Old 10-22-2015, 08:45 PM   #15
WhiteFRS69
WhiteFRS69's Avatar
Drives: 2014 Scion FRS
No corrosion in the socket or anything though?
none
Old 10-22-2015, 08:47 PM   #16
Originally Posted by WhiteFRS69 View Post
none
Then hard for them to say it was because of a cracked housing. Get one if you can but if not don't sweat it .
WhiteFRS69 (10-22-2015)
Old 10-22-2015, 09:57 PM   #17
WhiteFRS69
WhiteFRS69's Avatar
Now my windows are working. Think I messed up somewhere with fuses.
I'm working in the dark. But everything seems fine
Sent from my SM-N920T using Tapatalk
Old 10-23-2015, 11:33 AM   #18
WhiteFRS69
WhiteFRS69's Avatar
well did everything i could
got the windows working, just a bad fuse!
gonna replace all the LED's on the car with the stock Bulbs,
put the stock tail lights back on and call the dealer
The Following 2 Users Say Thank You to WhiteFRS69 For This Useful Post:
MisterSheep (10-23-2015), Tcoat (10-23-2015)
Old 10-23-2015, 11:36 AM   #19
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
In for updates. I'm personally considering aftermarket lights and I am afraid of something like this happening.
Instagram: trevor.parque
Tcoat (10-23-2015)
Old 10-23-2015, 02:04 PM   #20
WhiteFRS69
WhiteFRS69's Avatar
I gave up. Took it to the dealer. Playing the waiting game now
Sent from my Galaxy Note 5
Old 10-23-2015, 03:36 PM   #21
WhiteFRS69
WhiteFRS69's Avatar
Update 1: dealership has no idea what is causing it. Trying to blame it on my stereo system. I'm fighting it!
The Following User Says Thank You to WhiteFRS69 For This Useful Post:
Tcoat (10-23-2015)
Old 10-23-2015, 04:56 PM   #22
WhiteFRS69
WhiteFRS69's Avatar
update 2:
they called again, part wont be here till tuesday, claim it will most likely be warrantied,
not in the clear yet but its looking good
i forgot to ask what part they are replacing
Tcoat (10-23-2015)
Old 10-25-2015, 11:04 AM   #23
WhiteFRS69
WhiteFRS69's Avatar
update:
dealership called yesterday, part is on backorder, they dont know when they will be getting it in
i asked for a loaner.. they dont have any still
asked them to cover the Fee for a Rental... have to wait till monday to see if they will cover it.....
again!!!! i forgot to ask what part they are replacing! ill call monday and find out
contacted the company i bought my Tail lights from to see if i could swap them out for a new pair,
im afraid if i put the tail lights back on, i may be in this same situation
Old 10-28-2015, 09:38 AM   #24
WhiteFRS69
WhiteFRS69's Avatar
got the car back
it was my Brake light Switch
Part Number su00302490
could anyone tell me if that could have just been faulty? or caused from the tail lights ????
Old 10-28-2015, 11:20 AM   #25
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
I have no idea but OP, you also had LED bulbs for interior lights?
i remember my doom light did not work when door is opened after i switched to LED for while. it worked for while but one day, Boom! it did not work. BCU was damaged. ever since then, i don't use LEDs for interior. I only use LEDs on exterior light such as headlight,brake, license plate light, etc. I don't fully understand why LEDs causing it but didnt want to risk it again. anyway, glad you got the parts fixed under warranty!
Old 10-28-2015, 12:24 PM   #26
WhiteFRS69
WhiteFRS69's Avatar
yes i have Interior LED's
in the trunk and the dome light
been on the car for almost 2 years, just weird im seeing this problem now
now that ive had this problem, i may just stick to regular bulbs in the Interior
Old 10-28-2015, 01:07 PM   #27
86geek
86geek's Avatar
Drives: 2015 FRS Asphalt
I had a similar incident with LED bulbs.
I removed the dome LED, trunk & DRL bulbs before taking my car for it's first oil change. When I put them back in that's when my headlights would not go on. I had remembered reading another member had it's BCU fried because of the interior dome light. I can't remember specific details. I removed the LED dome & trunk bulbs and put the OEM bulbs back in. So far my headlights are fine now. Go figure huh.
Opti-Coat & Cquartz Finest, Apexi Drop in Filter, 2.5 Perrin Res. Catback Exhaust
86geek is offline   Reply With Quote
Old 10-28-2015, 02:24 PM   #28
WhiteFRS69
WhiteFRS69's Avatar
thanks for the input!
im going to swap back in the stock Bulbs
"LED Strip Daytime Running Lights and Valenti Tails --- Shipped Anywhere!!" F-T Exterior Parts - Lighting 169 08-20-2016 01:15 PM
SOLD -Valenti Tails and Valenti 3rd light (Smoked) / Wheelhaus' headliner brake light AtlasMick Exterior Parts (Aero, Lighting, Etc.) 8 03-07-2015 06:51 PM
New VALENTI TAIL LIGHTS. yes TAILS VakaGT Cosmetic Modification (Interior/Exterior/Lighting) 7 02-27-2015 03:59 PM
Valenti Fourth Brake Light With Stock Tails mackdaddytran Cosmetic Modification (Interior/Exterior/Lighting) 0 06-20-2014 11:03 AM
"LED Strip Daytime Running Lights and Valenti Tails --- Shipped Anywhere!!" F-T Exterior Parts - Lighting 187 05-15-2013 01:07 AM
