#15 |
Drives: GT86 - minor mods
I'm stock and running Bardahl 0W30, can't be more happy, oil keeps at normal temp and doesn't go 120 degrees C(248F) any more during fun time or slow traffic. So i would recommend 0W40 for FI, even 0W50 from ENEOS if accessible in any way, 0w50 is LFA's stock engine oil :P
Of course there's this cold crank oil pressure debate, but in a long run - everybody should decide on their own, if they travel by 1/4th of a mile a time or like running 1,5h drift sessions
#16 |
Drives: 10 series FRS
Mobil 1 0w-40 European formula.
#17 |
Drives: Nevermorange FRS
Only since the OP used the words "prohibitively expensive" I'm going to repeat what others have said:
The Mobil 1 0w-40 Euro oil is very good along with the Amsoil 0w-40 signature. Google either one with the "UOA" and "VOA" in the search string to see their specs both new and used. The HTHS, TBN and additives are right in line with what you're looking for: Affordability, protection level, duration and cost.
PRO86 | STL | LuckyDog
#18 |
Drives: FR-S TRD RS1#1488
Anyone using Rotella T6 5w40? I used to use it in my STi and have been thinking of switching out from the 0w20 i've using right now.
*it'll help if i mentioned that i'm on FI too
#19 | |
Pros: Cheap, good additives for Diesel and DI engines. Cons: Extra wear on startup. Anecdotal: I tried it for a race weekend this year because I like to try new things from time to time and toward the end the of the day I watched the pressure fall (temp static) which suggests shearing and by the end of the weekend I consistently running 5-10 psi less than I was when I started the weekend. So I did some digging and kept finding an underlying theme about how this oil shears down at high rpm becoming more like a 30wt which would explain what I experienced. I replaced the oil with Mobil1 0w-40 for the following event and did a 6 entry race weekend with over 6 hours of race time and the pressure stayed the same throughout the weekend (which is what I'm used to). So no more Rotella T6 for me in the race car. With that being said.. If 90% of engine wear occurs at startup, I'd want to run an 0w-xx for something that's also DD. If it's only tracked or is a dedicated race car then startup wear isn't as important.
#20 | |
| Headunit recommend | boxan59 | Electronics | Audio | NAV | Infotainment | 1 | 03-28-2015 06:29 AM |
| Can you recommend me what to mod next? | l0aded | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 08-21-2014 12:40 AM |
| What tires would you recommend? | Ludacrits | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 18 | 06-22-2013 10:12 AM |
| To BRZ Owners - Would you recommend BRZ? | Z_Rocks | BRZ First-Gen (2012+) — General Topics | 40 | 06-18-2013 12:32 AM |
| What shocks would you recommend? | CaptainSlow | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 01-31-2013 02:18 PM |
