Old 05-20-2015, 12:18 PM   #15
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
1) it's your toe settings, not the arm.
2) if you are ever worried about bolt movement, mark the rear camber washer against the arm so you have a point to measure against. just because you can torque the bolt more doesn't mean that something is actually moving. Like this:
3) see #1.
4) get an alignment before passing judgment.
-alex
Old 05-20-2015, 12:58 PM   #16
wparsons
wparsons's Avatar
Keep in mind just how small the toe measurements are too. I have 0 front toe, and 1/16" total rear toe in (not per side). There's no way you can eyeball 1/32" per side, even 1/8" per side would be hard to eyeball.
flickr
Old 05-20-2015, 03:36 PM   #17
DuMa
DuMa's Avatar
Drives: LR BRZ Limited
well im not claiming to say i adjusted toe and its aligned. In fact i hadnt even touched toe but i just know its out of spec.
judging on the comments here, im guessing everyone had their alignment guy torque or tighten the Camber bolt on the SPC Arm. No one did it themselves?
DuMa is offline   Reply With Quote
Old 05-20-2015, 04:03 PM   #18
HATED1
HATED1's Avatar
Drives: 86
I'm sure everyone tightened everything down after it was installed. Unfortunately it's hard to eyeball a lot of the adjustments. You will be feeling better after the alignment
HATED1 is offline   Reply With Quote
Old 05-20-2015, 04:15 PM   #19
2016 Camaro SS
2016 Camaro SS's Avatar
Drives: Fast
I torqued all the bolts to spec myself and got an alignment. These SPC arms work just fine and don't make a lot of noise.
Just because the wheel looks straight doesn't mean it's aligned. I guarantee your alignment is way off, most likely on toe.
2016 Camaro SS is offline   Reply With Quote
Old 05-20-2015, 04:56 PM   #20
mav1178
mav1178's Avatar
Did you not read my comment?
Just because you can tighten it more doesn't mean it is not tightened properly.
If you must know, I tightened mine perfectly fine. Never used a torque wrench.
After alignment and several track events, the bolt has yet to move. Marking is unmoved also.
-alex
Edit: here's your original post:
After looking under the car again today, the camber bolts i felt after torquing it 55ft/lbs and after i set the desired camber angle (eyeballing it), i could still tighten a few more turns by hand easily with some crescent wrenches. So i dont think this 55ft/lb from SPC's specs is tight enough.
I hope you realize that torque spec is a function of the material of the bolt and the size of it. See this for some overview info:
https://www.imperialsupplies.com/pdf...rqueCharts.pdf
Old 05-21-2015, 08:50 AM   #21
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
We at AZP have installed no less than 50 of these SPC arms. Mostly on street driven (Really bumpy NJ and NYC Streets) as well as our own Project BRZ street/track car as well as our Spec86 Cup wheel to wheel race car.
We have also aligned these cars as well. None of our own nor any customer cars have come back due to any handling or bolt losing issues. All alignments were done on our Hunter Hawkeye Elite Aligner.
I would say our sample size is probably larger than most. The key is proper installment and setup of your suspension before jumping to the conclusion that the parts are bad.
-mike
AZP Installs is offline   Reply With Quote
Old 05-26-2015, 03:58 PM   #22
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
i installed mine this weekend and had an alignment done. I was told that I still have too much toe with just the arms and i need to find another adjustment alternative.
can anyone chime in on this? I have rs-r super downs with -1.3" in the rear. it seems to me that there should be enough factory toe adjustment to compensate for it. i really dont want to buy toe arms or use the offset bushings.
supramkivtt2jz is offline   Reply With Quote
Old 05-26-2015, 04:07 PM   #23
HATED1
HATED1's Avatar
Drives: 86
That is really strange. You are only dropped on springs and only have -1.3 camber and they can't align the toe within spec? I don't mean to be rude, but i think you may need to find another alignment shop.
Old 05-26-2015, 04:07 PM   #24
wparsons
wparsons's Avatar
The SPC control arms come with new toe bushings with a bigger adjustment range, just for that very reason...
As for if there's enough adjustment or not, it all depends on how much camber was dialed out, not the final camber.
flickr
Old 05-26-2015, 04:15 PM   #25
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
im sorry, i should have clarified i am -1.3 inches lower in the rear.
Old 05-26-2015, 04:30 PM   #26
HATED1
HATED1's Avatar
Drives: 86
no worries, 1.3 inches in the rear shouldn't be a problem. The alignment shop should be able to adjust accordingly. @wparsons had good input as well.
Old 05-26-2015, 04:31 PM   #27
Koa
"by hand with crescent wrenches" is not "by hand".
/throws down mic
I'M OUT
Old 05-26-2015, 04:51 PM   #28
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
/throws down mic
I'M OUT
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
Sold: SPC Rear LCAs vanetix Brakes, Suspension, Chassis 3 10-23-2014 12:51 AM
For Sale SPC LCAs Tylub Brakes, Suspension, Chassis 2 08-12-2014 05:57 PM
Rubber bushing LCAs unsurety Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 06-15-2014 03:19 PM
AP Rear LCAs JDLAutoDesign Brakes, Suspension, Chassis 2 04-17-2014 03:43 PM
Racer X LCAs bakerr6 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 08-18-2013 03:46 AM
