Old 07-15-2015, 02:24 PM   #15
sprintertrueno86
sprintertrueno86's Avatar
Drives: 2018 BMW M2
Try pushing in that a/c funnel. Maybe it's getting caught to it when you push the trim piece in making it not snap in place.
sprintertrueno86 is offline   Reply With Quote
Old 07-15-2015, 02:33 PM   #16
86Hiro
It gets installed as one whole piece though....Trim ting on the vent housing tunnel and then snaps into place....suppose to anyways
86Hiro is offline   Reply With Quote
Old 07-15-2015, 03:40 PM   #17
Shady195
Drives: '13 10 Series FRS #1203
I apologize I was speaking only of the trim piece not the entire vent. I have not removed the whole vent assembly like that.
Shady195 is offline   Reply With Quote
Old 07-15-2015, 03:47 PM   #18
Originally Posted by 86Hiro View Post
Would anyone like to volunteer to show their drivers side vent opening to make sure mine isn't broke somewhere?
Not gonna pull it off when you can't get it back on but I have the parts and service manual at home I will take a look and see if it goes into that sort of detail.
Old 07-15-2015, 03:50 PM   #19
NWFRS
NWFRS's Avatar
Drives: ‘13 FRS
Things used to be so simple...I remember when all of my car's interiors were assembled at the factory with TEK screws...
On a serious note. Plastic is fussy. Just get comfortable, maybe with a cup of coffee, get some really good light and just stare at it for a while. That's what I do. I always find the trick-or the damaged part eventually...
NWFRS is offline   Reply With Quote
Old 07-15-2015, 03:56 PM   #20
Hell they used to have slot screws.
NWFRS (07-15-2015)
Old 07-15-2015, 03:59 PM   #21
projek_01
projek_01's Avatar
Drives: 1996 ST204, Series 10 FR-S
I think you have the rotation wrong. I recall the thicker side facing left and the thinner facing closer to the mirror. Turn it around and try again in different angles.
projek_01 is offline   Reply With Quote
Old 07-15-2015, 05:04 PM   #22
86Hiro
A/C Vent Not Snapping in.....
The passenger side trim ring bezel is the only one that has a thick and thin side to it. The drivers side is symmetrical all the way around. Correct me if Im wrong here
Old 07-15-2015, 05:22 PM   #23
Husker BRZ
Go Big Red!!
Drives: 2013 SSM BRZ Limited
So out of curiosity, why did you pull both pieces off? You can just pull the vent ring off without removing all of it... All I did was pop the vent ring off, wrap it, and pop it right back on.
Husker BRZ is offline   Reply With Quote
Old 07-15-2015, 05:30 PM   #24
86Hiro
Because I didn't want to break a tab off the trim ring, or bend the edges. But that leads me to this now haha
Old 07-15-2015, 05:35 PM   #25
Husker BRZ
Go Big Red!!
Yeah I actually broke one of those tabs but since there is like 4-5 of them it still snaps on and stays perfectly fine thankfully! Hopefully you're able to get it figured out!
Old 07-15-2015, 05:36 PM   #26
86Hiro
Im sure Im overlooking something or....something. I'll give progress updates for sure
Old 07-15-2015, 06:13 PM   #27
86Hiro
Okay so after cursing a few times, and getting mentally frustrated over and over, I tried pushing in a little harder and the tab that is exposed in the pics above, snaps in, and when I let go, it comes out.......What the fudge?!? The tab is clearly unharmed, and the edge of where it snaps onto isn't bent or broken....The fuh!!
Old 07-15-2015, 06:23 PM   #28
Tromatic
Try a little WD40. Being a snap-tite car, most of those pieces have a maximum limit regarding how many times they can be removed without failing, which is about once.
Tromatic is offline   Reply With Quote
WTT: my Raven frs fender vent for BRZ fender vent VakaGT Exterior Parts (Aero, Lighting, Etc.) 2 11-13-2014 02:56 AM
WTT FR-S fender vent for BRZ fender vent (white) Anthony Exterior Parts (Aero, Lighting, Etc.) 8 12-02-2013 07:52 PM
WTT: My Asphalt fender vent covers for your DGM BRZ fender vent covers SkAsphalt Canada Classifieds 0 10-07-2013 01:25 PM
TRADE: FT86 Fender Vent for BRZ Fender Vent xia Exterior Parts (Aero, Lighting, Etc.) 0 10-04-2013 09:56 PM
hot air thru vent boonFRS Issues | Warranty | Recalls / TSB 28 09-13-2012 12:35 PM
