Old 02-24-2015, 01:52 PM   #15
Silver Ignition
APEXHNTR
Silver Ignition's Avatar
Drives: 10 Series FR-S #1867
So 35psi asphalt/38psi concrete then?
2013 Sc10n FR-S 10 Series
#1867 of 2500
in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer]
Silver Ignition is offline   Reply With Quote
The Following User Says Thank You to Silver Ignition For This Useful Post:
Thorpedo (02-24-2015)
Old 02-24-2015, 01:55 PM   #16
renfield90
The Stig's German cousin
Originally Posted by ViperASR View Post
So you're saying that everyone driving around in their street cars with ~32psi in their tires are constantly on the edge of rolling over?
That isn't even close to what I said. Straw man arguments typically come from people who don't understand logic, or who are arguing from a losing position. Which one are you?
Old 02-24-2015, 02:01 PM   #17
renfield90
Try it out and see how you like it. Did you read the link I posted? As long as the tire doesn't start becoming a torus and lifting the edges off the ground you can add more pressure. If you have some white printer paper you can drive over it to see what your contact patch looks like. Regardless of whether you think a sufficiently rolled over tire can flip a car, the physics of higher tire pressures creating more grip are unchanged.
The car will be harder to drive with higher pressures, because the tire will be less compliant over bumps on the surface. My personal opinion is you should learn to drive this way. I'm not alone in this, I know a few people with multiple national championships under their belt who run higher pressures than everyone else. Maybe they're on to something.
Old 02-24-2015, 02:19 PM   #18
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
From the site that you quoted (which I revisit every so often)
From all this, we can assume the following:
  1. A tire will gain grip with increasing tire pressure until the internal pressure overcomes the strength of the carcass portions that keep the tire cylindrical, at which point the tire will start losing grip;
  2. A tire with a fairly rigid construction (a DOT-approved tire) will want more total pressure than a tire with a floppy construction (race slick);
  3. A wide tire (with a large unsupported beam section across the tread section area) will stand less total pressure than a narrow tire; and
  4. A soft tire will need less pressure than a hard tire.
And this is pretty much what is observed in the wild. A wide, floppy, soft, and sticky race slick might use 15 PSI, but a narrow, stiff, hard, and smooth OEM street tire might use 55 PSI.
this is why I'm fairly comfortable running 27~28 psi on a 235 R1R on a 2800 lb car. But will run higher on other tires like the RS3 or ZII
having said that, 22 psi on any street tire is suspicious..... No way that's enough air to support the carcass under comp use, it is bound to deform.
Old 02-26-2015, 02:20 PM   #19
Silver Ignition
APEXHNTR
Thanks for all the responses, guys.
That link is awesome! A wealth of information; things I've known to be true but never quite understood until it was all laid out for me. Thanks for that.
While I have several RE-11 driver's in the house, how do you guys feel about doing an AutoX event or two with temps below 40*F? In November when I swapped back to my stock wheels I was noticing that the RE-11 (old 140TW version) was a bit slippery at ambient temps below 40*F...have 3 events in March alone and they're done in a beach parking lot on Long Island's south shore, so temps are generally between 28*F and 40*F for the month of March. Will I be struggling for grip or is one run enough to warm them sufficiently? Can't be worse than the OEM Michelins......can they...?
#1867 of 2500
Old 02-26-2015, 02:23 PM   #20
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
you're not really gonna have any of the high performance summer tires do well at 40*F, so really, everyone is on equal footing.
the best thing to do for those really cold days is have a smaller section width tire with taller sidewalls, they will heat up quicker
Old 02-26-2015, 02:35 PM   #21
Thorpedo
The SquadWhisperer
Drives: '13 Ultramarine FR-S (STX)
What 7thgear said is about right. Your all seasons will be on equal footing ( I would guess) as the ultra/extreme performance tires get really hard at temps that low, which is why tirerack lists min. temps. Your all seasons may actually be softer at that temp. Funny thing, has anyone tried a performance winter? They will be the softest of the bunch at that temp.
2013+14+15 Atlantic Region Motor Sports Autocross STX Champion
2013+14+15 Atlantic Region Motor Sports Overall Autocross Champion
2017 Bluenose Autosport Club Overall Rallycross Champion
Powered by Great North Performance, Jani-King Canada, and OK Tire.
Thorpedo is offline   Reply With Quote
Old 02-26-2015, 06:55 PM   #22
cjd
cjd's Avatar
Drives: 2017 BRZ
Yeah, the Nokian WRG3 supposedly started as a race tire for such conditions. Very good feedback on my wife's Prius, makes me want to get her better tires for the summer. And makes me wish I had them too, though I just don't drive much if at all in the winter.
Old 02-26-2015, 07:05 PM   #23
n8dog11914
n8dog11914's Avatar
Drives: 2013 WRB Subaru BRZ 6MT
I also have our first autocross event of the year this weekend. Temps in Charlotte are going to be around 25 to 37 degrees F. Should be quite interesting!
I am really debating if keeping my OE Michelins on would actually be any better than the RE11As.
n8dog11914 is offline   Reply With Quote
Old 02-26-2015, 08:01 PM   #24
Silver Ignition
APEXHNTR
Interesting…maybe I'll bring both my OEM Michelins and the RE-11's and do some testing...
#1867 of 2500
New Bridgestone RE-11A Hanakuso Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 51 02-13-2014 11:51 AM
FS: Bridgestone Turanza tires Drifty86 Wheels and Tires 5 12-18-2013 11:54 AM
FS: Bridgestone Blizzak WS70 205/50/17 aim1126 Wheels and Tires 4 10-14-2013 08:43 PM
WTB Stock Bridgestone Tire LIKEABOSS Mid-Atlantic 9 04-26-2013 03:25 PM
WTB Stock Bridgestone Tire LIKEABOSS Wheels and Tires 6 04-26-2013 02:07 PM
