Old 01-04-2017, 01:51 AM   #15
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
I have the B8's with the Swift Spec R springs, i think the spring rate is too high for the B8's for the rear of the car, but it's perfect for the front.
I'd likely go for the regular swift springs if i could do this again, or just lay the dough on some proper coilovers.
The B8 and B6 are pretty standard when it comes to seeking a better suspension, in fact there is no wrong answer when it comes to the Koni's or Bilsteins...
I'd like to do a full review when the spring comes around.
The Following User Says Thank You to dem00n For This Useful Post:
soulreapersteve (01-04-2017)
Old 01-04-2017, 12:22 PM   #16
norcalpb
norcalpb's Avatar
Check to see if that grade 8 longboard bolt they include isn't grinding on the inner fender well (top bolt).
Originally Posted by Caspian View Post
Hi Superhatch,
I had B8s on order, then read your review and picked up the Perrin front endlinks and Whiteline Roll Correction.
I had them installed for me. I'm getting a rubbery creaking noise now when turning the wheel and the same sort of noise when the suspension is compressed.
Did you experience the same? Do you have any ideas on how to minimize the noise? I've had the installer look at it and he thought everything was fine. One mechanic said he thought that was just the sound the polyurethane bushings made.
The handling and ride are excellent. It is just the noise I'm concerned with and making sure there aren't any adjustments needed.
Thanks for any thoughts.
Lee
WTB: Koni yellow struts and RCE yellow springs nlowell Brakes, Suspension, Chassis 2 05-20-2014 04:10 PM
WTB: Used Bilstein B14 or B16 InvalidJohnny5 Brakes, Suspension, Chassis 0 03-11-2014 11:40 AM
Bilstein I-RC C3 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 12-16-2013 12:45 PM
FS: RCE Yellow, Koni struts and pre cut housing for Koni's. Dinko Brakes, Suspension, Chassis 21 12-16-2013 11:32 AM
-Sold- FS: ASSEMBLED Koni Yellow + RCE Yellow combo; lightly used! OrbitalEllipses Mid-Atlantic 21 06-14-2013 01:10 PM
