Old 01-16-2015, 07:04 PM   #15
Tromatic
Even with them all "off" with the buttons there are still some overrides that kick in if the car thinks it is slipping toooo much. Pedal dance kills that urge it has. No problem.
Sharp, short, highway on ramps are my friend!
Can you reference that? The manual says that off is off (the three second thing) and won't reactivate. Mine does, in a most obvious way. Somewhere around here is proof that the nannies are never totally "off" (dance or fuse the exceptions) but damned if I can find it.
Could it be an MT/AT issue?
Tromatic is offline   Reply With Quote
Old 01-16-2015, 07:09 PM   #16
Manic
Is not fast.
Manic's Avatar
Drives: 2014 Whiteout M/T
If you just press the TC button quickly, it will deactivate until you hit 20mph(?). Primarily this is used for snow starts and the like. If you hold the button, it will remain 'off', but as you mentioned only the pedal dance or removing a fuse shut it off completely.
Manic is offline   Reply With Quote
Old 01-16-2015, 07:17 PM   #17
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Here's your 14-page proof:
http://www.ft86club.com/forums/showthread.php?t=25494
Also, it should be noted that even with pedal dance, you can still trigger "ice mode" if you somehow are hard on the brakes and run into a complete loss of braking power (aka going offroad or hitting oil) situation.
-alex
Old 01-16-2015, 07:23 PM   #18
It is here http://www.ft86club.com/forums/showthread.php?t=25494
Never mind Mav is just that much faster!
Old 01-16-2015, 07:26 PM   #19
Bergen23
Drives: '15 Halo FR-S
I turned off my traction control by holding the button, came in hot into a corner and almost spun it into a ditch after starting to slide. Nothing kicked in to save me except for some counter steering and a loss of momentum
Bergen23 is offline   Reply With Quote
Old 01-16-2015, 07:30 PM   #20
Tromatic
Same-same using the owners manual "three second" rule which says all off. Next time I go to the dealer I'll bring it up. And yes, the dude I go to at the dealer is an FR-S owner and hooligan too. Lucky, I guess.
Old 01-16-2015, 07:56 PM   #21
Jond63
Jond63's Avatar
Drives: FR-S Firestorm 2013
Same here -- hooning around it sure seems that in mine I can slide, spin, and lock up the brakes all day with holding both buttons down until all the lights come on.
Jond63 is offline   Reply With Quote
Old 01-16-2015, 08:30 PM   #22
Hey wait a sec here guys, the only answer to the OPs original question is: Only when I am on a certified track under controlled conditions!
Old 01-16-2015, 08:37 PM   #23
CatDaddysBBQ
Drives: '13 FR-S
Constantly. Rarely is it more than a small slide of a few degrees, but I've gotten so used to doing it, it's become habit and just part of the way the car drives. I'm not talking huge sideways drifts, that's what snowy parking lots are for.
But let's just say "inducing oversteer"??? Every single chance I get. It's 1/2 the reason I bought the car.
CatDaddysBBQ is offline   Reply With Quote
Old 01-16-2015, 09:32 PM   #24
themadscientist
Hotlink Terrorist
themadscientist's Avatar
Drives: 2015 WRB BRZ Spec S
The car has no power, this is impossible.
Old 01-16-2015, 09:37 PM   #25
Old 01-16-2015, 09:46 PM   #26
themadscientist
Hotlink Terrorist
Ah, so I must wear my butch gear to do it, got it.
Old 01-16-2015, 09:50 PM   #27
Unless your other car is a Prius!
Old 01-16-2015, 09:50 PM   #28
themadscientist
Hotlink Terrorist
I have Prius wheels on the BRZ, right?
2nd gear powerslide ease? civdaddy Scion FR-S / Toyota 86 GT86 General Forum 22 11-02-2012 03:40 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
