Old 10-25-2015, 04:55 PM   #15
kberkel
kberkel's Avatar
Originally Posted by ryoma View Post
nice! I was looking into sound deadening to improve the audio in the car. I have no prior knowledge about any of this so your write up was nice. have you also removed the sound tube in the engine bay? that will also reduce noise entering your cabin.
Yeah I removed the tube.. then I got a Top Speed Catback which is outrageously loud.
Usually I just bump music, but whenever I drive with passengers it always reminds me how loud the exhaust is.
They are always like.. "You drive this every day? "
kberkel is offline   Reply With Quote
Old 10-26-2015, 12:31 AM   #16
wootwoot
Drives: FRS
Why do the pieces you made look so much better than the crap I paid JP Coachworks to make for me?
Nice work!
wootwoot is offline   Reply With Quote
Old 10-26-2015, 12:44 AM   #17
GotBRZ1691
GotBRZ1691's Avatar
Drives: 2014 Subaru BRZ Limited 6smt
Damn dude I am quite impressed
Can we get a full interior picture? I want to see all the panels in place
GotBRZ1691 is offline   Reply With Quote
The Following User Says Thank You to GotBRZ1691 For This Useful Post:
DAEMANO (10-26-2015)
Old 10-26-2015, 12:14 PM   #18
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
In for more. Good looking work!
DustinS is offline   Reply With Quote
Old 10-26-2015, 12:20 PM   #19
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
Mad Skillz
LOLS2K is offline   Reply With Quote
Old 10-26-2015, 12:23 PM   #20
jayhoang
jayhoang's Avatar
Drives: 2014 Scion FRS
Sweet! Looks awesome.
http://www.lifewithjson.com
Instagram: jayhoang
jayhoang is offline   Reply With Quote
Old 10-26-2015, 12:46 PM   #21
adamg
Drives: brz
this is some amazing work
adamg is offline   Reply With Quote
Old 10-30-2015, 06:42 PM   #22
kberkel
kberkel's Avatar
Thanks guys!
Here is a little sewing trick that prevents me from crying when my cheap sewing machine messes up
Fixing Bad Stitches (jams, etc.)
- You can only do this if your holes are spaced evenly. If you short stitched or stitched crooked, those holes are permanent and you can't fix.
- Your thread will lose tension.. I usually tape my folds down before I top stitch, so I don't worry about about the material bulging back up
Here you can see my thread snagged, tension was way too high, I freed it, then kept sewing.
After you've spent hours on a part, there's no way you can just start over
So I cut on the dotted line (top and bottom thread)
Flip over, and pull up on the bobbin thread. This pulls the thread through.
Now.. start sewing right where the previous top stitch ends. Carefully make sure you use the exact holes.
You'll end up with this.
Now flip over.. and pull on the inner bobbin threads to pull the top stitch through
You'll get this.
And boom! Hard to tell you even messed up
I usually just glue down on the seam before I wrap and it is perfectly good.
The Following 2 Users Say Thank You to kberkel For This Useful Post:
aminninja (12-01-2015), DAEMANO (10-30-2015)
Old 10-30-2015, 06:58 PM   #23
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Great thread! Very inspiring! Please post some pics of the pieces you wrapped installed in your car. Thank you!
Old 10-31-2015, 01:16 AM   #24
kberkel
kberkel's Avatar
Thanks! I will soon, the car has been in pieces for a while. Ended up taking apart the center console to do the inner knee pads tonight.
Also still working on the door piece. The door piece is fighting me every step of the way. The fiberglass problems, the sewing problems. Ugh
It needs to be stretched, so some areas look bad when it's just laying there. It's hard to visualize, the alcantara will be cut to surround the armrest. Should turn out good though.
Old 10-31-2015, 01:23 AM   #25
kberkel
kberkel's Avatar
Inner Knee Pads
Sooo.. these were so easy to sew, but annoying to wrap.
Here you can see I made a simple template for the outer stitch.. tape it to the fabric, then taped around the edge.
