Old 06-22-2012, 11:48 AM   #15
Gt86er
Gt86er's Avatar
Here are pictures of how I installed mine.
Gt86er is offline   Reply With Quote
Old 06-23-2012, 10:38 AM   #16
was385
Drives: MT WRB BRZ Limited, 2007 911s
Oh OK, now I understand what you did.
BTW, for anyone who did hardwire it, how did you ground it? I see the ground wire, but the harnesses I've seen have a screw hook for the ground.
was385 is offline   Reply With Quote
Old 06-23-2012, 03:25 PM   #17
Lil Abner
Drives: 2013 FR-S, 6MT, Ultramarine
There are 3 wires in the harness:
Blue: (+) Reverse
White: (+) Positive
Black: (-) Negative
So for a radar detector, use the Black for your ground, White for your positive. There is no need to ground to the chassis of the car.
Lil Abner is offline   Reply With Quote
Old 06-23-2012, 06:40 PM   #18
was385
Blue: (+) Reverse
White: (+) Positive
Black: (-) Negative
I understand that part of it, it's that the hardwire harnesses I've seen for sale just come with a bolt loop to ground to the chasis. Does anyone know of an adapter or another harness that can just tie into the wire?
Old 06-23-2012, 07:17 PM   #19
Lil Abner
Are you referring to something like this:
Passport 8500 Hard Wire
In that link, there is a red push-on connector and a black ring terminal. The black ring terminal just needs to be cut off and attached to the black wire in the factory harness.
Does that still answer your question?
Old 06-23-2012, 08:04 PM   #20
was385
That's exactly what I'm talking about. As someone who hasn't really done electrical work before, what's the best way to attach it to the ground wire? Can I hook the cut wire up to a T-Tap?
Old 06-23-2012, 08:09 PM   #21
Lil Abner
I would add a push-on connector like the positive wire in the hard wire kit. Look at the picture below. I used the red T-taps on the factory wires, and red Push-On connectors on the aftermarket side. These connectors can be found at local auto parts stores.
If you can't find the connectors, let me know. We may be able to work something out for me to send you some.
Old 06-24-2012, 07:46 PM   #22
blalor
Drives: WRB BRZ Limited 6MT
The bolt that holds the fuse box to the body serves as a ground. I crimped a large eyelet to the ground wire for the V1 hardwire adapter, and put the bolt through it. Worked like a charm. Need pics?
blalor is offline   Reply With Quote
Old 06-25-2012, 10:24 AM   #23
was385
Alright thanks, I'll have to run out to radio shack or napa when the kit comes in. Just to clarify, do the wires you're running this off only go to the homellink mirror?
Old 06-25-2012, 05:37 PM   #24
Lil Abner
Those wires in the picture go to the mirror AND radar detector. I didn't take a picture of the rest of the wiring. So I think you're wondering if there's enough power up there to power both things? Answer: YES
Old 06-26-2012, 07:41 PM   #25
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
I wanted to add to this thread. I had my valentine 1 hardwired into my 04 STi utilizing the oem compass mirror harness. I happened to have the mirror sitting around so I hacked off the harness coming from the mirror, and put quick disconnects on the newly exposed wires.
I then took the hardwire kit for my valentine 1 and put quick disconnects on the exposed wires here as well.
I then found the wires that were hot and ground and hooked those up correctly on the harness, and plugged it into the car.
So when I traded my STi for the BRZ I pulled the harness back out and had it sitting around waiting to see if it would work in the new car. So today I went out to check it out and, yep for me this install was plug and play.
So yep I was able to plug it all in and tuck the wires. Took me all of maybe 10 minutes.
for reference the blue is switched power on the factory 04 compass mirror harness and black is ground.
Ranatsu is offline   Reply With Quote
Old 06-26-2012, 09:36 PM   #26
was385
Hypothetically speaking, if I were to accidentally cut through the three wires while trying to expose them for the t-taps, is there any problems with just covering them up with electrical tape where the white plug used to be... hypothetically speaking of course.
Old 06-26-2012, 09:41 PM   #27
Lil Abner
Well, for using T-Taps, you actually don't need to strip the insulation back. Just put the T-Tap around the wire, and squeeze together with pliers until they snap. They will penetrate the insulation on their own.
But yes, hypothetically speaking, you can just tape off the ends of the wires. INDIVIDUALLY please.
Old 06-26-2012, 09:56 PM   #28
was385
Yes, definitely individually. I wasn't trying to strip the individual insulation off, just the rubber tubing that surrounded all three of them together. Which brings me to my next point, I'm hooked up with the ground wire to black and the other to white and yet nothing. Anyone have suggestions? I'm about to just cut my losses, tuck this stuff back up in the headliner, and move on to just wiring it to the fuse box which seems a little more idiot proof (which I apparently desperately need).
Direct wire radar detector Kieranz Electronics | Audio | NAV | Infotainment 25 11-02-2015 12:01 AM
What will you hang from your rear view mirror? Dillano609 Scion FR-S / Toyota 86 GT86 General Forum 148 11-15-2013 02:52 PM
Radar Detector? Longhorn248 Other Vehicles & General Automotive Discussions 68 07-14-2012 04:31 PM
Mounting radar detector video ayau BRZ Photos, Videos, Wallpapers, Gallery Forum 10 06-07-2012 11:29 AM
Rear view Mirror pic nixeighty6 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 45 01-27-2012 05:10 PM
