Old 06-15-2015, 06:12 PM   #15
Shinobu's Smile
Drives: 2010 Tacoma, 2015 BRZ AT Limited
Originally Posted by kch View Post
Make sure to update your template file, which is separate from the firmware. That's probably what's causing your wonky readings.
I was running 7.1 with the Adv Multiplier of 0. I noticed they released 7.2 less than a month ago so Ill see if it fixes this. Thanks.
On a separate note, there's no XML file for the D00D cal ID for editing the ROMS or am I just misunderstanding how to do this?
Shinobu's Smile is offline   Reply With Quote
Old 06-15-2015, 06:31 PM   #16
kch
Senior Misanthrope
kch's Avatar
I don't remember details (first time, rushed through it), but I know I edited my D00 rom with romraider a while back, so I guess there have to be XMLs out there somewhere.
Old 06-16-2015, 04:53 PM   #17
Shinobu's Smile
Originally Posted by elBarto View Post
Update the template file, fixes most of those issues.
Download it here
No Dice.
I updated the template file to 7.2 and still no numbers (just 0) for Adv. Multiplier, or Knock Correction. FLKC is either 100, -100, or -5. Is it possible im not recording one of the channels that is necessary for the Adv. Multiplier calculation? (I have it set up for engine speed, throttle, MAF Volt, Engine Load, VVT Intake, VVT Exh, Ignition Adv, KC Learned, AFR, ST Fuel Trim, LT Fuel Trim, Adv Multiplier, Knock Corr, and FLKC, Am i missing something necessary)?
Sorry @FRSwag2014 if i thread-jacked you but i suppose it is pertinent to OFT compatibility with 2015's (AT in my case)...or me just being a goofball.
OFManager - v1.20.0
Template File - 7.2
HW - 01.00
FW - 01.33
Old 06-16-2015, 06:31 PM   #18
steve99
No Dice.
OFManager - v1.20.0
Template File - 7.2
HW - 01.00
FW - 01.33
Thats an issue with oft logging contact the oft guys by email or phone with your rom id .
Old 06-18-2015, 12:08 PM   #19
FRSwag2014
FRSwag2014's Avatar
Drives: 2015 BRZ Limited CWP
Send a message via AIM to FRSwag2014
Shiv got back to me. I was good. Flashed and running fine
FRSwag2014 is offline   Reply With Quote
Old 06-19-2015, 08:11 AM   #20
Shinobu's Smile
Did you PM, call, or email him through OFT site? Cause I have pm'ed and emailed him to no avail.
Old 06-24-2015, 06:01 PM   #21
efactor84
efactor84's Avatar
Drives: 2015 Scion FR-S
Be nice if they have the D00D files for the 2015 FRS from RomRaider. I can't really do anything for editing, unless someone can correct me on this. I'm running the version 2.067 with no issues, but want to get into Rom editing for the fun of it.
efactor84 is offline   Reply With Quote
Old 06-24-2015, 07:30 PM   #22
Shinobu's Smile
Yup. Glad im not the only one. Does yours properly log "Adv Multiplier"? Mine just reports 0.
Old 06-24-2015, 08:50 PM   #23
efactor84
efactor84's Avatar
Not sure, I'll keep you updated. What is significant about it?
Old 06-25-2015, 09:17 AM   #24
Shinobu's Smile
Its necessary in determining if there is any knock present. Its probably very needed if you ever want to customize your tune, at least from what I gather (im new at this)
Old 06-26-2015, 06:30 PM   #25
efactor84
efactor84's Avatar
Checked mine recently and mine does say "0" too.
Old 06-27-2015, 09:50 AM   #26
Shinobu's Smile
I contacted them via their sales email to troubleshoot. They seem to think that I'm using bad gas and that there's knock present but I'm trying to insist that the number should fluctuate if thats the case and that I have used multiple brands of gas (always 93oct) and forwarded a couple of my logs. Ill keep you all posted with what they find when/if they get back to me.
Old 06-27-2015, 07:10 PM   #27
cookiesowns
Drives: WRB BRZ Series.Blue
I'm on D00C STG1 with my own tweaks, and all parameters log fine for me.
I would flash back to stock, wipe the OFT, and update w/ template to see if it fixes.
However, I still feel the D00C STG1 tune on the AVCS are too aggressive, makes the motor sound very angry at 3800-4500rpm under part-throttle.
cookiesowns is offline   Reply With Quote
Old 06-30-2015, 02:45 PM   #28
Shinobu's Smile
I just got an email back from the OFT people and they said there was a "small logging bug" with the 15AT model year and it should be fixed with the next update.
@efactor84
@Vroomin86
Tomei Expreme Ti Test Pipe Titanium 80mm Subaru BRZ 2013-2015 / Scion FR-S 2013-2015 RallySport Direct Engine, Exhaust, Bolt-Ons 1 06-15-2015 11:45 AM
2015 wrx vs 2015 gti vs ford focus st best all around dd and autocross jflogerzi Other Vehicles & General Automotive Discussions 13 05-25-2015 08:33 PM
2015 Formula Drift Tech Day - 3/28/2015 yospeed Southern California 1 03-05-2015 03:10 PM
Aside from 2015 Acura NSX and Toyota Supra, what else in 2015? stockysnail Northwest 7 01-13-2015 02:30 AM
Nissan to enter 2015 24 Hours of Le Mans + 2015 FIA WEC mav1178 Other Vehicles & General Automotive Discussions 1 05-23-2014 10:47 PM
