#15 |
Drives: 2016 Toyota 4Runner Trail Premium
Pretty sure this is a wide double din and not a 1.5 din. People are putting in double din radios and adding kits to make up for the extra space on the sides.
| The Following User Says Thank You to sure74 For This Useful Post: | Spaceywilly (04-14-2013) |
#16 |
Drives: 2011 Civic Si
That's what I though. Like a 2.5 din :P
#17 |
Drives: 1986 AE86 GT-S, 2011 Lexus IS250 6M
Toyota pretty much never uses 1.5. They used to use standard 1 or 2 DIN, then switched to using 2 DIN mounting, but with a larger (mainly wider) face for it, which is what the FR-S/86 has. It is definitely not 1.5 DIN, and is larger than 2 DIN, but uses 2 DIN mounting bracketry (though with a different offset for the face as well).
Jeff
![]() 2011 Lexus IS350 F-Sport 6MT with LSD 1986 Toyota Corolla GT-S Supercharged |
#18 |
First 86 Driver Baby!
Drives: FR-S, Flex
It's a 2 DIN. DIN stands for Deutsche Industrie Norm, and references the height only, not the width.
#19 | |
Still it doesn't matter, since it is also taller than 2 DIN. Jeff
| The Following User Says Thank You to Jeff Lange For This Useful Post: | Fly Guy (06-23-2012) |
#20 |
Drives: FR-S, Flex
Correct, both have a width of 180 mm, with the only difference the height (1 DIN 50 mm, 2 DIN 100 mm).
#21 |
Right, but the factory radio is both taller and wider than a 2 DIN.
Jeff
#22 | |
~Hachi Roku~
Drives: 2013 Firestorm GT86 A/T
I work in Dubai as well, my 86 is scheduled for end of July(The wait is killing me!). So to pass this time I do stuff to keep me occupied. And last night I was looking at a similar Kenwood unit at E-max store (in Mirdif City Center). They had the following unit for AED 5400 and no clue how to install it or whether it includes GCC maps at all. I was so disappointed. ![]() I wouldn't mind knowing where you got your Kenwood unit from and for how much? Any separate installation charges? Please share. Thanks! |
#23 |
Drives: Toyota86, MX5, Jeep, FJ45, 59 Caddy
Yeah E-max are pretty poorly informed on the Kenwood products and they're not going to help you with installation.
I got mine from Yellowhat at Times Square - and while they can do the installation for you, I actually just did it myself. I've been modifying cars over the past 10 years, and before that I used to help my dad on his car projects, so I know what I'm doing The head unit was 2400 AED, the separate navigation ECU was 2800 AED. Antenna adaptor BAA44 I think was around 70 AED (but not sure). The head unit you showed is a standard double din meaning it is narrower so you will have to use an adapter kit and will have blank plastic parts on each side. Look in some other threads of people putting in custom head units and you will see... As for the pictures, they are displaying fine here. Try holding CTRL while pressing refresh. They are hosted on the same place as my other pictures so if you can see those, there's no reason to not see these.
![]() 2013 Toyota 86 - 2008 Mazda MX5 2001 Jeep Wrangler - 1982 FJ-45 Land Cruiser Pick-Up 1959 Cadillac Sedan DeVille |
#24 | |
~Hachi Roku~
Thanks for the info. I'm sure it will come in handy when I'm looking out to change my radio too.
#25 |
Drives: 2013 BRZ Limited
subscribed.
#26 |
Drives: '04 MR2 '10 MX5
I believe this is Alpine's attempt to do something similar: http://www.crutchfield.com/p_500INEZ....html?tp=20222
It mentions a bezel like most installs need, but I don't believe it requires spacers on the side of the opening and since it's being touted as bigger than usual it implies that it might natively fit openings like Toyota's |
#27 |
Doesn't fit the Scion TC's opening, which I think is the same as the FR-S(could be wrong)
#28 |
| BRZ Navigation Audio Run Through | F1point4 | Electronics | Audio | NAV | Infotainment | 84 | 10-14-2012 12:20 PM |
| 2013 FR-S - 1st inventory unit for Scott Clark Toyota Scion | sctcmediaman | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 05-23-2012 08:57 PM |
| BRZ Navigation System | Guaruja | BRZ First-Gen (2012+) — General Topics | 15 | 04-13-2012 09:52 AM |
| replace the Ford Navigation system? | megancheung | Electronics | Audio | NAV | Infotainment | 1 | 03-22-2012 03:51 AM |
| New Here (Navigation Option Question?) | Jokester | Scion FR-S / Toyota 86 GT86 General Forum | 36 | 02-19-2012 09:25 PM |
