Old 02-26-2015, 03:11 PM   #15
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Nitrous Express Kit
Under a grand for the kit.
DustinS is offline   Reply With Quote
Old 02-26-2015, 03:43 PM   #16
Koa
Originally Posted by Celadrielas View Post
Ok, My question was more specifically why spend a couple of grand. If it's free and you can do it, sure. Why not? But I don't understand the 2-3 grand for a No2 kit when you can you spend ~$3100 and go legit FI if you put the leg work and research in. (one of our local car meet people did a SC kit)
also remember one can combine NOS and FI for a very potent, dynamic setup.
Old 02-26-2015, 08:00 PM   #17
mad_sb
Drives: 2013 Asphalt FR-S
If your set on running a bottle then do some research on ecutek.
Old 02-26-2015, 08:59 PM   #18
themajesticone
themajesticone's Avatar
Drives: '13 UM86
I would try to reach out to the top tuner shops personally and ask them their experience. It seems to be a rare occurrence to include NOS in a build.
JRSC C30 91 oct | JDL UEL Header | Tomei Overpipe | Milltek Front Pipe | Milltek Catback | SPL LCA v2 | FA 500 v5 Coilovers 6k/7k | SPC Front Camber Bolts | Enkei RPF1 17x9 +35 | 245/40 Michelin Pilot Super Sport
themajesticone is offline   Reply With Quote
Old 02-28-2015, 05:52 PM   #19
brznoob
brznoob's Avatar
Drives: 2014 subaru brz Limited 6mt
NX Stage 2 EFI kit 50 shot E85
https://plus.google.com/116431783151...ts/fC7LVnj5y9u
Not running the RPM window switch yet as the tech had some setbacks getting the tach signal but looks like will soon be resolved and is totally wired.
2014 BRZ Limited 6MT World Rally Blue.
Mods: Tomei UEL header, Tomei overpipe, HKS Dual Resonated Front Pipe, Stock Catback, JR C30 kit with HBP, DW700cc injectors, DW 65C pump, Delicious Tuning FF kit, Forrester XT oilcooler, ACT HD Street clutch, ecutek #mototuned.
brznoob is offline   Reply With Quote
Old 03-25-2015, 10:00 PM   #20
Zex_Frs
Just another bottled FRS
Zex_Frs's Avatar
Drives: 2014 Scion Frs on Bottle
I'm set on running nitrous because I like it don't get me wrong my last car was tirbo and I love it but is play out on the frs already also is supercharge. Most likely because they work really good with the frs. That been said I have talk to my ecu tek tuner but they haven't done any frs on bottle yet so I guess I will be the first one lol I'm just waiting on getting injectors and a pump as the tuner said I needed them to run e85 and the bottle let's see and I will keep you updated on build. And I spray s 75 with my wet zex Kit big difference on performance got me hook!!!
Zex_Frs is offline   Reply With Quote
Old 03-25-2015, 11:25 PM   #21
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
Friendly advice, make sure you have a laptop that will let you know the status of your manifold and when it's danger.
I didn't do that when I had my NOS installed and my floorpan fell out of my car. Major inconvenience
TylerLieberman is offline   Reply With Quote
Old 03-26-2015, 12:39 AM   #22
Tromatic
Don't forget to post pics post explosion!
Tromatic is offline   Reply With Quote
Old 03-26-2015, 07:14 AM   #23
LS1M
Drives: 2015 BRZ
This is also my first post - well, second post, if you count the "hello world" intro I did last week. I ran nitrous at the drag strip on my Camaro for a couple of years. Cars typically "blow up" because there is too much nitrous in the cylinders at low rpm's. If you activate the nitrous when the rpm's are low, each cylinder gets a bigger fill of nitrous. Too much nitrous, too much torque, you end up with bent connecting rods. So a window switch is important, so you don't activate it until you're up at least over 3000 RPM. I also had mine shut it off just before it shifted, and a time delay on activiation. That was to allow the tranny to shift (didn't want to spray through the shifts) but probably doesn't mean much with a manual transmission. You certainly don't want to be spraying if you hit the rev limiter, because then you will have a major lean condition - all nitrous and no gas = boom! In addition to the window switch you need a throttle switch so you spray only at wide-open throttle. And of course you must make sure you don't run lean. I think that's everything - WOT switch, window switch, delay timer (optional), bottle heater (to make sure the nitrous is at a consistent temperature), and some way to measure your AFR so you're not running too lean. Running too lean will cause a backfire and possibly melt your pistons, running too much nitrous will create more torque than your engine can handle & bend your rods.
Properly installed and functioning, nitrous can be a blast and completely safe. Personally, I found it a pain to have to heat up the bottle, open the valve, purge, check, the solenoids, any time I wanted to use it. It was fine for the track, but too much hastle for a daily driver. It is fun, though...
-Mark
LS1M is offline   Reply With Quote
Old 03-29-2015, 04:46 PM   #24
Zex_Frs
Zex_Frs's Avatar
-Mark
Thanks for the nice write up instead of saying stupid comments like post pics of the explosion, my Zex kit has the tps build in I have a window switch and heater also I had used nitrous before and know to set the windows switch to certain rpm and stuff.
Old 03-29-2015, 04:49 PM   #25
Zex_Frs
Zex_Frs's Avatar
Thanks a lot for the stupid response and will do!!! I write a post thinking I get some advised but guess this forum is a joke or the ppl here are
Old 03-29-2015, 04:52 PM   #26
Zex_Frs
Zex_Frs's Avatar
Can someone tell me how to close down the thread? Tired of dumb stupid response of ppl like supposedly senior members that should help or keep their mouth shut lol!!!
nitrous, tunning
FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp PrimeMotoring Engine, Exhaust, Bolt-Ons 8 10-30-2015 06:36 AM
FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp PrimeMotoring NY / NJ / CT / PA 0 10-20-2014 10:48 AM
Moto-East BRZ/FR-S Tuning and On-Line Configuration tool! Xero-Limit Announcements, Contests, Giveaways 2 03-25-2013 03:24 PM
nitrous eindio Forced Induction 17 09-22-2012 01:09 AM
