Old 11-20-2015, 04:48 PM   #15
Martyr03
Drives: Scion FRS
Subbed. Looking to cage the car soon, and i only live an hour away.
Martyr03 is offline   Reply With Quote
The Following User Says Thank You to Martyr03 For This Useful Post:
GSpeed (11-20-2015)
Old 11-21-2015, 10:25 PM   #16
philooo
Drives: 13' Scion FRS Track car
As usual, I just love to see the iteration in the design and finally feel that more bars is bette
What about NODAL POINTS ?
Everybody is talking about nodal point for cages. My understanding is that it is a good thing to regroup tubes into 'nodal points':
instead of placing tube slightly at different places:
For example bars coming from the rear suspension and going on top of the main hoop should merge on the opposite side as the bar going from main hoop to the A pilar.
Did you run some analysis on what difference it make to have one meeting 'nodal point' instead of 2 meeting points, like the one you have in your design. Not sure how you call your purple dots in your rendering ?
I would say that I have seen it both ways, and I am still unclear as to what perform better.
I would assume the force would transfer better with a point with symmetrical contacts (1 purple point), but then an asymmetric design (2 purple points) could allow some more distortion in between the 2 points and prevent tube sheer. (pure speculation on my end
I hope I am not confusing everybody
philooo is offline   Reply With Quote
Old 11-22-2015, 09:49 AM   #17
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Correct. It's more structurally efficient to bring tubes together at one node, but occasionally (like we're doing) they don't meet at the same point for fitment reasons. That corner of the cage is pushed very tightly up into the roof of the car, and the A-pillar bar has to be moved outward a little bit to allow for the A-pillar bar to clear the chassis. If they were to meet at one node, the roll bar would have to be about 1.5" lower, which would also bring the A-pillar bar closer to the driver's head. Given our larger tube size, we can handle the slight shear loading put into the roll bar at that location. This is one of those things we're only able to do because we have a 3D scan of the car.
GSpeed is offline   Reply With Quote
The Following User Says Thank You to GSpeed For This Useful Post:
philooo (11-25-2015)
Old 11-29-2015, 09:00 PM   #18
OkieSnuffBox
Drives: '23 BRZ Limited
Originally Posted by GSpeed View Post
Don't worry, we're still planning on making bolt-in cages. Not going to lie, though, people will expect prices to be much cheaper than it'll wind up costing us. It happens in every corner of this industry, everyone wants parts that say, "Made in USA!" but they don't want to pay what it costs to make quality parts in low enough quantities to fill these niche markets. This (tracking 86/FRS/BRZs) is definitely a niche market.
The problem with that, is for some reason the vendors in this market seem to think the same material and labor should be worth 2-3x what they are for other vehicles.
Old 11-30-2015, 08:59 AM   #19
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Well sure, it's a problem of quantity. There just aren't as many interested buyers for this platform. It's a problem we all have to live with, and hopefully solve. If we can continue to push this platform as a cheap way to go fast on track, more people will buy them to modify, and prices will continue to fall.
Jake
JazzleSAURUS (11-30-2015)
Old 11-30-2015, 10:39 AM   #20
mrk1
Drives: Sterling BRZ Ltd
That "some reason" is called economy of scale. Prices will go down as demand increases and parts can be made in volume. Pretty standard pattern with a new platform. I own a manufacturing business and I would be hesitant to crank out a million parts for a new market, especially when the parts would rust on the shelf. GSpeed is really doing some awesome work here and seems to have the process abilities to back it up. I'm following progress for sure.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
The Following 2 Users Say Thank You to mrk1 For This Useful Post:
GSpeed (11-30-2015), Rosticles (11-30-2015)
Old 11-30-2015, 10:42 AM   #21
gatorbushmen
Amateur Drifter
gatorbushmen's Avatar
Drives: '13 FRS
subbed..... Definitely interested.
gatorbushmen is offline   Reply With Quote
Old 11-30-2015, 10:50 AM   #22
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
This is an awesome thread. Cage on.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
Old 12-02-2015, 09:46 PM   #23
plucas
plucas's Avatar
Drives: Subaru
Alright, let's do some analysis here. First off, let's get one big thing out of the way.
This is not a quantitative stiffness analysis.
We do not know enough about the torsional behavior of the vehicle to get a hard, reliable number for the torsional loads a vehicle experiences on track. So we're going to pick a reasonable number, and hold it constant through multiple tests and see how the results compare.
What this means is the numbers do not match up to the real world. They are only useful for comparing between tests.
