Old 03-17-2015, 04:48 PM   #15
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
Originally Posted by Engdrew View Post
Hey guys, I'm new to the forum and am glad I finally joined!
So... A couple days ago I had taken a girl out on a date to a restaurant near a strip of pubs. We came out a few hours later to my complete disgust when my CF hood had 2 deep key marks on it.
Very frustrating when people see a nice car and decide to damage it. Do you guys have an recommendation to getting it out? If possible? I'll attach some pictures. Thanks.
Use whipenew as a temp fix. I use it to cover up scratches until I find a good day to touch up on my car. Tire shine works well too for temp fixes to clear coat scratches. Just buff extra residue out.
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
Old 03-17-2015, 05:12 PM   #16
Engdrew
Drives: 013 ft86
I'll have to try that! Thanks for the temp fix idea!
Hopefully I can get it buffed out. If not maybe try a detailer?
Engdrew is offline   Reply With Quote
Old 03-17-2015, 06:33 PM   #17
Tgionet
SPACESHIP
Tgionet's Avatar
Drives: BRZ Ltd 6MT WRB
You'll be able to sand that out, worst case scenario you might have to level the epoxy or clear coat (if it's clear coated). Epoxy is a royal pain in the ass to sand, but not difficult to do. I'd wet sand then polish it. I'm confident you'll be able to get it back to 90%+ if not 100%
Tgionet is offline   Reply With Quote
Old 03-17-2015, 06:42 PM   #18
Engdrew
Drives: 013 ft86
What grit should I sand it with? 2000? And do you know if they sell sponge ones at that level? Thanks.
Old 03-17-2015, 06:46 PM   #19
MikeyBatz
MikeyBatz's Avatar
Drives: Scion FR-S
Assuming its been clear coated, if you can scratch it with your nails then its too deep else it will buff out.
MikeyBatz is offline   Reply With Quote
Old 03-17-2015, 06:50 PM   #20
Engdrew
Drives: 013 ft86
I tried that test and my finger nail does catch on it a little..
So Id say it's pretty deep.
Old 03-17-2015, 07:06 PM   #21
Tgionet
SPACESHIP
Tgionet's Avatar
I'd use a DA and finish at 3000 before moving to rubbing compound and finally jeweler's polish. Depending on how deep the scratch is you may need to add clear coat to it. You could contact Seibon and ask what they'd suggest using.
Old 03-17-2015, 07:29 PM   #22
Chad11491
Drives: 85.5 Porsche 944, '15 mustang GT PP
You'll have to get the clear touched up if you can feel it. I really like meguiars ultimate compound for light scratch and swirl removal, i would get some clear and fill it in, and do as others have said and sand it down with 800, then 1200 then 2000 then 2400 or whatever is close to that. Then compound, Polish, glaze, seal, and wax. That sounds excessive, but it has the deepest shine of anything I've ever seen, and it will fill and hide small scratches.
Chad11491 is offline   Reply With Quote
Old 03-17-2015, 07:29 PM   #23
Engdrew
Drives: 013 ft86
That sounds like it would work, if not help a lot. All they recommended me doing is contacting a fiber glass detailer to do the work.. Nothing else.
Old 03-18-2015, 12:24 AM   #24
mvpstigma
mvpstigma's Avatar
Drives: 2015 Scion FR-S 6SPD Man. [Halo]
Sorry to hear about the damage.
Might I ask the general whereabouts you were at?
Wouldn't want to end up there myself.
mvpstigma is offline   Reply With Quote
Old 03-18-2015, 01:40 AM   #25
Engdrew
Drives: 013 ft86
Lightbulb
Down on 1st street. In seattle
Definitely taking the accent or bike down there next.
Old 03-18-2015, 03:34 AM   #26
niceguy21
Socal Valley 86 Member
niceguy21's Avatar
Drives: 2000 Toyota Tacoma SR5 & Scion FRS
In my experience if you feel how deep the sratches are in the paint. If they seem like they are non existent to the touch maybe light compound with some polishing can knock it down. If you feel that sratch is too deep, sand around the area with 2000 grit, if the scratch is still visible after sanding, you'll need to obtain some resin and catalyze a small amount, depending on how deep the scratch is, with a small blade add within the scratch crevice, making sure not too much or else it would cause more work trying to sand the resin while risking damaged from execesive sanding. Once the resin has cured (about 2 hours)begin to sand off resin with 2000, once you feel that most of the resin has been leveled begin to buff using a wool disk and compound (rotary buffer with light speed and pressure). Once all sanding marks have been knocked, use a dual action along the whole hood with a choice of polish, then clean thoroughly. Lastly wax and watch it look like new. That's my input, wish I could make a video for a more detailed process.
niceguy21 is offline   Reply With Quote
The Following 3 Users Say Thank You to niceguy21 For This Useful Post:
DAEMANO (03-18-2015), Engdrew (03-18-2015), Koa (03-19-2015)
Old 03-18-2015, 03:48 AM   #27
Engdrew
Drives: 013 ft86
Cool
Thank you. I'll have to look into this and give this a try! Definitely want to get it fixed asap.
I just don't want to be the guy to make that jackoff's key work even worse with the sanding.
The Following 2 Users Say Thank You to Engdrew For This Useful Post:
niceguy21 (03-18-2015), Tcoat (03-18-2015)
Old 03-18-2015, 10:04 AM   #28
Felix7007
Drives: Scion FR-S Black
PLASTI DIP BRO
Felix7007 is offline   Reply With Quote
somebody keyed my frs, need help xcooperx Southern California 30 03-26-2015 01:21 AM
Car keyed!! uEih BRZ First-Gen (2012+) — General Topics 28 10-26-2014 07:41 PM
Some kid keyed my car HillCountryGuru Cosmetic Modification (Interior/Exterior/Lighting) 20 06-06-2013 01:10 PM
Keyed. eXtreme Burrito! Scion FR-S / Toyota 86 GT86 General Forum 125 04-09-2013 11:40 AM
Car got keyed Ravine AUSTRALIA 88 10-20-2012 04:22 AM
