Old 05-26-2015, 07:16 PM   #15
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
I know nothing about starters, but could this be somehow related to the vehicles immobilization feature? Like it doesn't recognize this as the same engine, so there's no handshake when the key is turned and thus it refuses to initialize/power up the starter?
Originally Posted by humfrz
I'm old and lazy
Old 05-26-2015, 07:36 PM   #16
mad_sb
Drives: 2013 Asphalt FR-S
Originally Posted by protpibe View Post
I've already checked if the engine is seized
The starter motor *does not* spin when it is connected to the vehicles electrical system, both INSTALLED and NOT INSTALLED into the engine block. It does spin when I remove it from the vehicle and test it with a battery charger.
I've put the car in higher gear and pushed it in my garage and heard the engine turn. It is not seized.
My first thought was immobilizer, but you kept your original ECU, DI driver box, etc right? I didn't think you would need to recode anything if you kept your original electrics.
Did you try your other key by chance? Wondering if it could be the battery in the keyfob.... Do you have anyway to pull codes or is the dash throwing any lights when you try to turn the key??
Old 05-26-2015, 08:23 PM   #17
protpibe
protpibe's Avatar
Yeah I kept my existing ecu/fuel computer, etc. I have a CAFI Dashlinq with torque in dash, I'll check to see if there are any codes. I'll also try a spare key.. coudln't hurt, right?
I've been at work all day long and have been looking over some wiring diagrams. Even though the grounds LOOK fine, I think they may be the culprit.
Old 05-27-2015, 11:14 AM   #18
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
Just two ground straps under the motor to the frame rails. The rest is all plug and play harness stuff. Is your injector ecu bolted down to its bracket on the passenger side head or do you just have it laying there for testing? It needs to be grounded or the car won't start
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
Old 05-27-2015, 04:34 PM   #19
NOHOME
Drives: RAVEN
I am thinking bad solenoid.
You have not checked power at the starter while attempting to crank.
Put a voltmeter on the starter power lug. The one with the braid on it.
Turn the key.
Tell me what the voltage at the lug is when the key is turned to the crank position.
It should be around 12 volts.
What you are really checking for is current: if there is not enough current, it wont maintain the 12 volts.
You can also monitor the voltage on the input side of the solenoid. There should be 14 volts before you turn the key and it should drop when you do turn the key.
If you have a clamp on current meter that can handle 100 amps or so, then you could use that instead.
My guess is a bad solenoid. When you actuated the starter on the bench, did you do it by jumping the power to the lug with the braid or did you do it by attaching the jumper cable to the input lug and then use a small jumper to actuate the solenoid.
NOHOME is offline   Reply With Quote
Old 05-29-2015, 06:25 PM   #20
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
+1 on solenoid.
1 other thing to try to isolate the starter issue... Have you tried to roll or tow start the car? Assuming it's a manual.
Spartarus is offline   Reply With Quote
Old 05-30-2015, 08:17 PM   #21
zkv476
zkv476's Avatar
Drives: 2014 SWP BRZ, MT
I'd place my money on the solenoid.
For reference here's a random pic of our starter.
The little spade connector triggers the solenoid. The bottom copper stud connects straight to the battery. The top stud with the wire goes to the motor. I'm assuming if you jump directly to the upper terminal you can get the motor to spin. Use a voltmeter and probe the pole going to the motor and attempt a crank. If you get no power coming out of the starter side of the solenoid, the solenoid is bad.
The answer is racecar. Always.
zkv476 is offline   Reply With Quote
Old 05-30-2015, 08:21 PM   #22
wutsaiu
wutsaiu's Avatar
Drives: 2015 Raven V8
wutsaiu is offline   Reply With Quote
Old 05-31-2015, 12:04 AM   #23
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by wutsaiu View Post
LOL
Old 05-31-2015, 12:42 AM   #24
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
...tom cruise, awkwardly specific to the rescue
Old 06-01-2015, 12:01 AM   #25
killercl0wnfish
Drives: fr-s
i have a fa20 starter ill sale just pm me, came off a motor with 14k miles did a swap so no need in it..
killercl0wnfish is offline   Reply With Quote
Starting issue? winsometang Issues | Warranty | Recalls / TSB 7 11-26-2014 05:25 PM
Bucket Seats on a Budget - Full Bucket & Reclinable - Starting at $190 - Sonic Motor Sonic Motor Interior Parts (Incl. Lighting) 117 08-29-2014 08:32 PM
Starting issue Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 33 08-15-2013 07:40 AM
Van starting issue-need advice. LivingLegend Off-Topic Lounge [WARNING: NO POLITICS] 3 01-15-2013 10:48 PM
Motor Trend, August issue. 1660 Scion FR-S / Toyota 86 GT86 General Forum 216 08-02-2011 06:43 PM
