Old 06-21-2012, 02:26 PM   #15
Mild2Wild
Drives: Firestorm FR-S
While we're on a tangent to bottom lips: Does anyone know of similar products available or in development for the FRS?
Mild2Wild is offline   Reply With Quote
Old 06-21-2012, 02:50 PM   #16
rcm47
rcm47's Avatar
Drives: 13’ FRS (traded), 18’ CWP BRZ tS
This is also what im waiting for.
rcm47 is offline   Reply With Quote
Old 06-21-2012, 02:59 PM   #17
RYU
RYU's Avatar
Drives: really slow...
loving this except for the vortex generators. i'd rather do w/o the wing too but it's not as offensive as the VGs.
RYU is offline   Reply With Quote
Old 06-21-2012, 05:05 PM   #18
Nardi330
Nardi330's Avatar
Drives: 86
Check the FB link I posted above. They have a prototype for FRS but its a bit bigger.
Nardi330 is offline   Reply With Quote
The Following User Says Thank You to Nardi330 For This Useful Post:
Mild2Wild (06-21-2012)
Old 06-21-2012, 07:38 PM   #19
Metabrz
001 of 012
Metabrz's Avatar
Drives: MY12 NZDM Subaru BRZ "BRZ001"
So, there is a lot of talk about staggered set ups creating understeer.
There are a lot of cars that are sold new with a staggered set up so surely this can tuned out with appropriate suspension work?
I really like the staggered look but my brz will be used on track quite a lot so its definititely function > form for me.
Any peeps got some guidance in this area? Thanks
BRZ001: Peace Love and Wheelies @metabrz on IG
Metabrz is offline   Reply With Quote
Old 06-21-2012, 07:59 PM   #20
Mild2Wild
Thanks for the heads up. I think it'll look better if black and not color matched like in the white prototype photo.
Old 06-21-2012, 08:28 PM   #21
RRnold
2 wheel member
RRnold's Avatar
Drives: JZA80, 997.1, Taco
That looks hella good!
Old 06-21-2012, 10:07 PM   #22
spiller
Drives: JZA70 Supra, Lancer Evo 5, 86 GTS
Whether the car understeers or not depends on what sort of tires you go for. If you over tire the rear of the car too much it will not only make you slower in a straight line but the extra grip at the rear will tend to cause the car to understeer if the front is not balanced out with equal amounts of grip. The best way to do this is with your wheel alingment - more negative camber at the front basically. Some people like to run toe out on the front to induce turn in but ive never been a fan of that. It messes with the feel of the steering.
spiller is offline   Reply With Quote
The Following User Says Thank You to spiller For This Useful Post:
Metabrz (06-22-2012)
Old 06-21-2012, 10:18 PM   #23
Starscream15
Starscream15's Avatar
Drives: 2013 Subaru BRZ - DGM
I just peed a little....again.
Could someone chop these pics to DGM?
Starscream15 is offline   Reply With Quote
The Following User Says Thank You to Starscream15 For This Useful Post:
TPO (06-21-2012)
Old 06-24-2012, 12:29 PM   #24
Mr 286
Mr 286's Avatar
Drives: 2014 Camry SE V6 | 1991 MR2 Turbo
So from the looks of the sizing chart, I'm guessing a custom order PCD was required for the rear wheels to come in that width/offset.
Mr 286 is offline   Reply With Quote
Old 06-24-2012, 01:55 PM   #25
ultra
Curious cat.
ultra's Avatar
Drives: 86 GT base M/T - Red
Bit of an oversimplification there. The OP's question was whether a staggered setup would induce additional understeer. The clear answer would be yes, due to the higher amount of grip at the rear of the car.
Could you tune the chassis to re-balance the car after adding wider rear tires? Using a combination of springs/dampers, sway bars and aggressive alignment settings you probably could, but that would involve a whole lot of work just to fix something that was intentionally 'broken' in the name of aesthetics.
If you have an abundance of power to break the rears loose and need wide rubber to contain them that's one thing but there's a reason that the hardcore track S2K and Miata guys tend to favour square setups.
Having said that, nobody's proven things one way or another through actual testing on these cars yet.
Just my 2c.
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold)
1991 Mazda MX5 Miata (sold)
2007 Mitsubishi Evo 9 RS (sold)
2006 VW Golf R32 (sold)
ultra is offline   Reply With Quote
Old 06-24-2012, 07:54 PM   #26
spiller
Just my 2c.
Thanks for posting pretty much the same thing but in different words. i'm sure the OP gets it now.
Old 06-24-2012, 10:59 PM   #27
Coastermikey
Drives: BRZ DGM
It doesn't look like +38 all around, the rears look to be less with its concavity
Coastermikey is offline   Reply With Quote
Old 06-25-2012, 01:35 PM   #28
ultra
Curious cat.
ultra's Avatar
Same team. :happy0180:
The staggered setup looks undoubtedly hot.
Wheel Directory: Work Emotion CR Ultimate "Kiwami" 18x9.5 +30 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 179 11-20-2015 12:12 AM
Wheel Directory: Work Emotion XD9 18x9.0 +38 / 18x10.0 +18 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 103 11-21-2013 03:28 AM
Work CR Kiwami/Ultimate danscar Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 34 09-11-2012 12:24 AM
WORK Emotion Kiwami - 18x8.5/9.5. Staggered For FRS/BRZ *** Available Now *** RavSpec Wheels and Tires 59 07-24-2012 12:07 PM
WORK Emotion Kiwami - 17x9.0 +38mm 5x100 *** BRZ/FRS Spec *** RavSpec Wheels and Tires 5 07-19-2012 06:44 PM
