Old 02-17-2015, 08:32 PM   #15
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
Unless you were to drop both of the cars out of a plane and see which would land (crash) faster. This is why you need the parachute
Originally Posted by Shutter View Post
ah, gotcha. So lets plan on keeping the parachute
wait. Does that mean the RCF would technically beat us? Even in its destruction, the RCF is faster than us.
We're screwed.
The Following 2 Users Say Thank You to continuecrushing For This Useful Post:
Choco (02-18-2015), raven1231 (02-17-2015)
Old 02-17-2015, 08:39 PM   #16
raven1231
We're screwed.
I know its the sad reality of owning an 86
Choco (02-18-2015)
Old 02-17-2015, 08:42 PM   #17
swarb
.29 cd vs .33 for the rcf, so we cut the air better, so technically we would crash first. Dunno who wins though, die first or stay alive longer?
Old 02-17-2015, 08:45 PM   #18
qqqqball
qqqqball's Avatar
The 86 has the looks - it confuses people. The Lexus has the amenities that the 86 doesnt...uhh sound dampening being the most notable.. Our cars are so freaking loud, especially with aftermarket tires and a firm suspension.
qqqqball is offline   Reply With Quote
Old 02-18-2015, 09:42 AM   #19
Pat.Thornton
Pat.Thornton's Avatar
Drives: 2014' 86
I got to test drive the rcf at a dealer about a month ago and holy sh**. The thing rips through the gears and with eight speeds it seems never ending. Very fast but still not worth that kind of money... I got to drive the m4 that day as well and If I was gonna be spending that kind of money on a car I would pick that... I feel that the frs is better than both of them though due to it's lightweight and balance, and for the price it's unbeatable.
Pat.Thornton is offline   Reply With Quote
The Following User Says Thank You to Pat.Thornton For This Useful Post:
FRSBRZGT86FAN (03-05-2015)
Old 02-18-2015, 09:55 AM   #20
ScoobsMcGee
Junior Senior with Cheese
ScoobsMcGee's Avatar
Wouldn't that mean the car would have to fall nose-first the entire time? Now we need to consider weight distribution and counter-balancing to ensure optimal cd while falling to a splattery demise.
swarb (02-18-2015)
Old 02-18-2015, 10:55 AM   #21
babydriver
Hit the road and I'm gone
babydriver's Avatar
We're screwed.
All objects fall at the same rate of acceleration (assuming equal air resistance), 32 ft./sec/sec. Galileo proved this about 400 years ago. This is due to the fact that the Earth is massively larger than any object that we could drop from any height, even something like a mountain (if that could be done somehow).
The exception is an object with high air resistance (such as a feather). The slowing of the fall is exclusively due to the air resistance. On the moon, if you dropped a Lexus and a feather from the same height, they would land simultaneously. I doubt that the difference in air resistance would matter in the case of the two cars.
So the FR-S and Lexus would tie.
Slip, slidin' away.
The Following User Says Thank You to babydriver For This Useful Post:
Kkobe2 (02-23-2015)
Old 02-18-2015, 11:04 AM   #22
swarb
Old 02-19-2015, 09:43 AM   #23
Twin4Life
Twin4Life's Avatar
Drives: '14 Genesis Coupe 3.8 Grand Touring
Did you really type that with a straight face?
Twin4Life is offline   Reply With Quote
Old 02-23-2015, 01:29 AM   #24
richardM
Drives: scion frs, 2012 Mustang
I hate when people don't know physics
Sorry.. force= mass times acceleration
The heavier car has more force, so if both have equal resistance, the heavier car will fall faster.
Think of it this way.. the heavier car took more energy to pull it high in to the sky, and that energy is used to overcome the air resistance on the way back down hill.
When in doubt, try an experiment: get two toy balloons. Fill one with air and the other with water. Make them the same size so they have the same air resistance. Drop them both at the same time and see which hits the ground first.
A piece of paper and book have the same cross sectional area. Drop them side by side. CLEARLY the book falls faster.
So.. theory and experiment confirm.. Newton's laws work.
richardM is offline   Reply With Quote
Old 02-23-2015, 08:21 AM   #25
pushrod
Benched 86lb
pushrod's Avatar
Drives: Ultramarine FR-S
This is not because of the masses; it's because of aerodynamics. The piece of paper is easily deformed by the pressure from the air and changes shape. Also, air has a much greater ability to have a meaningful effect on a lighter object than on a heaver object, and so will be able to add or remove more kinetic energy from it.
Force = Pressure x Area
Accel = Force / Mass
therefore
Accel = Pressure x Area / Mass
therefore
a lighter object passing through a fluid will accelerate or decelerate more readily.
pushrod is offline   Reply With Quote
Old 02-23-2015, 08:21 AM   #26
Dude, really?
HunterGreene (02-23-2015)
Old 02-23-2015, 08:25 AM   #27
pushrod
Benched 86lb
pushrod's Avatar
Total drag comes from the products of the Cd and the frontal area. A small brick has less drag than an F18. That said, the 86 is also smaller, so it's even more in our favour.
Old 02-23-2015, 08:59 AM   #28
Pat.Thornton
Drives: 2014' 86
Tried to lol
New Lexus ES leaked. Who said it's Camry of Lexus? Dark Other Vehicles & General Automotive Discussions 25 02-24-2012 01:34 AM
