Old 03-27-2015, 10:15 AM   #15
robr
Drives: 2013 FRS, with boost by ATS Racing
Originally Posted by tirespin782 View Post
Is this on their stock compressor wheel or with the billet compressor wheel upgrade?
Only upgrade was the wastegate. Car had Perrin intake, 3" catback, base AVO kit with upgraded wastegate. Probably could have made more power if the new wastegate was capable of holding even 1 bar well.
robr is offline   Reply With Quote
Old 03-27-2015, 06:42 PM   #16
protpibe
protpibe's Avatar
If you want 3" with the AVO kit you have to buy their entire front/mid exhaust section kit. It comes with a downpipe, overpipe, and front pipe. You can't buy these pieces individually because they change the routing and flange locations. This setup without catalytic converters will yield the most power but be prepared for some boost creep.
Upgrading the stock front pipe only to a 3" diameter but keeping a 2.5" overpipe and downpipe is a waste of time imo. Even getting rid of the secondary cat in the front pipe probably won't do much (relatively speaking)
Old 03-27-2015, 07:32 PM   #17
Basket Case
Drives: 2013 Raven fr-s
Why would there be boost creep?
Basket Case is offline   Reply With Quote
Old 03-27-2015, 07:37 PM   #18
protpibe
protpibe's Avatar
My assumption is that The exhaust flows too quickly for the the tiny little internal wastegate to keep up when there is almost no backpressure (no cat and 3" dp).
Mine was creeping about 2ish psi
Old 03-27-2015, 09:29 PM   #19
WallsAndFoundations
WallsAndFoundations's Avatar
Drives:
Thanks for the input! Stupid question though.. what's boost creep? I have never heard of that term.
Is it when someone someone tries to hit on me for having a turbo?
WallsAndFoundations is offline   Reply With Quote
The Following User Says Thank You to WallsAndFoundations For This Useful Post:
Dammod (03-28-2015)
Old 03-27-2015, 09:38 PM   #20
robr
It's your friend on E85.
it's a pain on pump gas, especially if you're going for a fairly aggressive tune.
Old 03-27-2015, 10:00 PM   #21
protpibe
protpibe's Avatar
No thats boost creepin lol
If your wastegate is 7psi, but you start hitting 9psi
The Following User Says Thank You to protpibe For This Useful Post:
WallsAndFoundations (03-28-2015)
Old 03-28-2015, 10:14 AM   #22
WallsAndFoundations
Drives:
Haha another stupid question: let's say I'm set up correctly for a decent amount of boost (reinforced clutch and all that), it almost sounds like boost creep would be.. good..?
Old 03-28-2015, 10:15 AM   #23
WallsAndFoundations
Drives:
Thanks for the answer! How come it's an issue on pump gas?
Old 03-28-2015, 02:09 PM   #24
protpibe
protpibe's Avatar
The not good part is the lack of control
Old 03-28-2015, 02:56 PM   #25
robr
Like it's been said, boost creep happens because you aren't able to control boost 100% (for various reasons, none of which really matter to your question).
The main problem with boost creep when tuning is that you're basically trying to consistently tune for an out of control state. It generally is the same under the same conditions, but the "generally" part is the key word. So you're assuming the amount of boost creep will be the same every time, every day, every weather/elevation/whatever conditions. Which, if you haven't guessed, is a very large assumption.
As to pump vs E85, there's just a MUCH larger factor of safety on E85. Of course, an E85 tune that is way too aggressive would not be good either, but hopefully nobody tunes like that.
To Greddy Turbo Owners (or SBD/Zage Turbo).... Melted Radiator Fans? General Opinion? xuimod Forced Induction 106 09-01-2016 07:33 PM
FBM Stage 1 Base Turbo Kit Starting @ $3995 Garrett or PTE Turbo Choices FullBlown Forced Induction 588 12-02-2015 02:41 PM
Greddy turbo kit and AVO world turbo kit SPECIAL PRICING! THMotorsports.com Forced Induction 129 07-24-2014 06:51 PM
Geneva Preview: Techart to debut 911 Turbo, Turbo S vh_supra26 Other Vehicles & General Automotive Discussions 1 02-22-2010 06:20 PM
