Old 12-30-2014, 02:36 PM   #15
whataboutbob
AutoX-10/10ths every run
Can't wait to get my hands on one of these and put it in.
Build thread:Here
Old 12-30-2014, 03:03 PM   #16
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Originally Posted by Calum View Post
I think you miss understood. I have zero access to E85 and therefore have no desire to buy a flex fuel kit. I want to know if the app is already installed in the stereo that's sitting in my basement waiting for my car to come out of storage? Also, do I need a flex fuel kit to take advantage of the features of the app or will the stereo connect to the canbus without the flex fuel kit?
Ahh, yes I did miss understand.
You head unit does not have the app installed. The app will be available through the Google Play Store when it is released and can be downloaded from there. You head unit will allow for this and we will make sure it works properly on the head unit as we have them in our vehicles also.
You will need the "PowerPlug" module (what we call it, without the FlexFuel aspect) to control other aspects of the vehicle if you like via BlueTooth. This will be priced around $425 as a full plug in solution without the FlexFuel aspects. You will also need our tune to make it work as expected but should allow for a little more control on your end through our application.
Cheers,
William Knose
Old 12-30-2014, 03:16 PM   #17
DeliciousTuning
Originally Posted by megamarines View Post
Question: Within the month I'm dropping the Jackson Supercharger in with the CARB Legal tune it comes with. Will this FlexFuel system addition work in tandem with it or will it error out? In addition, if I were to take said car to SMOG test with nothing but 91 Octane in it, will it fail or would the FlexFuel system go unnoticed in it? How about with E85?
Our FlexFuel kit will not work as a FlexFuel Kit on the Jackson Racing Supercharger CARB tune. It will plug into the vehicle and operate but really give you no feedback into the ECU for proper FlexFuel control.
In this configuration (Jackson Racing CARB tune and our FlexFuel Kit) it will also throw a CEL for the rear O2 sensor, which would cause a fail. You can very easily disconnect it from the rear O2 sensor and the vehicle will run properly.
In order for the Delicious Tuning FlexFuel BT Kit everything to work correctly you would need to purchase the following.
Delicious Tuning Flash & Go Tune
Delicious Tuning 11 PSI Map Sensor
You can always switch back to the CARB tune whenever you choose, by following these steps.
Make sure you are 91 octane (or very close)
Install stock OEM 5 PSI Map Sensor (5 mins)
Disconnect Rear O2 Sensor FlexFuel Input (1 min)
Reflash Jackson Racing Tune (5 mins)
Cheers,
William Knose
Old 12-30-2014, 03:17 PM   #18
DeliciousTuning
Very soon sir. Very soon.
Old 01-02-2015, 02:21 PM   #19
M23
Drives: 86
More vids!
..especially NA tunes vids
M23 is offline   Reply With Quote
Old 01-05-2015, 12:20 PM   #20
PolishFrs13
building life
PolishFrs13's Avatar
Drives: Raven Black, 6MT
Anyone know when bills vacation is over ?
Sent from somewhere
PolishFrs13 is offline   Reply With Quote
Old 01-05-2015, 04:48 PM   #21
Calum
That Guy
Drives: 2013 asphalt FRS MT
Sent from somewhere
IIRC Zach said they would be back today.
Old 01-05-2015, 04:54 PM   #22
PolishFrs13
building life
hm hopefully. I want my tune already
Sent from somewhere
Old 01-05-2015, 05:59 PM   #23
aaguirre123
Drives: sti 2012 sedan
What are the differences between this kit which uses the the o2 sensor and the old kit which taps the evap line? Is it better to use the o2 line?
aaguirre123 is offline   Reply With Quote
Old 01-06-2015, 10:57 AM   #24
lucid215
from the way i understand it is the difference is that the old kit you had to wire up a gauge display to show your e content where as the new kit you can use your phone instead of having to install a gauge. but i could be wrong
lucid215 is offline   Reply With Quote
Old 01-07-2015, 01:24 PM   #25
DeliciousTuning
Sent from somewhere
We are back and sending out tunes today that were ordered on January 2nd or later. Just trying to catch up on 300+ emails from the holidays and lots of voicemails.
If you ordered before this your tune has already been sent. If you have not received it, please check your spam folder and if not in their please email us.
Cheers,
William Knose
Old 01-07-2015, 01:28 PM   #26
DeliciousTuning
This makes it a LOT simpler to install. Now the entire process takes about 20-30 minutes max.
The older kits would require running wires through the firewall and through the passenger compartment to the ECU. Then you would need to either splice into the ECU harness OR purchase and additional adapter harness for $100 which makes those kits even more expensive.
We just wanted to make it a lot easier to install and remove when the time came.
Lastly you can view your ethanol content with your phone, with the free app we offer with the kit. App coming out soon.
Cheers,
William Knose
Old 01-21-2015, 06:52 AM   #27
brianhj
Drives: 2017 Camaro 1SS
Any update on when these will ship?
brianhj is offline   Reply With Quote
Old 01-21-2015, 11:03 AM   #28
DeliciousTuning
Still scheduled to ship out late next week as our brackets come in!
Sincerely,
Zach
Delicious Tuning - Q&A EcuTeK ProECU Tuning and Maps DeliciousTuning Software Tuning 1213 06-17-2025 04:02 PM
200+ WHP Completely Stock Vehicle, E85 and EcuTeK ProECU RaceROM Only (VIDEO) DeliciousTuning Software Tuning 156 07-01-2014 08:37 PM
Delicious Tuning - 200+ whp E85, Stock Headers, EcuTeK ProECU DeliciousTuning Software Tuning 19 12-07-2013 12:01 PM
Delicious Tuning: EcuTeK Stage 1 or 2 on 91, 93 or E85 fuels DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-19-2013 05:58 PM
Delicious Tuning: FlexFuel Innovate Supercharger EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-13-2013 01:34 AM
