Old 04-27-2015, 02:54 AM   #15
Shourewaters
Drives: 2013 Scion FRS 10 Series
Does this intake trigger the CEL?
Shourewaters is offline   Reply With Quote
The Following User Says Thank You to Shourewaters For This Useful Post:
aFe POWER (04-27-2015)
Old 04-27-2015, 03:41 AM   #16
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
I'm guessing given the low mass its momentum would be quite low as well.
Old 04-27-2015, 07:37 PM   #17
aFe POWER
aFe POWER's Avatar
Drives: 2014 Scion FRS
No it does not
aFe POWER is offline   Reply With Quote
The Following User Says Thank You to aFe POWER For This Useful Post:
Shourewaters (05-04-2015)
Old 04-27-2015, 11:36 PM   #18
Donbrz
Drives: 2015 Brz Blue Series
Install Require Bumper Removal
Does this require removal of the bumper to install? I understand it's almost impossible to remove the brz bumper and get it rehung properly, and am hesitant to consider if the bumper removal in necessary. Thank you for feedback?
Donbrz is offline   Reply With Quote
The Following User Says Thank You to Donbrz For This Useful Post:
aFe POWER (04-28-2015)
Old 04-27-2015, 11:49 PM   #19
PNW FRS
PNW FRS's Avatar
Visit their website... there are install instructions (PDF) available. Looks like there is a "partial" removal of the bumper in order to remove the OEM snorkel.
2013 Asphalt / MT
Olympia, Washington
PNW FRS is offline   Reply With Quote
The Following 2 Users Say Thank You to PNW FRS For This Useful Post:
aFe POWER (04-28-2015), Donbrz (04-28-2015)
Old 04-27-2015, 11:52 PM   #20
PNW FRS
PNW FRS's Avatar
Dyno results
Not sure if it's indicated on the "print out" -- but what kind of exhaust (headers to tips) are on the test car.
2013 Asphalt / MT
Olympia, Washington
The Following User Says Thank You to PNW FRS For This Useful Post:
Old 04-28-2015, 01:40 AM   #21
Wise
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
I have the Version 2 aFe Takeda intake which looks similar in install to this version.
The install pamphlet told me to remove the bumper to unbolt and take out the snorkel assembly of the stock intake.
I was able to unbolt and remove the snorkel by unscrewing the top pan of the front bar and then peeling back the bumper's top part just enough to get a socket wrench in. The hardest part was wiggling the snorkel itself out of the gap made. I had to get a mate to hold the front bar's top back a bit while I pulled it through.
Much easier than removing and remounting the whole unit though.
Wise is offline   Reply With Quote
The Following 3 Users Say Thank You to Wise For This Useful Post:
aFe POWER (04-28-2015), Donbrz (04-28-2015), Shourewaters (05-04-2015)
Old 04-28-2015, 12:00 PM   #22
aFe POWER
aFe POWER's Avatar
As "Wise and PNW FRS" suggested it is a partial bumper detachment making it easier to remove the snorkel with enough given room. The instructions should provide you with enough help to do this.
The baseline and the Takeda intake run had both the stock exhaust, and stock exhaust manifolds on the test car.
The Following 2 Users Say Thank You to aFe POWER For This Useful Post:
Donbrz (04-28-2015), PNW FRS (04-28-2015)
Old 04-28-2015, 04:29 PM   #23
PNW FRS
PNW FRS's Avatar
More questions..
Is the "regular" plastic (non-CF) version available with the intake tube w/o the hole for the Sound Generator? (Like the CF version.)
RE: removal of oem snorkel > wondering how much the removal of this plays in your peak HP gain? Seems that taking off the snorkel creates sort of a "ram-jet" scenario whereby fresh air is being forced into the large airbox -- end result is your increase in air flow.
2013 Asphalt / MT
Olympia, Washington
Old 04-28-2015, 07:11 PM   #24
aFe POWER
aFe POWER's Avatar
That with a combination of the sound tube delete, bigger filter and our tube design all adds up in making more power.
Old 05-01-2015, 05:44 PM   #25
aFe POWER
aFe POWER's Avatar
Bump
Old 05-13-2015, 10:12 PM   #26
mikeTee
Yup.
mikeTee's Avatar
Drives: MT Subaru BRZ '13
In for one once it goes below 450
mikeTee is offline   Reply With Quote
Old 05-14-2015, 11:26 AM   #27
aFe POWER
aFe POWER's Avatar
We do have a plastic version of the Takeda momentum intake system, if cost is a concern
http://afepower.com/shop/details_new...-S&brandID=137
Old 05-14-2015, 11:30 AM   #28
mikeTee
Yup.
mikeTee's Avatar
That v2 design doe lol.
The Following User Says Thank You to mikeTee For This Useful Post:
aFe POWER (05-14-2015)
afe power takeda, br-z, carbon fiber, fr-s, intake
APR Radiator Cooling Plate Carbon Fiber w/ TRD Intake Subaru BRZ 2013-2014 / Scion FR RallySport Direct Engine, Exhaust, Bolt-Ons 0 02-27-2014 05:25 PM
FS: Takeda Momentum Intake Vlady Engine, Exhaust, Bolt-Ons 10 12-14-2013 03:27 PM
carbon fiber airbox for takeda/greddy momentum intakes-SOLD FR-Shadow Engine, Exhaust, Bolt-Ons 17 09-16-2013 03:54 AM
