#15 |
Drives: 2015 AOZORA EDITION
Any updates I might just call in tmwr to book an appointment. After I flash my car with OFT noise is only at idle when I Rev it a lil you can hear it but barley
#16 |
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
I take my car in tomorrow. Will update when details become available.
#17 |
Just got a call from the dealer.
It turns out its something to do with the input shaft on the transmission that's making this noise. Its weird, because I never had any shifting issues or anything of that nature. They ordered a new transmission and I'll be getting it replaced May 13. This sucks. From what I understand, its safe to drive. It just sucks. |
#18 |
Drives: Subaru BRZ
mine has had this too since probably.... 8k miles. I dont think its anything to worry about. And i'm honestly really surprised that the dealer is straight up replacing the whole trans for this "issue"
part of me thinks the noise will still be there(if they dont change out the clutch/pressure plate as well), or come back after several thousand miles. I'm genuinely curious. please report back.
2014 WRB BRZ
#19 | |
#20 | |
Drives: Subaru BRZ
but actual failures of synchros/gears are basically limited to those running over 300 rwtq. i'm sure there has been a few bad ones out there though.
2014 WRB BRZ
#21 | |
#22 |
Booked my appointment for th 29th hope goes well. I will update if I get new tranny or not
#23 | |
| The Following User Says Thank You to Koa For This Useful Post: | Xuningshen (05-15-2015) |
#24 |
New transmission is in. So far there hasn't been any chatter noise upon a cold start (35F this morning) and normal idle.
I only noticed a brief noise when the A/C compressor kicked on after turning on the heat. I guess the problem is fixed. The dealership sent the defective tranny back to Subaru. I asked the parts/service rep if Subaru would say what failed or caused the failure, and he said no. If there was an issue with it, the only way they would know is through a bulletin or TSB. I'll keep listening for the noise, but with it finally warming up outside it might be impossible to mimic the conditions. |
| The Following 2 Users Say Thank You to Bobblehead For This Useful Post: | NA_FRS86 (05-15-2015), Xuningshen (05-15-2015) |
| Cold rattle? | JGalp | Engine, Exhaust, Transmission | 7 | 06-24-2018 02:25 AM |
| Flywheel Rattle? | CB762 | Issues | Warranty | Recalls / TSB | 119 | 11-16-2016 11:09 PM |
| Rattle sound on cold start | Frs32907 | Issues | Warranty | Recalls / TSB | 0 | 07-12-2014 11:36 AM |
| rattle sound cold start | marky | Issues | Warranty | Recalls / TSB | 1 | 03-24-2014 07:16 PM |
| Flywheel / Clutch rattle | topazsparrow | Issues | Warranty | Recalls / TSB | 7 | 07-05-2013 09:09 PM |