First off, we'll apply 1000 ft-lbs to the rear four mounting points of the cage. These loads are evenly distributed between the points, but the points are not constrained to each other. They can move around naturally.
The front two mounting points will be fixed. We will measure displacement of the lower left roll cage mounting plate, and use that to calculate an angular deflection, which we can use to compare different configurations.
The first test is a simple 6-point cage with a crossed main hoop brace, a double crossed main hoop, and full length harness bar. This is the lightest, simplest cage design, and will be the starting point for this study.
Deflection- 2.49°
Stiffness- 402 lb-ft/deg
Weight- 99.5 lbs
Next, let's add FIA style door bars:
Wow. Okay, door bars really help torsional stiffness across the car.
Deflection- 0.47°
Stiffness- 2146.6 lb-ft/deg
Weight- 125.6 lbs
That's an improvement of over 400%. So we're definitely adding door bars. Now, let's add some beams between the bottom of the rear hoop and the rear shock mounts. These types of bars are common on flexy unibody cars.
Deflection- 0.43°
Stiffness- 2321.9 lb-ft/deg
Weight- 134.05
So for an additional 8.5 lbs we pick up another 8% stiffness. Not bad.
Many series allow two additional chassis points on the firewall to protect the driver's compartment from wheel intrusion in accidents. Let's add those and see how much stiffness they add.
Deflection- 0.36°
Stiffness- 2758.1 lb-ft/deg
Weight- 135.52 lbs
An extra 1.5 lbs (neglecting landing plates, of course), and we gain another 18%. Pretty good for the negligible weight, and considering they're really there for safety.
Now, what about the different between FIA bars and NASCAR bars? Everyone knows NASCAR bars are better at protecting the driver in broadside impacts since they arc out away from the driver, but how do they affect torsional stiffness?
Deflection- 0.30°
Stiffness- 3297.7lb-ft/deg
Weight- 145.02
So they weigh an extra ten pounds more than FIA bars, but they add almost 20% more torsional stiffness! Sounds like a good deal.
This sort of iterative analysis is a bit of insight into how we design. Torsional stiffness is just one of many things to consider when designing a cage, but you can see here why certain things are the way they are.
Jake
Can you get a better picture of how you are loading the cage? I thought I understood the wording, but the picture look different than what I expected.
plucas is offline   Reply With Quote
Old 12-03-2015, 10:16 AM   #24
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
In that last picture, the pink dotted line? That's the axis around which the torque is applied.
My graphics card is woefully underqualified for Solidworks, and I get a lot of strange glitches. One of which is Simulation's External Load indicators showing up inconsistently, incorrectly, or not at all. Functionally, it's there correctly, but it doesn't always show the visuals right.
Old 12-07-2015, 10:05 AM   #25
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
We're in the middle of moving our server to a new host, so our pictures will be down for a little bit. Sorry for the inconvenience.
Old 12-08-2015, 09:14 AM   #26
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Pictures back up! Thanks for being patient through this build, we're pushing hard on the Viper GTS build right now, and should resume work on the BRZ shortly.
Old 01-04-2016, 03:20 PM   #27
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Here's another update on the cage build.
The jungle gym of a rear cage:
Here's a shot of the harness bar offset, which allows for maximum seat room.
Door bars:
Although we won't be keeping them, it's possible to keep the factory glass windows installed, either for regulations or preference. We'll be removing ours, and making some brackets to fix the windows in a permanent upright position for transportation and storage.
Thanks for following this build! It's a slow winter for this car, but we're planning on doing some awesome things with this car when it warms up.
The Following 4 Users Say Thank You to GSpeed For This Useful Post:
DarkSunrise (01-15-2016), kch (01-04-2016), killboy (02-24-2016), mrk1 (01-04-2016)
Old 01-15-2016, 02:22 PM   #28
Iwannajag
Drives: 13 FR-S whiteout / blue w2w
Interested
Subscribed
Iwannajag is offline   Reply With Quote
GSpeed's 2015 BRZ- SCCA Super Touring Build GSpeed Member's Car Journals 380 10-31-2020 07:07 PM
Roll cage for a DD? Yamajee Suspension | Chassis | Brakes -- Sponsored by 949 Racing 42 08-10-2018 10:27 PM
Show us your Custom Roll Cage or Roll Bar and Harness Setup Black Tire Tracking / Autocross / HPDE / Drifting 27 02-13-2015 09:59 PM
Roll cage/bar Question Sulee417 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 45 05-03-2014 12:11 AM
Roll cage (Stealth Inc.) Suspension | Chassis | Brakes -- Sponsored by 949 Racing 37 12-16-2013 11:51 AM
