Old 01-05-2015, 12:59 AM   #15
frslee
Just drive it
Drives: 13' FR-S
If your only purpose for impact wrench is to remove lugs, then I would say why not go with whatever fits your budget? I spent $99 on the craftsman 19.2v 1/2" last year and still using it fine. Used it to change springs, wheels, multiple friends' wheels. Gets the job done.
frslee is offline   Reply With Quote
Old 01-05-2015, 12:25 PM   #16
Wepeel
Drives: '13 BRZ Ltd
Do you guys have any issues with messing up the studs when removing lugs with the impact? Our studs seem prone to cross-threading/stripping...
Wepeel is offline   Reply With Quote
Old 01-05-2015, 01:31 PM   #17
jvincent
jvincent's Avatar
Most cross threading/stripping happens when people impact them on.
No issues for me an I've had the wheels on/off probably a dozen times in the last year. I use the impact to take them off, and and when I put them back on I thread them by hand and use the impact to spin them down to essentially finger tight.
Torque wrench from there to the correct value.
The Following User Says Thank You to jvincent For This Useful Post:
gdrider77 (01-24-2015)
Old 01-05-2015, 08:42 PM   #18
connorlug
Drives: #1553 10 Series FRS
I personally use and recommend the Milwaukee lineup, I work in a shop where I abuse my Milwaukee stuff on the daily, and I've had my Milwaukee impact for 2 years and it hasn't even shown signs of wearing out yet lol. I can't recommend them enough!
connorlug is offline   Reply With Quote
Old 01-19-2015, 06:59 PM   #19
Frost
CASC-OR T.A. Director
Frost's Avatar
Drives: '13 Prius, '22 BRZ
Originally Posted by Draco-REX View Post
You can pry my Dewalt cordless impact from my cold dead hands. It has proven very helpful for all sorts of work. Even gently getting seized bolts loose without snapping them. Best tool purchase I ever made.
I can't believe it took me this far down the thread to find a Dewalt recco.
Dewalt is worth the hype. The only people who complain are people who say they are frequent users but aren't. They will never see the shit I see some Dewalt tools go through and just blink and say: "What? Am I supposed to shed a tear?"
If you can't get Dewalt, Craftsman is good. Milwaukee isn't bad but a solid step down from Dewalt imho.
EDIT: Taking off stuff, I use impact. Putting stuff back on, hand fasten, torque wrench to final spec. After snapping a metal flange and nearly taking out my eye (thank god for safety glasses) due to poor casting, I have sworn the f*ck off using impact for fastening. Slow but I'll be damned if anyone says I cheated.
Frost
Want the best quality track times for new personal bests? Come on out to Ontario Time Attack!!!
OTA LIVE TIMING LINK
Frost is offline   Reply With Quote
Old 01-22-2015, 12:16 AM   #20
Whatabouteggs
[Citation Needed]
Drives: 2014 WR Blue Subaru BRZ Premium
I bought a 3/8" craftsman 18v and it suuuuuuuuuucks.
Get a dewalt 1/2" and be done with it, seriously.
If you're feeling cheap you can try the alltrade brand I guess, you can get those off newegg or amazon for $60 sometimes. No idea if they're any good honestly, but anything's better than mine.
[ame="http://www.amazon.com/Tradespro-837212-24-volt-2-Inch-Cordless/dp/B00E6EF826"]Amazon.com: Tradespro 837212 24-volt 1/2-Inch Drive Cordless Impact Wrench Kit: Home Improvement[/ame]
Whatabouteggs is offline   Reply With Quote
Old 01-22-2015, 11:05 PM   #21
Miniata
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
I've had the Craftsman 19.2V 1/2" impact for 3+ years now. At first I used it with the NiCad batteries I already had on hand, and if fully charged they would remove lug nuts ok, but I'd be lucky to get through one complete wheel swap before the battery started to die. Upgraded to lithium batteries and it made all the difference in the world. It will do multiple wheel swaps on different cars, and the batteries can sit for weeks/months between charging and still be good to go.
I also have a Dewalt 14.4V impat that my wife got me for my birthday 10-12 years ago, before the more powerful impacts were commonly available. Still works well, although not as much power as the newer higher voltage impacts out there.
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar
Miniata is offline   Reply With Quote
Old 01-23-2015, 03:14 PM   #22
xtremeyolks
Drives: 14 brz, 370z, sti
I have this one: [ame="http://www.amazon.com/DEWALT-DCF880M2-20-volt-Lithium-2-Inch/dp/B00AEAYXWM/ref=sr_1_4?ie=UTF8&qid=1422040358&sr=8-4&keywords=dewalt+1%2F2+cordless+impact"]Amazon.com: DEWALT DCF880M2 20-volt MAX Lithium Ion 1/2-Inch Impact Wrench Kit with Detent Pin: Home Improvement[/ame] and love it. Small, lightweight, and plently of tq for most things.
xtremeyolks is offline   Reply With Quote
The Following User Says Thank You to xtremeyolks For This Useful Post:
justint5387 (01-29-2015)
Old 04-07-2017, 04:05 PM   #23
reeves
Just found out Amazon is having a Hitachi sale right now. The WR18DBDL2 cordless impact wrench looks awesome for tight spaces. 255 ft-lbs, and only weighs 3.3 lbs.. 2" wide, 5" long.. more compact than some cordless drills. The extra battery & carrying case doesn't hurt either.
reeves is offline   Reply With Quote
Old 04-07-2017, 07:22 PM   #24
stevesnj
stevesnj's Avatar
If you're just removing lugs, get some exercise and use this... it's free and in your trunk. :P
My 2016 Build thread
The Following User Says Thank You to stevesnj For This Useful Post:
humfrz (04-11-2017)
Old 04-07-2017, 07:46 PM   #25
qqzj
Drives: MDX, Camry
I heard ingersoll rand is the best. why nobody here recommend this one?
https://www.amazon.com/gp/product/B0...=ATVPDKIKX0DER
qqzj is offline   Reply With Quote
Old 04-07-2017, 08:15 PM   #26
reeves
That one looks like overkill for tires, exhaust & suspension work (which is all I need it for). Went ahead and bought the more compact Hitachi one, 250 ft-lbs is all the torque I'll need. Plus at 3.3 lbs, it's easier/lighter for the wife to use, I can leave it in her car's trunk in case she gets a flat and needs to change tires.
Old 04-07-2017, 09:08 PM   #27
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
I have Craftsman 19.2V.
The same battery pack powers:
1/2" Impact gun
Portable flashlight
Air compressor
Drill
I pretty much use impact gun to take off lugs and to speed up lug install process, but I never actually torque it down with a gun. Always use a torque wrench to finish off but the lugs are started by hand.
Because it's $400+ and I'm not a professional mechanic.
Old 04-07-2017, 10:08 PM   #28
qqzj
Drives: MDX, Camry
Some of those Milwaukee guns recommended are also in the $400 range ...
When purchasing such a gun, better leave some room for crankshaft pulleys. 200 ft lb won't be nearly enough there.
How does AC impact power? scionfrs2014 Scion FR-S / Toyota 86 GT86 General Forum 48 05-13-2019 06:58 PM
FS: Snap-on 1/2" cordless impact wrench & driver vc86 Mechanical Maintenance and Tools 1 08-04-2014 05:40 PM
Way too loud. Best fix for minimal impact? transition Engine, Exhaust, Transmission 55 07-24-2014 12:02 PM
[SYD] Milwaukee M18 1/2" High-Torque Impact Wrench 2663-22 eckoflyte Australia Classifieds 2 08-27-2013 06:19 AM
