Old 07-07-2015, 03:37 AM   #15
steve99
Originally Posted by cookiesowns View Post
Are we able to log more than 12 params now? Or is the 12 param limit still present?
That would suck, as I want to log what I'm logging now, combined with the new body parameters.
I would GLADLY trade logging time for more parameters.
Reading shiv,s post it appears you will be able to do both at same time
the current parameters all come from ecu vie direct reeading of ecu ram addresses.
the new driving parameters are derived from the stability control and abs modules likely via reading data off can buss ie a differnt mode of request so its likely it can be done concurrently.
Old 07-07-2015, 12:15 PM   #16
sirsol66
Drives: 2013 FRS- Hot Lava
Shiv is there any progress for being able to check/clear chassis error codes (i.e. speed sensor warnings?)
sirsol66 is offline   Reply With Quote
Old 07-08-2015, 11:22 AM   #17
Tromatic
Way cool.
Tromatic is offline   Reply With Quote
Old 07-08-2015, 11:50 AM   #18
Teseo
Drives: frs
This will be an excellent tool for compare suspensions components like coilovers etc
Old 07-08-2015, 12:27 PM   #19
Tectoniic
#FiftyShadesOfBlue
Tectoniic's Avatar
Drives: 2015 FR-S
and the ROI on the OFT keeps getting better!!
Engine/Exhaust: OFT w/ E85 Tune | FT86SF Catted UEL | Invidia Q300 Catback
Wheels/Tires/Suspension: Avid.1 AV-20 18x8.5 +33 w/ 245/35/18 PSS | RCE Yellow Springs | Velox LCAs
Cosmetic: Valenti FT86SF Special Edition Tails | Diode Dynamics Full HID/LEDs | BRZ Fender Garnishes
Tectoniic is offline   Reply With Quote
Old 07-08-2015, 02:03 PM   #20
Rybot
Rybot's Avatar
Drives: Subaru BRZ Series.Blue
This is gonna be fun to see!
I assume we can just add the data stream to the current UI we have for monitoring?
Rybot is offline   Reply With Quote
Old 07-09-2015, 12:44 AM   #21
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
You will be able to log up to 14 channels simutaneously. And you can view any combination of channels (old and new). The 14 channel limit is somewhat arbitrary and is based upon hoe many channels we can clearly display on the screen at the same time.
Old 07-09-2015, 12:46 AM   #22
Shiv@Openflash
Drives: 2013 FRS
I can look into like this. When do you feel speed sensor codes? I only see them on the Dyno and they clear as soon as you drive on the street.
Old 07-09-2015, 12:50 AM   #23
Shiv@Openflash
Drives: 2013 FRS
Originally Posted by Thorpedo View Post
Man oh man, I wasn't expecting this with all the other development you are doing on different platforms. Please Shiv, do your best to have this out in the time frame you mentioned. I only have so munch summer up here in snowville.
THANK YOU.
Contrary to popular believes, developing new features on other platforms doesn't limit development on this platform. In fact all these new features will be ported into the other supported vehicles. In this particular case, we decided to use the gt86 as the test bed. We could have just as easily used the Porsche, Mx5, Fiat, etc but i like my little turbo FRS so much that testing things like this is a blast
Old 07-09-2015, 12:57 AM   #24
steve99
The Android Torque app will clear all CEL codes from BCM and auto trans like the dreaded P0700 so you should be able to sniff the obd command sent by Torque or other OBD scanner and copy to OFT
It also reads those codes so could probabbly mod oft to read all cel codes to
Old 07-09-2015, 01:00 AM   #25
Shiv@Openflash
Drives: 2013 FRS
Sounds like a plan
Old 07-09-2015, 01:15 AM   #26
Tromatic
I just wish the tablet was way bigger and wireless!
Old 07-09-2015, 01:26 AM   #27
jupillam
jupillam's Avatar
Drives: White out Scion Frs
can we adjust steering angle?
jupillam is offline   Reply With Quote
Old 07-09-2015, 11:13 AM   #28
burdickjp
Drives: 2013 ultramarine Scion FR-S
What logging rate are you getting with this data?
burdickjp is offline   Reply With Quote
OpenFlash Tablet will not connect to OpenFlash Manager rever5e Software Tuning 10 03-12-2022 10:17 AM
FS: New OpenFlash Tablet, OpenFlash Header, Perrin Filter, Perrin Antenna FT86POWER Engine, Exhaust, Bolt-Ons 12 05-01-2015 10:39 PM
FS: Brand New Openflash Header AND Openflash Tablet combo FT86POWER Engine, Exhaust, Bolt-Ons 6 02-11-2015 02:56 PM
Openflash Tablet + Openflash Header smellslikecurry Engine, Exhaust, Bolt-Ons 9 12-01-2014 06:20 PM
Expert Review: Plug-and-Play performance for the FRS/BRZ with Vishnu Openflash Tablet ModBargains.com Software Tuning 82 07-25-2014 07:06 AM