Then I sew on the edge of the tape.
Didn't take many pictures. The top surface was easy, but it was meticulous cutting the edges to fit right.
Had some carbon fiber vinyl laying around.. so I wrapped the silver trim. Really happy with how these turned out
The Following User Says Thank You to kberkel For This Useful Post:
DAEMANO (10-31-2015)
Old 10-31-2015, 05:59 PM   #26
kberkel
kberkel's Avatar
Wrapped Shifter Surround
I rewrapped since my last one wasn't perfect and bubbled on one side. I forgot how completely annoying this thing is to wrap. It's also hard to hold while your wrapping so you don't keep touching the adhesive. I hope this is the last time.
Sooo.. cut to size:
Peel the backing off.. and lay over the top. Check to make sure your placement is good!
Press down the flat areas.
The outer curved part gave me tons of trouble.. For these problems, I usually lift up, apply a little heat, then use my fingers to push the creases outwards. I had to do this inch by inch, it took a while.
The worst part is over.
Getting the sides completely covered without creases.
Cut and wrapped around the back. Now time for the holes.
I continuously heat and push down to stretch the material. It has some spring-back when you apply heat again, but it stays partially stretched.
Generally there is not much worry for creases here.. just keep pushing downward to stretch it until it reaches the inner edge.
DONE!
frsvr4 (11-24-2015)
Old 11-22-2015, 12:03 AM   #27
kberkel
kberkel's Avatar
Some random updates.. things haven't been working out lately
Fiberglass Door-Panel Wrap
So.. I went to wrap the piece, and my skill level just wasn't up to par. Too many odd concave curves. You can see I glued some CCF to some sections. I saw this tip on TheHogRing.. if you've ever been in a modern cadillac, they have a similar feel. Firm, but not "fabric on plastic."
So, I cut off the entire outer portion.. so I would just have a fiberglass cover for the perforated center piece.
I refinished the entire perimeter. I made it PERFECT.
In the picture below.. it's not adhered to the door.. it would normally sit perfectly flush.
I wrapped it.. but ended up hating it. The cheap alcantara I bought just never looked good. So.. I scrapped the project all together
The wrapped speaker panels are enough uniqueness for me.
Sound Proofing
Nothing much to see here.
Just in case anyone wants to see how how I MLV/CCF'd the rear panels.
Wrapped Rear Arm Rests???
I was bored.. and the panels were sitting in my living room, so I thought.. what the hell, I'll try it.
Here's how I make patterns now. The tape method was OK, but posterboard is cheaper than tape and I don't have to transfer the 'tape patterns' into official patterns on posterboard. I can just mock these up, pull them off, and use them! I did this for the knee pads also.
I then top stitched it with red stitching.. but when I mocked it up, it just looked terrible, so I scrapped the project.
Cluster Hood Remake
I need to make extra money.. so now I'm mainstreaming some of my projects that work 100% of the time.
Gonna try a couple different versions and sell them. If anyone has any suggestions for designs, let me know! I am still not taking custom orders.. but I will entertain ideas and sell prototypes.
ollie (11-22-2015)
Old 11-22-2015, 01:11 AM   #28
Porcupint
Drives: 13 GBS BRZ
Just fair warning, be careful about selling stuff without a vendor account.
Porcupint is offline   Reply With Quote
R.I.P. Sprint car driver Kevin Ward Jr. hit by Tony Stewart Floggin Tires Off-Topic Lounge [WARNING: NO POLITICS] 89 08-08-2015 03:07 AM
Elite Eight: Kevin Ware of Louisville has his leg snap in half... (GRUESOME) Dizz1e Off-Topic Lounge [WARNING: NO POLITICS] 9 04-01-2013 08:42 PM
Kevin Brown Paul_S Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 03-20-2013 06:39 PM
OEM Upholstery ExWhyZer0 Cosmetic Modification (Interior/Exterior/Lighting) 9 12-25-2012 02:21 PM
Kevin's BRZ kgc Member's Car Journals 13 09-19-2012 03:39 PM
