Old 07-16-2012, 12:22 PM   #15
Memphis
Memphis's Avatar
Drives: Scion FantasticRoad-Sex
Have any of you tried launching your auto? It bogs down before it decides to get up and go. I am talking with nannies on/off or any combination. Its like it lugs all the way up to a certain range in the RPM. My friends manual does not experience this which is expected.
Is this what the OP is talking about?
Memphis is offline   Reply With Quote
Old 07-16-2012, 01:03 PM   #16
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Is this with the brake fully depressed? Toyota has a safety feature where it won't rev passed 2k with the brake fully in. Only problem is the car moves without stickier tires.
Or if you talking about a neutral drop then yeah, that doesn't work. You need to get around 90$%on the brakes in drive to launch. But like I said, with sticky tires the car still rolls a bit
Old 07-16-2012, 01:20 PM   #17
Memphis
Memphis's Avatar
Yea it is fully depressed because of what you mentioned. I can sit and spin the tires but anymore pressure on the brake and its a no go :p
Whats 90% to you?
Old 07-18-2012, 04:27 AM   #18
finch1750
finch1750's Avatar
Whats 90% to you?
A little less than 100. Lol. IDK really. I just put it down all the way and let off very very slowly to find the sweet spot
Old 07-18-2012, 05:27 AM   #19
Echo
Drives: Scion FR-S. Black.
Please explain to me how a launch is performed... I'm very curious as to how to pull this off in an auto.
Echo is offline   Reply With Quote
Old 07-18-2012, 07:06 AM   #20
Tylub
Tylub's Avatar
Drives: Raven Black FR-S
I am interested in this technique as well
Tylub is offline   Reply With Quote
Old 07-24-2012, 09:54 PM   #21
Cadenz
Drives: Subaru BRZ SWP Limited 2013
Originally Posted by mechaghost View Post
I have not hit any lag on the Auto. It does however get confused going on a steep and windy hill on low speed. It will keep the revs at 1500 rpm and will hesitate to downshift if I keep it a certain speed (which happens to be around 15-20mph due to up hill traffic) However I do just tap paddle shifters to kick it down or push more on the accelerator.
Other than that, the AT is a champ!
I've experienced this too. I live on a steep hill with speed bumps. In sport mode, every time I slow for the speed bumps, it will not downshift to keep moving but instead gets bogged down around 1500, until I really put excessive input on the throttle. Just been resorting to paddle control on my hill like some of you have been doing; though at first I thought something was buggy with the shift logic. Maybe tomorrow I'll see if going up the steep hill in normal mode fixes this error.
Cadenz is offline   Reply With Quote
Old 07-25-2012, 04:01 PM   #22
ahausheer
Re-member
Drives: Toyota camry
That lag I am wondering about plagues many Toyotas, Lexus, and many other modern vehicles. It happens when you are decelerating to around 20 mph, say for an upcoming turn, then you go to hit the gas and there is a delay between peddle input and acceleration which can cause a sudden jerk as the gears finally engage. Toyota actually had an ECU update TSB (for my model) about this but it did little good.
I have this issue in my car (04 Solara v6) and have been looking into it for a long time. The best theory I have seen is that the shift logic is such that the car, when decelerating, will stay in to high a gear to avoid engine braking thus increasing mpg. When you go to hit the gas the car needs to downshift which for some reason takes longer than it should. It is precisely the downshift hesitation that I am worried about as it can be a real pain. I also wonder if it has something to do with the Stator in the torque converter but that is just an idea.
Do any others with the auto have this ''downshift hesitation'', delay between peddle input and acceleration, or jerkiness, particularly when resuming acceleration immediately after moderate deceleration?
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
Old 07-25-2012, 05:21 PM   #23
hav0c
hav0c's Avatar
Drives: WRB BRZ Limited (AT)
Haven't had any issues. It's gotten even more peppy after break-in (about 2500miles right now).
hav0c is offline   Reply With Quote
Subaru BRZ 6 Speed Auto Official 0-60 testing!!! SUB-FT86 BRZ First-Gen (2012+) — General Topics 1 06-14-2012 11:39 AM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
Throttle Blip, and other features? ashtray BRZ First-Gen (2012+) — General Topics 39 03-07-2012 10:52 AM
