Old 02-14-2015, 02:24 PM   #15
PowderfaceTr.
PowderfaceTr.'s Avatar
Drives: stock
Have you tied taking the rust off? Just brush off and oil. This reduces your torque seting but rest assured its the best way to keep your lug bolts in the holes.
Advice On Proper Fundamentals of Japanese Motor Vehicle Feel free to ask.
PowderfaceTr. is offline   Reply With Quote
Old 02-14-2015, 02:34 PM   #16
vroom4
The cheapo muteki lugs, we have our wheels on and off 100 times a year, never a damaged lug or nut.
vroom4 is offline   Reply With Quote
Old 02-17-2015, 02:46 PM   #17
CSG David
CSG David's Avatar
Originally Posted by revolutioN21 View Post
Do the CSG Lug nuts work with rpf1's to use it on track?
Yes.
Old 02-17-2015, 04:12 PM   #18
ExxelDistributions
ExxelDistributions's Avatar
Drives: 2014 FR-S 6MT Monogram Series
Originally Posted by CSG David View Post
Yes.
Do you guys have a eta on when they might be available?
ExxelDistributions is offline   Reply With Quote
Old 02-17-2015, 05:14 PM   #19
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
Used to use project kics R40s; they all broke after a year of use. Back to steel muteki nuts.
TylerLieberman is offline   Reply With Quote
Old 02-17-2015, 05:21 PM   #20
CSG David
CSG David's Avatar
Which ones?
Old 02-17-2015, 05:23 PM   #21
ddeflyer
I am using: [ame="http://www.amazon.com/gp/product/B004QHMS5S"]Amazon.com: Muteki 32905B SR Series Black 12mm x 1.25mm SR48 Open End Lug Nut Set, (Set of 20): Automotive[/ame]
They are nothing fancy but so far they haven't caused me any trouble. I would recommend getting some extras (helps that they are cheap) as all it takes is someone walking by and accidentally kicking one as you work to ruin your day.
Fun car leads to autocross, autocross leads to track days, track days lead to lemons, lemons leads to racing school, racing school leads to spec Miata...
No idea where it leads next!
ddeflyer is offline   Reply With Quote
Old 02-17-2015, 05:53 PM   #22
ExxelDistributions
Which ones?
CounterSpace Garage Lug Nuts - M12x1.25 it says out of stock on your website
Old 02-17-2015, 06:48 PM   #23
CSG David
CSG David's Avatar
Oh the aluminum ones. We're in process of testing out a different type of aluminum alloy so once that's finalized, we'll have them ready to go.
Old 02-17-2015, 07:21 PM   #24
willnigguhwassuh
IG: will__is__nguyen
willnigguhwassuh's Avatar
Drives: 2013 Asphalt FRS
muteki extended lugs!
willnigguhwassuh is offline   Reply With Quote
Old 02-17-2015, 07:30 PM   #25
Sammakko
Bilge monkey
Sammakko's Avatar
Drives: '13 BRZ, 82 starlet
Kics/kyokugen lugs. I've used these for over 10 years on multiple cars with extremely good results. Never stripped or broken any, never broken the wheel key. Highly recommend.
Look up kyokugen on ebay.
Sammakko is offline   Reply With Quote
Old 02-21-2015, 10:08 AM   #26
Str8Ghostin
Drives: 2014 Raven Scion FRS 6MT
Originally Posted by DarkSunrise View Post
That's so funny I use the same and have never had a problem with them! Have used them on all my cars, great lugs
Str8Ghostin is offline   Reply With Quote
Old 02-22-2015, 05:28 PM   #27
orangeblue
Drives: Whiteout
I use these too.
orangeblue is offline   Reply With Quote
Old 02-23-2015, 08:13 AM   #28
troek
troek's Avatar
Drives: 2012 Toyota 86
Advan chromoly nuts.
How do you guys running 18x9.5 in the front do it? ysr50guy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 05-04-2014 02:49 PM
Closed Project Kick Revo Lug Nuts (closed) ARP Extended Lugs Sportsguy83 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 02-25-2014 11:46 AM
BRZ stock lugs and lock nuts w/ key scion dad Wheels and Tires 0 09-15-2013 10:46 PM
what upgraded pads are you guys running? ft86me Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 07-18-2013 01:22 PM
Stock Wheels and Gorrilla spline Lugs Nuts USMC -FRS Wheels and Tires 3 02-21-2013 02:32 PM
