Old 09-15-2015, 01:29 AM   #15
j_motion
Drives: 14 BRZ Red premium
Originally Posted by DJCarbine View Post
I did end up having to shave about 2mm from the bezel where it was contacting the android unit. The bezel would snap on, but look pushed out slightly
Ya ..im glad i didnt try to force it in.
Thx for the guide for the repin for the front door speaker.
I have the OEM Kicker sub, was worrying if the sub harness change some configuration.
But after re pin it work out pretty well. no problem at all.
BTY did you get the OBD2 BT reader with your headunit?
Thx
j_motion is offline   Reply With Quote
Old 09-15-2015, 02:46 AM   #16
calmtigers
Drives: 2014 Whiteout TRD FR-S 6MT
Pics installed? Considering this as an upgrade
"I love dinosaurs so much that I’ve based my life on burning as much black melted dinosaur flesh as I can on a daily basis...even the screaming sound of prehistoric reptilians being burnt through any of the classic Japanese four cylinders gives me great joy."
calmtigers is offline   Reply With Quote
Old 09-15-2015, 08:45 AM   #17
DJCarbine
Thupercharged
DJCarbine's Avatar
Thx
I did not, but it looks like it's easy to get one that works for less than 20 bucks or so
2013 FRS
Vortech V3 11psi
Old 09-15-2015, 02:30 PM   #18
j_motion
I will Rip it apart tonight and take some pictures..
Just did the basic install for to test out FM, GPS, to check if they work or not.
Haven't go the time to install the reverse camera yet.
Going to route the Mic to the OEM mike location.
Purchased this to Retain OEM USB harness to USB connection on the aftermarket HU. Not going to bother with the OEM 3.5mm Jack, will never use it anyways.
http://www.aliexpress.com/item/USB-c...1_5_4,201409_2
DJcarbine.
I got the OBD2 form Joying, It pair and connects to the headunit and Torque app. But it doesn't show any real time data after.
And it throws a lot of U0073 code when it is communicating with the cars ECU and sifting through AUTO detect mode to find a Protocol that would work. Not sure if adaptor problem, so i got a couple more to try it out.
Jason
Old 09-16-2015, 08:39 PM   #19
rhood168
rhood168's Avatar
Drives: Black Subaru Brz Limited
I wonder if this will work with OEMAudio+ setup.
rhood168 is offline   Reply With Quote
Old 09-16-2015, 10:49 PM   #20
j_motion
Sorry i got a little held up, havnet got the time to take the pictures yet.
Im not sure if it will work with OEM audio.
If the harness config for OEM Audio is the the same as OEM , i dont see why now.
Right now my connection is like this.
OEM harness - kicker sub harness (plug & play) - Joying harness (Plug & play)
Just need to repin the connect on #9. - Android head unit.
Old 09-17-2015, 03:07 AM   #21
HAWAIICALIVEGAZ
HAWAIICALIVEGAZ's Avatar
Drives: HONDA, TOYOTA
Looks pretty good!
HAWAIICALIVEGAZ is offline   Reply With Quote
Old 09-23-2015, 08:53 AM   #22
privfaith
Drives: RX8 -> 2013 FRS
Anyone noticing the resolution on this thing is.. strange? I find a lot of the apps don't seem to fit correctly.
It's almost as if the sight impaired mode is on.
privfaith is offline   Reply With Quote
Old 09-23-2015, 09:21 AM   #23
DJCarbine
Thupercharged
DJCarbine's Avatar
I'm using this with the OEMAudio reference 400cf
2013 FRS
Vortech V3 11psi
Old 09-24-2015, 06:21 PM   #24
rhood168
rhood168's Avatar
Awesome what kind of harness did you use and what settings on the 400 cf? I'm using a pioneer radio atm and its great but I'm looking for something better.
Old 09-24-2015, 07:29 PM   #25
DJCarbine
Thupercharged
DJCarbine's Avatar
I told the guys at OEM Audio+ the headunit I was using, they took care of the DSP settings etc.
The harness is a standard toyota harness, basically just get a radio harness made for the FRS, and wire it into the android HU harness like any other install.
Plug and play
2013 FRS
Vortech V3 11psi
Old 10-12-2015, 10:26 PM   #26
joop1987
Drives: 2013 FRS, Raven, Auto
I installed one of these last weekend and so far I like it a lot. Shipping was fast and install was pretty simple. I had to grind the nipples off the original brackets and move the amp wire from pin 8 to 9. If you have a BRZ, you need to connect both pins. The unit comes with the Toyota harness for power, speakers, .... But you will need the antenna adapter cable (Metra 40-LX11) and USB adapter cable(Metra AX-TOYUSB).
joop1987 is offline   Reply With Quote
Old 10-16-2015, 09:31 PM   #27
duke_FRS
duke_FRS's Avatar
Drives: 2015 FRS Hot Lava 2014 CT200H
How does everyone like the unit? I've found it on amazon. Is it really worth it?
Open Flash Tablet Stage 1 93 | Borla Cat-Back | VOSSEN VFS1 | Eibach Sportline
duke_FRS is offline   Reply With Quote
Old 10-16-2015, 09:33 PM   #28
Binary_fission
Binary_fission's Avatar
Drives: FRS
Would like to know as well, I'm debating between this and ca-fi but i heard new cafi doesn't support obd2
Sent from my SM-N910T using Tapatalk
Binary_fission is offline   Reply With Quote
Another Android Head Unit Starscream15 Electronics | Audio | NAV | Infotainment 57 08-23-2015 12:41 AM
Dashlinq4 Android Head unit. Stock BRZ fitment. Toyota Universal. junglizste Audio/Visual, Electronics, Infotainment, NAV 3 01-08-2015 11:55 AM
Ca-Fi Dashlinq4 Android head unit universal Toyota phanguy Audio/Visual, Electronics, Infotainment, NAV 4 11-19-2014 11:57 AM
FS: T7019A Android Head Unit pheoxs Audio/Visual, Electronics, Infotainment, NAV 4 08-26-2013 05:05 PM
Android head unit drei Electronics | Audio | NAV | Infotainment 21 07-16-2012 02:42 AM
