevesnj's Avatar
Originally Posted by Cole View Post
Uhm, nope. Zinc plating and paint significantly reduce the possibility of corrosion.
Source: I'm a corrosion technician, and work on structures far more likely to corrode than a car. One of the best methods for stopping corrosion? Putting a coating on a structure.
Sounds good, I'll have to do that too. But it's the unseen scratches and rocks or other debris that hit the metal and expose the raw metal and when that starts to rust it's only a matter of time... Which is the recommended coating?
My 2016 Build thread
The Following User Says Thank You to stevesnj For This Useful Post:
Cedars (12-06-2015)
Old 12-06-2015, 11:35 AM   #16
Cole
Not a troll
Cole's Avatar
Uh... Your paint. Or the zinc plated metal your car is built with.
The Following User Says Thank You to Cole For This Useful Post:
go_a_way1 (12-06-2015)
Old 12-06-2015, 11:38 AM   #17
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
True, but it would be significantly less than if left uncovered I would think.
True but if left uncovered you will not need to rub the dirt in and scratch the paint by putting on and removing a cover. After winter a simple proper wash and car is good to go.
Old 12-06-2015, 11:40 AM   #18
JD001
JD001's Avatar
Drives: Subaru BRZ
Covers have a habit of lifting when the wind picks up and you can't keep an eye out all of the time. Whilst it's flapping about it rubbing against the paint.
I have used a Permabag in the past which is great in keeping the car safe however you'll have to keep an eye out for condensation build-up.
Old 12-06-2015, 11:40 AM   #19
stevesnj
stevesnj's Avatar
I thought you meant like a spray can undercoating. But Cars with zinc coating and better paint than our cars do get rust. Not 100% but some will. The way you make it sound is that all cars with zinc coating and paint will never rust.
Old 12-06-2015, 11:42 AM   #20
stevesnj
stevesnj's Avatar
Thanks, I'll have to keep an eye out for flapping.
Old 12-06-2015, 11:47 AM   #21
Cedars
Drives: gt86
Rust proof it with zeibart or something similar. Debris will chip at the metal exposing the base metal to salt and elements which can lead to rust. Ur obviously thinking long term.
Cedars is offline   Reply With Quote
Old 12-06-2015, 11:48 AM   #22
JD001
JD001's Avatar
Drives: Subaru BRZ
Yep something else to worry about! Lol
The Following User Says Thank You to JD001 For This Useful Post:
stevesnj (12-06-2015)
Old 12-06-2015, 11:50 AM   #23
stevesnj
stevesnj's Avatar
I know right..lol
Old 12-06-2015, 04:16 PM   #24
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
Ita still gona get dirty if its outside. Op will also need to remove cover to start car once a month in winter then reinstall it
Cars being stored should be left alone. There is absolutely no reason to periodically start a stored car, and several good reasons why it should NOT be started.
billwot is offline   Reply With Quote
The Following 2 Users Say Thank You to billwot For This Useful Post:
Cole (12-06-2015), go_a_way1 (12-06-2015)
Old 12-06-2015, 04:21 PM   #25
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Oh well then I guess I am wrong haha! I have never stored a car because life is too short for winter beaters
Old 12-06-2015, 04:37 PM   #26
Dake
Dake's Avatar
Whatever you get, definitely make sure it's fitted and not just a generic cover with lots of extra fabric.
[ame="http://www.amazon.com/gp/product/B00C3LK554?psc=1&redirect=true&ref_=oh_aui_detailp age_o03_s00"]I got this one[/ame], and I've been pretty happy with it. I don't use it a ton, but it's nice when I'm gone on week-long trips and the car is sitting out in a parking lot. It's especially good when the pine trees are dropping sap everywhere.
As others have mentioned, the trick is keeping your car clean AND keeping the cover clean so as to not make things worse due to friction between the surfaces.
Dake is offline   Reply With Quote
The Following 2 Users Say Thank You to Dake For This Useful Post:
lionbacker54 (12-09-2015), stevesnj (12-09-2015)
Old 12-09-2015, 03:57 AM   #27
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
You should only start the car if you know you will let it idle for as long is it can get up to operating temps and then drive it around so the tires don't dry rot, I've done this for other cars that have lasted 100k with no issues.....
The Following 2 Users Say Thank You to FRSBRZGT86FAN For This Useful Post:
NyC Zn6 (12-09-2015), stevesnj (12-09-2015)
Old 12-09-2015, 08:48 AM   #28
stevesnj
stevesnj's Avatar
Yeh I got the fitted cover just for this reason.
High quality outdoor car cover recommendation? qqzj Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 19 03-29-2016 09:27 PM
WTB: Trunk carpet, cover, spare tire, tools, foams, latch trim/cover Izzy Want-To-Buy Requests 7 06-27-2015 06:38 PM
1of86 limited cover. Indoor cover mint condition SpecPer Cleaning and Detailing 0 06-06-2015 08:17 PM
Oil Leak from either Timing Cover or Valve Cover BRZY Issues | Warranty | Recalls / TSB 5 04-06-2015 08:31 AM
The cover store car cover for sale. FRSfan111 Northwest 2 06-21-2013 04:49 PM
