Old 12-23-2014, 06:41 PM   #15
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by FR-S89 View Post
What would you recommend personally?
With the KW V1s/V3s i would have to buy top hats too, from my understanding
I just want no headaches, fit these wheels on my car and have em look good without a harsh ride... obviously will need an alignment but i think I can install myself
You can use your stock top hats with KW's and many other coilovers.
The Following User Says Thank You to Calum For This Useful Post:
Racecomp Engineering (12-24-2014)
Old 12-24-2014, 11:29 AM   #16
Firestorm_86
Drives: FRS
RS*R i-Sport. Pretty much plug and play if you're a coilover newbie, and the ride is more forgiving relative to the many performance oriented setups here.
But, it depends on your application. Will you see the track much?
Firestorm_86 is offline   Reply With Quote
Old 12-24-2014, 01:13 PM   #17
ahmed85
Drives:
Why no one recommend Tein Street flex coilovers, I believe they are the best option.
ahmed85 is offline   Reply With Quote
Old 12-24-2014, 04:24 PM   #18
kyoshi11
kyoshi11's Avatar
Get some swift spec R springs. They lowered me to about 2 fingers
kyoshi11 is offline   Reply With Quote
Old 12-24-2014, 04:27 PM   #19
kyoshi11
kyoshi11's Avatar
Old 12-25-2014, 04:25 PM   #20
FR-S89
Thanks for all the replies! this community is amazing
I'm considering KW v1 and Tein Street
The KW v3 are too advanced for me and I don't think I will utilize all the adjust ability features.
ST would be great (same as KW v1 but made out of different material) unfortunately i'm in Canada and the roads are salted here
I won't be tracking the car.. I might go to the track once this season but only for some fun legal cruising, not to set any killer lap times.
Will the KW v1 still allow me to adjust camber? Will I need LCAs?
Also has anyone with either of the aforementioned coilovers run 9.5 wheels squared?
FR-S89 is offline   Reply With Quote
Old 12-25-2014, 04:53 PM   #21
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
I appreciate both of these point but my view is that while a person might not drive fast on the road your suspension is working all of the time regardless of what speed you are doing. My 2 cents says that you should install the best suspension you can afford.
Ultramaroon (12-25-2014)
Old 12-27-2014, 06:50 PM   #22
With all KW and RCE coilovers the front lower mount is slotted so you can get a good amount of camber without plates.
With all coilovers, you'll need rear lower control arms to adjust camber.
- Andy
Squeaking / Creaking rear suspension with low ride height? Suspension pros welcome! mothespaceman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 08-14-2015 05:06 PM
Reccomendations for clutch set-up. ohnoitsthefuzz Engine, Exhaust, Transmission 21 11-14-2014 02:09 PM
Reccomendations for Led lights.. _F-R-S_ Mid-Atlantic 22 02-08-2013 08:10 PM
Reccomendations for Clear Bra installers in Balt/DC/Annapolis area? Grimlock Mid-Atlantic 31 08-28-2012 01:47 PM
Dealership reccomendations wanted - Victoria - Eastern suburbs llama_au AUSTRALIA 21 08-18-2012 08:19 AM
