Old 01-23-2015, 04:09 PM   #15
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Honestly, the biggest drawback for me would be load time of the tune file with the OFT. Dyno time is at a premium and it would be hard facing precious tuning time being lost to file writing- even for the smallest changes. That's sorta the debate I'm having with the OFT. I am okay to drop ~$1000 for the Ecutek stuff but their business model stinks and would rather just avoid them entirely. I can't do a standalone EMS because of emissions laws in my region so I'm left with not much else. I guess I will continue to lurk around OFT and see what happens? But for real, OFT and it's monitoring and logging capabilities are worth the $500 alone.
Is there anyway to speed up file write times?
hmong337 is offline   Reply With Quote
Old 01-23-2015, 04:20 PM   #16
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Speeding up writes times is easy. It just involves writing a small portion of the ROM (where the mapping data is located) instead of the whole ROM. This would reduce write times to 30 sec versus 5 minutes.
The problem with this is that it can be risky if the user doesn't know what he is doing. It's would be possible to write a portion of a ROM into a ROM file that isn't compatible. Which would result in a corrupt file and a possibly nonrecoverable ECU. This is not to say that we will never offer partial writing. But it is something that takes a good amount of time to implement correctly with sufficient safeguards for the end user.
Old 01-23-2015, 04:51 PM   #17
Robert@Openflash
Robert@Openflash's Avatar
Drives: C6 Z06
you should get one and I can set one up for you.
Why don't I have one of these yet!?!?
Robert@Openflash is offline   Reply With Quote
Old 01-23-2015, 05:14 PM   #18
steve99
Dont like contradicting anyone but taxtrix\ecuflash does complete rom write of 1280k bytes
tactrix\ecuflash does full erase first then writes complete rom its always 80 sec does not matter if your writing a couple of changes to an existing rom or a complely new rom ie different calid like updating from A01G to D00G. that has completly different structure so partial write would not work.in that case.
So its certianly possible to write a full rom in that timeframe.
Agree partial write would be a dangereous practice with all the different rom types structures, patches ect.
Old 01-23-2015, 05:25 PM   #19
Shiv@Openflash
Drives: 2013 FRS
If they are writing the entire file in 80 seconds, that's great news. We should be able to do that as well as it would just be a matter of reducing the wait time between each CAN command. I'll CAN sniff a write through Taxtrix cable to confirm. Thanks for the info!
Cheers,
shiv
Old 01-23-2015, 05:30 PM   #20
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
Seems like this would make using E85 without a flex fuel kit much less stressful. Very nice!
Jyn is offline   Reply With Quote
Old 01-23-2015, 05:40 PM   #21
Thorpedo
The SquadWhisperer
Drives: '13 Ultramarine FR-S (STX)
You can configure up to 3 different Tuning Alerts. And each Tuning Alert can have up to 4 conditionals that can be set as an OR or AND condition. For available channels, it will be a subset of the up-to-14 channels you configured for data logging/viewing. So if you wanted to create a lean run alert, you would do something like this in one of the 4 Tuning Alert menus:
Throttle > 70%
Engine Speed > 2000rpm
Engine Load > 1.0
AFR > 13.0
AND
With these settings, the alert would trigger if all of those conditions were met. The throttle and engine load conditions would keep the alert from triggering during lean spikes caused by lift throttle or traction control intervention. And the RPM condition would keep it from triggering at very low RPM where AFR can be a bit unstable. The AND setting makes sure that ALL of these conditions must be true for the alert to sound. If you used an OR setting, only one of these conditions would have to be true for the alert to sound.
You must be in the Realtime Data screen for the Tuning Alerts to work. You can be in any one of the 3 viewing options (14 channel, 3 channel or graphic). One the alert triggers, the OFT will beep and the flash the screen. After that the triggered channels will flash. To reset the channel flashing, simply press the RESET button.
To create a good Tuning Alert for low Advance Mult, you can simply set up a second Tuning Alert using just one single conditional.:
Advance Multiplier < 0.5
For a good Tuning Alert for overboost, overheat and knock, you can set up a 3rd conditional like this using an OR setting (so only one single condition needs to be true for the alert to trigger):
Boost > 10psi
Coolant Temp > 240
Knock Correction < -3.0
OR
Pretty awesome, huh?
Cheers,
shiv
My god man, I got a chubber from reading that.
2013+14+15 Atlantic Region Motor Sports Autocross STX Champion
2013+14+15 Atlantic Region Motor Sports Overall Autocross Champion
2017 Bluenose Autosport Club Overall Rallycross Champion
Powered by Great North Performance, Jani-King Canada, and OK Tire.
Thorpedo is offline   Reply With Quote
Old 01-23-2015, 05:57 PM   #22
Tromatic
I'd like to see the OFT tablet become a "dongle" that could connect via BT or WiFi to a tablet or laptop. That would be cool.
n7777;2102108]So many vendors have come and gone. So many tuners have come and gone. You keep rocking.[/QUOTE]
And each tune only gets better as well.
Tromatic is offline   Reply With Quote
Old 01-23-2015, 07:18 PM   #23
Malt
Drives: 2015 WRX
That sounds like a dangerous proposition considering if you ever lost wifi or bluetooth connectivity with the device you'd be left with a partially written ECU. If you are looking for just something with a real time display of stats then torque with a bluetooth dongle will work somewhat but I cant imagine we'll ever see any tuning device offer full wireless writing to the ECU. The risks are just to high.
Malt is offline   Reply With Quote
Old 01-23-2015, 07:29 PM   #24
Shiv@Openflash
Drives: 2013 FRS
Just the kind of feedback I like hearing
Old 01-23-2015, 07:41 PM   #25
phrosty
I agree, wireless flashing sounds like a disaster waiting to happen.
If one doesn't already exist, it likely wouldn't be too challenging or expensive to create an OBDII -> serial -> usb cable, and then a tablet app that could interface with it. Would enable some cool possibilities that aren't really possible on the OFT hardware.
*hint*hint* Openflash
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
Old 01-23-2015, 07:50 PM   #26
Malt
Drives: 2015 WRX
They have USB dongles that can interface with a laptop (Tactrix) and yes I realize that you are looking for a tablet app but I'm curious what cool possibilities do you envision that would be possible with such a setup that isn't possible with the current OFT?
Old 01-24-2015, 04:26 PM   #27
hmong337
Emperor JDM
hmong337's Avatar
If you can get the write times down a lot more, I'll be all over this. 80secs is good. But not the painful 5+ minutes it takes as seen in your OFT video.
Old 01-24-2015, 07:09 PM   #28
phrosty
Do you change hardware often enough for it to matter?
Don't get me wrong, I'd love an 80sec flash time as well but a few minutes is so far from a deciding factor for me.
Official OpenFlash Tablet FA20 Tuning Tech Discussion Thread Rombinhood@OpenFlash Software Tuning 2594 08-01-2017 01:03 AM
Weird template issue after 131 update fantah Software Tuning 5 03-31-2016 08:57 PM
[OFT] OPENFLASH TABLET: Tuning flexibility in one convenient package Garrett@Openflash Engine, Exhaust, Bolt-Ons 62 07-10-2015 02:40 AM
Local tuning shops who will tune with OpenFlash Tablet? Silver Ignition NY / NJ / CT / PA 24 02-20-2015 07:08 AM
OpenFlash Tuning Tech: Tales from the Dyno (Stock, Ecutek and OpenFlash tunes) Rombinhood@OpenFlash Software Tuning 237 02-10-2014 03:35 PM
