Old 06-30-2015, 12:14 AM   #15
flipsonic
flipsonic's Avatar
Drives: 2013 Scion FR-S (Whiteout)
Question
Guys, these 2 corners are they also going up a bit on yours or did they sit flat?
flipsonic is offline   Reply With Quote
Old 06-30-2015, 06:57 AM   #16
RickyBobby
Drives: 2013 Firestorm FR-S AT
Mine sit flat.
RickyBobby is offline   Reply With Quote
Old 06-30-2015, 07:26 AM   #17
RickyBobby
@Agent 86
Thanks for scanning and uploading the instruction images. Figure 2.5, keeping the gap between the brackets at 135 mm is very important. Without instructions I held the brackets against the console while drilling the other holes. This worked out ok because my armrest slides smoothly and engages in the 3 positions, but if I installed it again I would follow the instructions.
Also figure 5.1 shows the correct orientation of the plastic clips in the armrest base. It looks like I guessed right.
Old 07-03-2015, 05:01 PM   #18
Lonewolf
Lonewolf's Avatar
Drives: Moped
Great resource guys, thank you.
Old 07-06-2015, 04:59 AM   #19
djenousis
Drives: 2015
AMAZING! i was wondering why the car didn't have a arm rest...
2015 Subaru BRZ
djenousis is offline   Reply With Quote
Old 07-07-2015, 05:14 PM   #20
Agent 86
Drives: 2017 Cayman S
I just checked mine today, and yes they are slightly raised. If you hadn't mentioned it, I don' think I would have noticed.
The good thing is that it does not interfere with the movement of the armrest. It seems to be caused by the crown of the center console that armrest straddles.
If it bothers you, I imagine this could easily be fixed with the careful application of heat from a heat gun.
… and loving it! Maxwell Smart
Gone but not forgotten
2014 BRZ Limited - 2013 VW Golf R - 2010 Forester XT - 2006 Mazda 3 GT
Agent 86 is offline   Reply With Quote
Old 03-15-2016, 04:08 PM   #21
STEWARDORNG
Drives: 2016 BRZ
Awesome
Thanks for the info guys easy install works great! My kit came with no instructions so this was very much needed thanks again!
STEWARDORNG is offline   Reply With Quote
Old 03-07-2017, 11:16 AM   #22
Kutanks
Drives: 2013 Firestorm 6MT,2005 Saabaru 5MT
How much would a dealer/ shop charge to install this? I am sure I could do it myself but It looks a bit more involved than I thought at first. I test drove a car and was disappointed that the used one I am going to buy doesn't have an arm rest
Kutanks is offline   Reply With Quote
Old 05-30-2017, 09:37 AM   #23
Heavyax
Drives: 2015 Ultramarine Scion FR-S
Thank you for the guide, followed it and got my armrest in without any problems!
Sent from my ONE E1005 using Tapatalk
Heavyax is offline   Reply With Quote
Old 11-30-2018, 07:07 PM   #24
HRTROB
HRTROB's Avatar
Drives: Toyota 86
I just installed my armrest. I didn't want to drill any holes so I just used double sided tape. The whole thing mounts securely. You apply the tape to the underside of the armest rails (the side that mounts to the console), mount the rails to the included plastic cover/trim piece, apply tape to the sides and rear portion of the cover, then mount to the console. No need to use the template, takes only 5 minutes and is completely reversible
At first I thought the armrest wouldn't make any difference since I never found myself needing a place to rest my arm in this car, but I was wrong. It really feels good and does make driving (especially in traffic) more comfortable
HRTROB is offline   Reply With Quote
Old 08-09-2020, 04:18 PM   #25
e30cabrio
e30cabrio's Avatar
Drives: 2017 86
Thanks for all the input, I just did this and am very happy.
Car should have come with it stock IMHO.
e30cabrio is offline   Reply With Quote
Old 08-18-2020, 11:54 AM   #26
CincyJohn
Drives: 2022 MT Neptune GR86 Prem.
Anybody know if this will fit a 2020 BRZ?
CincyJohn is offline   Reply With Quote
Old 08-18-2020, 02:03 PM   #27
AJ32162
Drives: 2019 BRZ with Performance Package
Yes, it will fit the 2020 BRZ.
AJ32162 is offline   Reply With Quote
Old 03-06-2021, 10:32 PM   #28
DMB
Drives: 2019 86 TRD SE
Thank you for this. I bought my new 86 in December, from a dealer in AZ, and drove it back here. The armrest is a $199 option, but they couldn't get one in time. So, I bought one from a local dealer for a little more than that for the part only. No installation instructions included. It was too complicated for me to figure out, so I asked them how much to install it, and they quoted me almost $250. This is a huge help, and I thank all of you who contributed.
DMB is offline   Reply With Quote
*GB FR-S/BRZ Center Console Armrest $45.99 Massdrop Groupbuys 0 10-14-2013 09:06 PM
TRD Center Console Armrest zzabbas Cosmetic Modification (Interior/Exterior/Lighting) 12 01-22-2013 06:44 PM
JDM Center Armrest K2 Scion FR-S / Toyota 86 GT86 General Forum 49 10-09-2012 12:08 AM
DIY Center Armrest BRZranger Cosmetic Modification (Interior/Exterior/Lighting) 6 07-19-2012 11:04 AM
Center Armrest Sovran Cosmetic Modification (Interior/Exterior/Lighting) 13 05-11-2012 12:49 AM
