Old 10-21-2015, 05:10 PM   #15
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
And for the record:
Larger wheels (esp. lower offset wheels) tend to decrease the life of wheel bearings via increased load on them.
-alex
Old 10-21-2015, 05:24 PM   #16
stugray
Drives: 2013 GBS BRZ Limited
Look for tire rub marks could be right or left side.
Old 10-21-2015, 08:38 PM   #17
totopo
Drives: 370z
Originally Posted by mav1178 View Post
This is not a powertrain issue. Powertrain would be everything up to the axles, wheel bearings are under bumper-to-bumper warranty.
-alex
Powertrain Warranty
This warranty covers repairs needed to
correct defects in materials or
workmanship of any component listed
in the next two columns and supplied
by Scion, subject to the exceptions
indicated under “What Is Not Covered”
on pages 13-14.
Coverage is for 60 months or
60,000 miles, whichever occurs first.
Engine
Cylinder block and head and all
internal parts, timing gears and
gaskets, timing chain/belt and cover,
flywheel, valve covers, oil pan, oil
pump, engine mounts, turbocharger
housing and all internal parts, super
charger housing and all internal parts,
engine control computer, water pump,
fuel pump, seals and gaskets.
Transmission and Transaxle
Case and all internal parts, torque
converter, clutch cover, transmission
mounts, transfer case and all internal
parts, engine control computer, seals
and gaskets.
Front-Wheel-Drive System
Final drive housing and all internal
parts, axle shafts, drive shafts,
constant velocity joints, front hub and
bearings, seals and gaskets.
Rear-Wheel-Drive System
Axle housing and all internal parts,
propeller shafts, U-joints, axle shafts,
drive shafts, bearings, supports, seals
and gaskets.
https://www.scion.com/cm-pdf/warranty/2013/fr-s.pdf
of course:
WHAT IS NOT COVERED
This warranty does not cover damage
or failures resulting directly or
indirectly from any of the following:
Fire, accidents or theft
Abuse or negligence
Misuse — for example, racing or
overloading
Improper repairs
Alteration or tampering, including
installation of non-Scion Authorized
Accessories
Lack of or improper maintenance,
including use of fluids other than
those specified in the
Owner’s
Manual
Installation of non-Scion Authorized
Parts
Airborne chemicals, tree sap, road
debris (including stone chips), rail
dust, salt, hail, floods, wind storms,
lightning and other environmental
conditions
Water contamination
so OP: go look to see what your extended warranty covers. doesn't hurt to try, the dealer gets paid by scion so they may not care.
totopo is offline   Reply With Quote
The Following User Says Thank You to totopo For This Useful Post:
ravisraval (10-21-2015)
Old 10-21-2015, 08:45 PM   #18
mav1178
mav1178's Avatar
Originally Posted by totopo View Post
Front wheel bearings are not covered under the powertrain warranty.
Rear wheel bearings are covered under the powertrain warranty.
Given that OP has issues with the front passenger wheel bearing... yeah, it's not going to happen if that is the cause of the vibration and will be subject to the regular (or extended) warranty. And given the mods, they will deny it.
-alex
The Following User Says Thank You to mav1178 For This Useful Post:
totopo (10-21-2015)
Old 10-21-2015, 09:08 PM   #19
Ultramaroon
not playing cards
Ultramaroon's Avatar
-alex
Meh. It's just a wheel bearing.
Kuri (10-22-2015), ravisraval (10-21-2015)
Old 10-22-2015, 10:33 AM   #20
Kuri
Kuri's Avatar
Drives: 2014 BRZ Limited SWP
even so. It's not that hard to remove the front hub. At least it's not awd with the axle in the way
Kuri is offline   Reply With Quote
The Following User Says Thank You to Kuri For This Useful Post:
Ultramaroon (10-22-2015)
Beeping after ignition turns off.. chadstyle BRZ First-Gen (2012+) — General Topics 45 07-20-2020 02:53 PM
AC HVAC turns on randomly DarkestBuddha Electronics | Audio | NAV | Infotainment 0 06-28-2014 09:53 PM
Charging Phone Turns On Air-Bag onepremiere Issues | Warranty | Recalls / TSB 19 09-27-2013 03:23 AM
Switching the Turns and the DRLs, possible, or just too dang hard? VesperLynn BRZ First-Gen (2012+) — General Topics 3 08-18-2013 10:38 AM
Bluetooth turns on in driveway Pete156 Electronics | Audio | NAV | Infotainment 2 08-05-2013 01:12 AM
