Old 10-13-2015, 11:43 PM   #15
ScionOfHorus
ScionOfHorus's Avatar
Drives: 2015 Series.Blue BRZ
Also, is an injector/fuel pump upgraded needed if staying on 93?
ScionOfHorus is offline   Reply With Quote
Old 10-14-2015, 10:27 AM   #16
Mrc@ptuning
Mrc@ptuning's Avatar
Drives: S1000RR
We recommend our fueling package, which includes 850cc injectors, 4 bar map sensor and ecutek license.
http://www.ptuning.com/subdir/partno...=PTP-ENG-15005
You do not need to upgrade your fuel pump for 93 only injectors.
MrC
Mrc@ptuning is offline   Reply With Quote
Old 10-15-2015, 12:56 PM   #17
mkivsoopra
@Mrc@ptuning would the smaller turbo clear the stock sway bar?
mkivsoopra is offline   Reply With Quote
Old 10-15-2015, 01:04 PM   #18
Mrc@ptuning
Drives: S1000RR
No it will not.
MrC
Old 10-15-2015, 01:46 PM   #19
ScionOfHorus
MrC
Hmm, since I'm going full custom tune anyways I'll probably grab ID1000s and skip the basemap. Thanks for the info though
Old 10-27-2015, 09:41 AM   #20
Doug@PTUNING
Doug@PTUNING's Avatar
Drives: 1996 Honda Civic
Bump!
Doug@PTUNING is offline   Reply With Quote
Old 10-30-2015, 04:56 AM   #21
cookiesowns
Drives: WRB BRZ Series.Blue
Interesting. Any idea of turbo efficiency at around 8-10 PSI with similar boost curves the GT30 and GT28?
Want to see which turbo produces less heat. Assuming tuned similarly.
cookiesowns is offline   Reply With Quote
Old 10-30-2015, 04:11 PM   #22
Ken@PTuning
Drives: '92 Nissan 240sx KA-T
Send a message via AIM to Ken@PTuning
We haven't tested a GT28. Both the GT3076R and GTX2867R make around 325whp on our dyno with the same mods (the shop car). The GT30 will be more efficient than the GT28 when you start approaching the 400whp mark as you'll approach the limits of the GT28.
Ken@PTuning is offline   Reply With Quote
Old 10-30-2015, 10:37 PM   #23
cookiesowns
I was using GT28 and GT30 interchangeably with the GTX turbos you guys offer. . I have no plans of pushing over 400whp, at least on stock block.
Would the GTX2867R be a better turbo in that case? I rather not have massive amounts of torque down low.
Old 10-31-2015, 01:32 AM   #24
sw20kosh
Drives: 2013 Black FR-S
You won't have massive amounts of anything down low with either of these turbos. You are safe.
Old 11-05-2015, 05:32 PM   #25
Darryljr11
Sideways and Smiling!
Darryljr11's Avatar
Drives: Scion FR-S
Im considering trying out a GTX2971R or GTX2976R.
Element Tuning 10:1 Pro Comp Long Block, Ptuning SS GT3076R turbo kit, Exedy Stage 2 Clutch, and a bunch of other stuff
Darryljr11 is offline   Reply With Quote
Old 11-05-2015, 10:24 PM   #26
mjsivee
Drives: Scion FR-S
Is there an A/T version because i would make a drive up to you guys to get this bad boy installed?
mjsivee is offline   Reply With Quote
Old 11-06-2015, 09:48 AM   #27
Mrc@ptuning
Drives: S1000RR
You can never have enough torque down low If you are planning to run 300whp to 370whp for daily driving, autox, track days then the smaller GTX2867R is a very responsive turbo and spools up very fast compare to the GT30R, but if you have plans to build your engine and run over 400whp, the GTX2867R will run out of steam on the top end after 400whp. We love the spoolup and low end torque of the GTX2867R for daily driving and it will probably suit the majority of our customers, but for those with built engines and bigger hp goals, you will need to go with a larger turbo like the GT or GTX30R.
how about a GTX2871R, the GTX2867R spoolup and low end torque is great, just need a bit more top end which could probably be achieved with the 71mm vs 67mm compressor wheel. Haven't tried any of the GTX29R yet. but you could be the first
Sorry, our turbo system cannot be adapted for the A/T without a complete redesign of the turbo placement--currently no real demand for such a setup. The stock A/T bell housing is massive, which doesn't leave much room for a turbo or the 3" downpipe that's included in our turbo system.
Hint, swap to a M/T frs/brz
Old 11-06-2015, 01:21 PM   #28
Darryljr11
Darryljr11's Avatar
Drives: Scion FR-S
The GTX28 even with the biggest turbine housing will probably choke with my built motor. Might be the first to switch to the GTX29 this winter!
PTUNING: FR-S/BRZ/GT86 Spec-SS Turbo System (Now Shipping) ptuning Forced Induction 151 09-23-2016 10:48 AM
FS: BNIB JDL EL turbo kit, GTX2867R xwd Engine, Exhaust, Bolt-Ons 3 10-06-2014 11:16 AM
PTUNING: 501WHP 377WTQ 20psi Stock Motor PTUNING Spec-SS GTX3076R Turbo System ptuning Forced Induction 47 06-16-2014 03:52 PM
PTUNING: Adjustable Front License Plate Relocation Kit w/ Camera & Tow Hook Option ptuning Exterior Parts - The Rest 6 02-28-2014 11:21 AM
