Old 05-13-2015, 10:50 AM   #15
Originally Posted by pinski View Post
I'll be interested to hear what you find - I've recently added TRD springs that have slightly less drop than your RS*Rs and am trying to decide if I should get a proper alignment.
LOL join the group! There seems to be a few. I find it funny because we are 3 years into these cars and we are still not sure about some basic things like safe drop heights. My previous research was pretty clear that TRD springs did not require any additional changes when running the stock wheels and tires. It did however get a little gray if changing tire sizes.
pinski (05-13-2015)
Old 05-13-2015, 11:22 AM   #16
TheVoiceOfReason
TheVoiceOfReason's Avatar
Drives: BRZ Limited
LOL join the group! There seems to be a few. I find it funny because we are 3 years into these cars and we are still not sure about some basic things like safe drop heights. My previous research was pretty clear that TRD springs did not require and additional changes when running the stock wheels and tires. It did however get a little gray if changing tire sizes.
I think its a little undecided because while you don't absoulutely need camber adjustment with that little of a drop, it is likely necessary to get your camber even. Kind of a case by case basis and really depends on how picky you are about having matching camber on each side, and how much camber you wan't to begin with. For a DD it shouldn't matter.
You do however at least want an alignment to make sure your toe is good after any change. Each car ends up with different specs after dropping, so you can't really assume your specs are the same as someone elses on the same springs unless you get it aligned.
TheVoiceOfReason is offline   Reply With Quote
The Following User Says Thank You to TheVoiceOfReason For This Useful Post:
pinski (05-13-2015)
Old 05-13-2015, 11:41 AM   #17
Rapiddan45
Rapiddan45's Avatar
Drives: 2013 FR-S M/T Ultramarine
Just a rule of thumb for any vehicle. Anytime you lift or lower a vehicle get an alignment done. You'd be surprised how far off your toe can get from such a small drop.
2013 Ultramarine 6MT- Feal 441 coils, Whiteline 20mm front/18mm rear swaybars.
RPF1 17x9 +35. 245/40/17 RS-3 V2.
OFH, Invidia OP, Spencer Fab HFC FP, Invidia N1
C38 JRSC, JROC, Delicious Tune, Radium PCV Catch Can
Rapiddan45 is offline   Reply With Quote
Old 05-13-2015, 11:43 AM   #18
Yes.
They did align mine after installing the springs (it was months before I bought it) and the records showed that it was done. What they didn't have was the sheet saying exactly what the numbers were after the alignment and this is what I am curious about. Not to mention that after driving on the snows for 4 months and through the winter conditions I would like to verify that I am indeed in as good position as it appears to be.
Old 05-13-2015, 12:12 PM   #19
humfrz
Tcoat is a fit and still spry 56 years and has zero issue getting in and out of his lowered car. His not so fit 35 year old son-in-law however puts on a humfrz like show every single time he gets out.
Heck, I was lowering cars, like my 1948 Chevy, (with 2" lowering blocks), when @Tcoat was still looking for his pacifier in his crib .......
humfrz
chaoskaze (05-13-2015)
Old 05-13-2015, 12:30 PM   #20
humfrz
My first lowered car was the wife's 76 Pacer. When the rear shocks blew and the springs both broke I just bolted a 4x4 between the axle and frame and called it a day. And people complain about a rough ride with coil overs!
chaoskaze (05-13-2015), humfrz (05-13-2015), Rapiddan45 (05-13-2015)
Old 05-13-2015, 12:46 PM   #21
LucidMomentum
No Money, No Problems
LucidMomentum's Avatar
Instead of lowering it, you can do what I did and put on 18x8.5 wheels to fill out the gap a bit more. I live in a town with some awful roads so I didn't want to lower it.
Pics in my sig.
Old 05-13-2015, 12:58 PM   #22
asdf
Loading...████████] 99%
asdf's Avatar
Drives: #0517
I'm running TRD springs -- had it aligned about a week after install, added camber bolts up front + the oem 'crash bolt.' I asked to straighten out the toe and max out the camber up front, car feels amazing after alignment! I'm was able to get -1.9 for camber up front.
W/ the toe straightened out (at minimum, made equal on both sides), the car feels tighter going in a straight line. And w/ the added camber up front, grip feels improved in corner. Definitely worth it, imo.
asdf is offline   Reply With Quote
The Following 2 Users Say Thank You to asdf For This Useful Post:
pinski (05-13-2015), Tcoat (05-13-2015)
Old 05-13-2015, 02:22 PM   #23
WNDSRFR
Drives: FR-S,GTI
I have the Eibach Pro Kit with 235/45/17 Conti's. It's not that low but this urethane bumper-bumper thing has saved my front end many times. I got it on ebay for like 79 bucks. Probably my most practical mod to date. Note what the bottom looks like.
Anyone with a Carbon Fiber Fender? (The whole Fender) Stayreal Cosmetic Modification (Interior/Exterior/Lighting) 10 03-13-2014 04:55 PM
Stock Fender or C-WEST Fender? Stayreal Cosmetic Modification (Interior/Exterior/Lighting) 3 03-12-2014 08:06 AM
TRADE: FT86 Fender Vent for BRZ Fender Vent xia Exterior Parts (Aero, Lighting, Etc.) 0 10-04-2013 10:56 PM
Want to trade my white Frs fender vents for Brz fender vents White0utFrs Exterior Parts (Aero, Lighting, Etc.) 0 09-23-2013 04:17 AM
TRADE: brz fender for fr-s fender dun3 Exterior Parts (Aero, Lighting, Etc.) 1 07-04-2013 11:06 PM
