#15 |
Drives: 2019 Mazda Miata RF
Crap...sorry, tire weight came from the michelin website, and I was adding OEM and aftermarket wheel weights, I will edit the post to reflect ONLY the tire weight.
#16 |
Someone asked for this in a PM, so I'll add it here too...
225/45/17 ZII's compared to stock: ![]() Same ZII's compared to 205/50/17 Barum Polaris 3 snows: ![]() Stack of 4 stock tires compared to 4 225/45/17 ZII's, both un mounted:
#17 |
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
With a smaller diameter tire you are dropping the CG whatever ~1/2 the diameter difference is and the engine doesn't have to work as hard to rotate the smaller diameter tire/wheel. This translates to a little more planted ride, a little bit more responsiveness from the throttle, and a little bit quicker acceleration. You give up theoretical geared top speed due to the smaller diameter, but that is a non-issue with a drag limited vehicle with too little power and too high a gearing to even get to the theoretical top speed to begin with. Actual top speed with a smaller diameter tire would probably be higher than on stock sized tires due to engine being a little more 'efficient' in its power delivery... would need GPS to verify of course since speedometer will artificially read high.
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
#18 |
Drives: n/a
Thanks for the replies everyone! Decided to stick with the stock size MPSS, should get them installed this week.
#19 | |
Drives: 2015 Scion FR-S
Sent from my XT1254 using Tapatalk
FRed-S
| FS: STOCK RIMS AND TIRES | bhbnuckle | Canada Classifieds | 1 | 03-31-2014 09:02 PM |
| stock rims and tires | bulldog11267mad | Wheels and Tires | 1 | 08-20-2013 09:58 AM |
| Wtb: stock rims only no tires | whitefrs | Wheels and Tires | 1 | 04-24-2013 11:16 PM |
| WTB: OEM Stock rims and tires | HATED1 | Wheels and Tires | 4 | 08-29-2012 02:23 PM |
