Old 12-28-2014, 12:51 AM   #15
Ultramaroon
not playing cards
Ultramaroon's Avatar
Originally Posted by wparsons View Post
Just an FYI, the spare tire hold down is not the right threads for the front rotors. I tried, couldn't get it to thread, bought the right bolts and got mine off without issue.
You didn't try hard enough.
Old 12-28-2014, 02:17 AM   #16
Apex_BRZ
Drives: 2013 Subaru BRZ Limited (WRB)
Originally Posted by Ozzman View Post
Why in tarnation are you removing the hubs? Don't remove em unless you are planning to replace em.
Had to, like the first post says (I swear nobody actually reads posts except for the title of a thread). Installing brake ducting. Got them off and they are back on and torqued. Routing the hose tomorrow. The annoying parts are done, thanks for the advice guys.
Apex_BRZ is offline   Reply With Quote
The Following User Says Thank You to Apex_BRZ For This Useful Post:
fx35s (12-28-2014)
Old 12-28-2014, 02:33 AM   #17
ZionsWrath
Thanks
ZionsWrath's Avatar
When i installed my ap sprint kit i used a 5 pound sledge hammer and a block of wood
Old 12-28-2014, 01:57 PM   #18
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
20130831-DBA4650_HawkHPPlus_FrontJob-029 by VictorN07, on Flickr
F1point4 is offline   Reply With Quote
The Following User Says Thank You to F1point4 For This Useful Post:
DandoX (08-20-2019)
Old 12-28-2014, 09:51 PM   #19
Apex_BRZ
Originally Posted by F1point4 View Post
Or, you could save yourself all that unnecessary hassle and just do what I did and have them off in 5min without beating on anything and sitting in a chair the whole time.
See...nobody reads the posts in these threads.
Old 12-28-2014, 10:10 PM   #20
CoupedUpSubie
Drives: 2013 BRZ Limited
99% of threads would have 75% less posts if people actually read them. This would lead to people not achieving 20,000 posts.
Glad you got the rotors off. I've had to drive the studs out in order to pop the rotor off, it didn't have the handy jacking holes.
2013 BRZ Limited 6MT
2014 Ram 1500 Quad Cab Black Ram - 8 speed with 3.21 gears
1994 Honda VFR750 - Two brothers 4-1 left side exit exhaust
1993 Honda CB750 Nighthawk
CoupedUpSubie is offline   Reply With Quote
Old 12-28-2014, 10:14 PM   #21
Ultramaroon
not playing cards
How sure are you about that?
Old 12-28-2014, 10:15 PM   #22
wparsons
wparsons's Avatar
Not the same threads as the right bolts. The spare tire hold down would only go in about half a turn once the thread caught. The correct bolt threaded in easily.
Comparing the two side by side it's obvious the hold down is a different thread.
Have you actually threaded your hold down into your rotor? Every reference I find to this is about WRX's, not FRS/BRZ's. The rotors are the same, but the hold down could be different.
flickr
Old 12-28-2014, 10:33 PM   #23
Ultramaroon
not playing cards
I was just kidding. I'm hardcore anal about thread & fastener preservation so, among other things, I have a bag of SAE and metric bolts just to have the right pair to screw into any rotor.
Old 12-28-2014, 11:45 PM   #24
Apex_BRZ
I stripped the crap out of them. Those jacking holes are completely useless. I ended up putting bolts through the caliper bracket mounts on the back side and a nut and drove it off that way. It was beyond easy.
Old 12-30-2014, 12:01 PM   #25
The_Understated
Hooner in training... eh?
The_Understated's Avatar
Drives: 2013 Scion FRS
Out of curiosity where did you route the air from for the ducts? Fog light bezel without the lights?
**Dunno what to put here yet... Imagine something witty...**
The_Understated is offline   Reply With Quote
Old 12-30-2014, 11:45 PM   #26
OmarYasin
OmarYasin's Avatar
U need a slide hammer man! Go to autozone and rent one, i had the same issue with my rotors when i was installing arp wheel studs, just screw in the 8mm rotor bolts and with a slide hammer yank it out.
OmarYasin is offline   Reply With Quote
Old 12-31-2014, 04:10 AM   #27
Wes
Wes's Avatar
Drives: JRSC'd Asphalt FR-S
I did mine today and they were stuck as well and tried used a hammer lol but it was easiest to use the 12mm bolt for the skid plate and just thread it in until it pops off
Old 01-03-2015, 09:14 AM   #28
Apex_BRZ
The kit came with a couple ducts that I zip tied to the grill at the opening in the front bumper. I'd like to do the fog light housings, but only if I have a nice way to do it. Either replace the housings, or I'll need an adapter. For now, I just needed it done since I leave next week for Sebring.
Brake Pads, Rotors and All Your Brake/Suspension Needs! Great Prices!! Check it out!! Mike@CZP Brakes, Suspension, Chassis 348 06-01-2018 01:29 PM
FS: OEM Brake Rotors SuiSid3l Brakes, Suspension, Chassis 3 12-23-2014 03:55 PM
Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! eauto Brakes, Suspension, Chassis 255 10-15-2014 02:45 PM
BBK,BRAKE PAD,BRAKE ROTORS,MASTER CYLINDER BRACE +MORE @ Source,LLC SOURCE,LLC Brakes, Suspension, Chassis 94 07-07-2013 11:56 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 11:20 PM
