#15 |
Drives: 2013 FRS, 2024 Trueno
I autox my car and its prob about 1.5" lower than stock. Ive got clicking noises coming from one axle. I got an extra from a wrecked car for like $50 shipped off ebay that is ready to go if I have one go out.
Yes. If you try to find the part number for the axles there is only one. Meaning they have to be symmetric.
![]() Last edited by Shneegle; 06-28-2017 at 06:46 PM. |
#16 |
Depending on the noise it could just be a worn out axle nut. Is it only on accel/decel or does it happen at other times? If it's the former I say spend $5 and try putting on a new axle nut, that fixed my clicking noise. iirc it popped up around 40k miles, I fully expect to have to replace them again before I hit 100k.
#17 | |
Time Traveller
I was running -1.6 rear -1.4 front and lost my drivers rear axle. $100 fix, no problem Switched to -1.4 rear - 1.2 front and lost another drivers rear axle (more violently this time.) $100 to fix as well as my ring and pinion got hosed in the process and various seals ($1200 later, I'm back on the road) Now at -1.2 rear and 1.0 front and have been happy as a clam running hard for 10k miles. Unless adding differential spacers, I would not again run this car lower than -1.2 hard for any amount of time. |
#18 | |
Time Traveller
#19 | |
Time Traveller
#20 | |
I know it will fail eventually and have parts ready to go when it does. The 1.5 is also a guesstimate. About to change to a set of AST 5200's so the height could change soon.
#21 | |
Time Traveller
Point is, when the axle pops, it can damage other parts attached to it (wheel hubs and parts in your differential.) In my case, the second time I lost an axle it also took my ring & pinion (final drive.) Total cost on that was $1400. |
#22 |
Drives: 2013 Raven FR-S
Reading that really freaked me out. I'm currently lowered -1.5" in the back and I'm thinking I might raise it back up 1/4" to be safe.
#23 |
Drives: Subaru BRZ
Coming from an S2000 where the forum gurus have recommended tightening the rear axle nut beyond the factory spec, I wonder if tightening the rear axle nuts will alleviate the issue?
https://www.s2ki.com/forums/s2000-un...sb-diy-929843/ |
#24 |
Time Traveller
Recommended. When I raised mine back up to its' current height, I thought it would bother me. Turns out I can't even see the the height anymore and I appreciate that the suspension has just that much more travel.
#25 | |
Time Traveller
#26 |
Drives: Subaru BRZ
Daemano - thanks for the insight. Where can I find information on how much to tighten the rear axle nuts and to what spec? The BRZ is now my track car and I'm in the process of learning to drive it. I still have my S2000 and use that primarily for autocross.
At this time I have no plans of lowering the BRZ. Want to run it in stock class in the Northeast 86 Cup. Over the winter I'll start thinking about adding a bit of camber. |
#27 |
What are your measurements at the pinch welds? I think my rear fenders are uneven, so that might give me a better idea where to set it.
#28 | |
Time Traveller
Got the spec from the factory service manual located here (big download, but a must for any owner.) http://www.ft86club.com/forums/showthread.php?t=8374 |
| WTB: DSS 600hp rear axles | SterlingBrz | Want-To-Buy Requests | 1 | 03-17-2015 08:49 PM |
| should i upgrade axles? | Frs300 | Engine, Exhaust, Transmission | 16 | 07-01-2013 11:00 PM |
