Old 04-02-2015, 10:46 PM   #15
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
My roommate works at ACT, so don't hold your breath. I'll have one before anyone else and I'm not expecting it any time sooon.
p.s. the exedy kit that comes with the flywheel is just the OEM replacement.
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
Old 04-02-2015, 11:55 PM   #16
wootwoot
Drives: FRS
The exedy stage one comes with a 12lb flywheel. I know because I called them to confirm. Then I bought it and checked before I installed it.
http://www.ft86club.com/forums/showthread.php?t=54737
wootwoot is offline   Reply With Quote
The Following User Says Thank You to wootwoot For This Useful Post:
Hyper4mance2k (04-03-2015)
Old 04-03-2015, 12:13 AM   #17
Hyper4mance2k
Alexandrino_Auto
Drives: series.Blue
Interesting. Thanks.
Old 04-03-2015, 12:42 AM   #18
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Stock lightweight one from Toyota...
https://www.japanparts.com/parts/detail/42820
Just wish it were less expensive...LOL
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
Old 04-03-2015, 02:18 AM   #19
WHTEBRZ
Drives: BRZ Limited
I have a forged steel flywheel on my celica for this reason. Rotational weight makes a huge difference and it only weighs 9 lbs!
WHTEBRZ is offline   Reply With Quote
Old 04-03-2015, 09:49 AM   #20
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
It may be worth considering a clutch and flywheel assembly that are balanced together. I run lightened pulleys, prolite flywheel and alum driveshaft and other than some cosmetic NVH issues, I have no drivability or CEL issues. I had my clutch and flywheel balanced as an assembly and the balance shop did have to make some adjustments to the clutch cover.
Also a driveshaft shouldn't have much to do with idle unless you have an automatic which you obviously don't. At idle you are clutch in or in neutral no?
industrial is offline   Reply With Quote
Old 04-03-2015, 09:58 AM   #21
Cross
It's the Mad Cow
Cross's Avatar
It's more the cars ability to catch the idle when it's coming down that causes most tuning issues and stall problems.
Lightening the drive shaft can add to that on in gear decels but it's not usually as big of a problem. This will be my first time trying it on an FRS though.
If I do lighten the factory flywheel I will have them rebalance everything again just to be safe.
With the prolight is it indeed unable to mount to stock like everyone believes?
Old 04-03-2015, 10:01 AM   #22
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
I suppose, I haven't experienced what you mentioned. I will say, once you have all these parts, you'll want to set idle to at least 900rpm. You get alot of drama when the AC kicks on at the stock idle. I have mine set at 950rpm currently to deal with my flywheel chatter while clutched in.
Old 04-03-2015, 10:13 AM   #23
Cross
It's the Mad Cow
Cross's Avatar
Thanks I will make sure to do that, what about the prolight only fitting specific clutches?
Old 04-03-2015, 10:32 AM   #24
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
I didn't experiment with any clutches. I ordered a stage 1 clutch with a pro-lite flywheel, had it balanced and installed it about two years ago.
Old 04-03-2015, 10:41 AM   #25
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Yes this will be an NA E85 Bolt on setup for now, but knowing me that will not last I have already been thinking about building another turbo kit or going with the Edelbrock Supercharger kit when they hit the market.
Then I wouldn't lighten the factory flywheel, but just save for a flywheel designed using lighter material yet just as strong if not stronger. If you're planning on adding lots of extra torque to the output shaft, I wouldn't go weakening the item which is the engine-part of the assembly which transfers that torque to the transmission.
^GT5 Replay Photo Mode^
Old 04-03-2015, 11:23 AM   #26
Cross
It's the Mad Cow
Cross's Avatar
Meh I may also sell the car and get an NSX by that time so I can't be sure what I will do. I like my FRS considerably but it's been a long time and I need to have some fun in it again to remember if this is the car for me or if I should find an NSX.
Old 04-03-2015, 12:28 PM   #27
Hyper4mance2k
Alexandrino_Auto
Drives: series.Blue
You're not weakening it, your making less likely to break by removing material...
Also, the ACT's are all replacements, both the Street & Pro.
Old 04-03-2015, 01:02 PM   #28
SirBrass
SirBrass's Avatar
Well, after reading the responses after, I still maintain reservations but it sounds less like a risk than I'd previously thought.
Flywheel Chatter samisons Issues | Warranty | Recalls / TSB 13 12-05-2014 09:30 AM
Fs: act flywheel and clutch Guildjs Transmission and Driveline 9 05-18-2014 03:26 PM
Stock clutch+flywheel+pressure plate+ ACT lightweight flywheel & pressure plate PineappleFriedRice Transmission and Driveline 0 11-08-2013 04:54 PM
*Perrin Performance/Agency Power LIGHTENED Crank Pulleys In Stock* 10k Redline Engine, Exhaust, Bolt-Ons 7 10-15-2012 10:51 PM
Swap: factory 16s for factory 17s Sydney MZ21 Australia Classifieds 10 07-29-2012 10:46 PM
