Old 05-21-2015, 10:14 AM   #15
wparsons
wparsons's Avatar
Originally Posted by mav1178 View Post
... but this depends on your local autocross course design. Some places like to put in courses with a lot of 2nd and 3rd gear changes.
-alex
That's the key! I would look at logs/video from typical courses you would be running to see where the rpm's spend most of their time, then look at dynos to see which header gives you the most area under the curve based on the realistic rpm range you need.
If you're spending more time in the 3000-5000 range, a 4-2-1 will likely be way better. If it's all over 5000 then 4-1 will probably win out.
flickr
Old 05-21-2015, 12:06 PM   #16
copafeel
Drives: Honda 2000
Originally Posted by kosoku View Post
trippinbillies - check out ptuning's header. They got 200hp with header and a 3" exhaust (I think the 2.5" would be better) + a tune.
Just my opinion but I think EL is the way to go for high REV's. UEL I think is better for the torque dip (someone correct me if I'm wrong).
Agreed. For max top end power, this answers your question, op. Ptuning header .
copafeel is offline   Reply With Quote
Old 05-21-2015, 12:19 PM   #17
evomike
Drives: frs
Originally Posted by 2016 Camaro SS View Post
Perfect setup. I run that exactly. End of thread. I'll just save you a lot of time and you won't be disappointed.
and you have zero proof that this is correct except your butt dyno
evomike is offline   Reply With Quote
Old 05-21-2015, 01:19 PM   #18
2016 Camaro SS
2016 Camaro SS's Avatar
Drives: Fast
If you'd like to pay for my dyno pulls, I'll get you numbers, but most likely it will just end up being, "Oh, that dyno is known to give high numbers or its off".
I've got 20+ datalogs you can go through if you'd like.
Not to mention the other threads containing JDL UEL headers combined with headerback exhausts breaking 190-200 whp constantly.
If the OP is going for a pure STX build though, maybe a 4-2-1 merged EL might be a better choice. UEL's are pretty solid for daily drivers.
2016 Camaro SS is offline   Reply With Quote
Old 05-23-2015, 12:26 PM   #19
kosoku
Drives: 2013 fr-s
OP, make a decision?
kosoku is offline   Reply With Quote
Old 05-23-2015, 12:32 PM   #20
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
Nameless performance 3" kit (axleback, mid, front, over) with either the Nameless Performance headers (EL) or the JDL (UEL).
stockysnail is offline   Reply With Quote
Advice on 3" Exhaust Combo: JDL EL Catted Header, Nameless OP/DP, Perrin Cat-Back rtyp3 Engine, Exhaust, Transmission 30 10-25-2016 08:52 AM
Top Gear Solutions| Borla UEL Header / Cat Back Exhaust | Package and Combo Deals! TopGearSolutions Engine, Exhaust, Bolt-Ons 156 04-14-2014 08:14 PM
The Exhaust Diet: Lightest Header to Exhaust tip combo phastafrican Engine, Exhaust, Transmission 3 12-30-2013 08:44 PM
Agency Power Header and Exhaust shickles Engine, Exhaust, Transmission 3 04-29-2013 09:47 PM
