Old 11-20-2015, 07:13 PM   #15
LaertesSon
LaertesSon's Avatar
Drives: Asphalt 2013 FR-S 6MT
Well, I'm out of "ideas".......
Hopefully, Crawford has a solution.
What a bummer ...... all that work ......
Please let us know how it turns out.
humfrz
I will report everything I get back for you guys to read.
OFT Stage 2 tune, OFH, Works AB-M, Perrin 2.75" Intake/Silicone inlet
Kartboy Short Shifter, WC Lathewerks knob, MTEC springs
TSW Nurburgring, FIVE:AD aero kit, smoked Valenti
LaertesSon is offline   Reply With Quote
The Following User Says Thank You to LaertesSon For This Useful Post:
humfrz (11-20-2015)
Old 11-20-2015, 07:15 PM   #16
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Maybe you pulled a wire slightly out cuz I hear they are a tight fit??
Old 11-23-2015, 10:50 AM   #17
PunX
Drives: GT86 - minor mods
Just my two cents, but as those blocks change the amount of air that engine can access instantly - before opening throttle. did you by any chance disconnected battery to have ECU relearn all the fuel trims and ratios? as fueling has changed, i think it should be reinitiated like that. it may help.
PunX is offline   Reply With Quote
Old 11-27-2015, 04:49 AM   #18
PunX
Any feedback from crawford already?
hopefully this thread isn't forgotten.
--bump--
Old 01-21-2016, 04:26 PM   #19
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by LaertesSon View Post
So today I installed the Crawford Billet Power Blocks. I took the car for a drive after I installed them, and everything seemed normal until I revved it to about 4k under load, and it seemed to stutter and not want to go above that. I took it home and tightened up the intake tube and looked over everything and it all seemed fine, so I took it out again and under a bit more throttle revved it to 4k. Same issue, but this time I got a blinking CEL that went away after a few seconds. I checked the code with my OBD reader and it's a cylinder 2 misfire. Any idea of the quickest way to fix this or find the problem? My guess is the o-ring on that cylinder has come undone and is causing a vacuum leak. Thanks in advance
By the way - my only other mod on the engine is the Perrin CAI and inlet tube. No tune.
What did you hear from crawford?
Old 01-21-2016, 04:28 PM   #20
LaertesSon
LaertesSon's Avatar
I got absolutely nothing from Crawford. They never answered any of my emails or calls. I can't say I recommend dealing with them.
Old 01-21-2016, 04:31 PM   #21
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Too bad ..
Old 01-21-2016, 04:56 PM   #22
FRSBRZGT86FAN
Originally Posted by nikitopo View Post
Too bad ..
So that totally turns me off of buying the crawford BPBs, would money be better spent on pulleys and a front pipe then?
Old 01-21-2016, 04:59 PM   #23
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
Crawford Performance is a joke...need some answers as well.
Old 01-21-2016, 05:05 PM   #24
LaertesSon
LaertesSon's Avatar
Yeah man go for something other than their product. They may be good engineers (I can't speak for if the product works in all cases) but they do not know how to run any sort of customer service. Just make sure to always check the return policies and you'll be fine.
Old 01-21-2016, 05:09 PM   #25
LaertesSon
LaertesSon's Avatar
But don't make this about the product, seriously. I'm sure it works great in most cases. It just didn't for me, and I got no sort of support from them when that happened.
Old 01-21-2016, 05:09 PM   #26
D_Thissen
D_Thissen's Avatar
Sorry to hear..
I would post this on their FB page. If they don't have the decency to return your calls or emails, screw 'em.
The Following 2 Users Say Thank You to D_Thissen For This Useful Post:
drewbot (01-21-2016), LaertesSon (01-21-2016)
Old 01-21-2016, 05:28 PM   #27
FRSBRZGT86FAN
Originally Posted by D_Thissen View Post
Sorry to hear..
Yea, I believe they got kicked off the vendors/sponsor list here because of there service and claims at some point. Also the dyno numbers for the block seem quite embellished, I was so sure of buying this but now I'm just gonna swing on some cnt uel headers, grimmspeed gaskets and a perrin pulley for the same money as the block and proven gains.
Even more important note they never say that the power is returned to the location of the torque dip or say that you'll lose power on the top end. I think there's a ROM tutorial available that keeps you from losing all that power up top
The Following 2 Users Say Thank You to FRSBRZGT86FAN For This Useful Post:
fumanchu1 (04-13-2016), LaertesSon (01-21-2016)
Old 01-21-2016, 05:39 PM   #28
LaertesSon
LaertesSon's Avatar
Thats a much better move. I would go back and do the same if I could.
Crawford Billet Power Blocks smbstyle Engine, Exhaust, Transmission 799 01-18-2016 06:01 PM
FS: Crawford Billet Power Blocks FRSH86 Engine, Exhaust, Bolt-Ons 17 09-21-2015 04:52 PM
Crawford Billet power blocks Triumphrider Engine, Exhaust, Transmission 0 08-01-2014 02:39 AM
Brand new Crawford Billet Power Blocks serial gixxer Engine, Exhaust, Bolt-Ons 1 07-19-2014 12:33 AM
Brand New Crawford Billet Power Blocks wawro569 Engine, Exhaust, Bolt-Ons 18 07-11-2014 03:06 AM
