Old 11-25-2014, 02:07 PM   #15
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
The thermal efficency of an engine is pretty static when its built, thus it can be as efficient as it can given the ideal conditions (right AFR producing the hp they want), the milage will be dictated by the amount of fuel flowing into the engine which is controlled by your foot. Youll have an easier time regulating gas milage with your foot, than remapping and retarding the engine.
Old 11-25-2014, 02:43 PM   #16
Koa
Completely unrelated threadjack, but every time I see your avatar I >HAVE< to say it out loud in Bane's voice.
The Following User Says Thank You to Koa For This Useful Post:
cdrazic93 (11-26-2014)
Old 11-25-2014, 09:01 PM   #17
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
You can get a 10-20% improvement altering the factory ECU. With direct injection, you can run some absurdly lean mixtures like the lean burn motors from the 80's did (think 16+ AFRs).
But they definitely would be less than ideal for emissions, so you won't find it from an OEM. Probably not the best for the catalytic converter either.
But yes, it can be done. We toyed with it for quite some time and found about a 15% improvement on pump and e85. While legalities prevent us from offering this, if you're using a DIY platform, you should be able to extract several more MPG with the right approach.
Xero-Limit is offline   Reply With Quote
The Following 3 Users Say Thank You to Xero-Limit For This Useful Post:
BuBlake (11-27-2014), Dadhawk (11-25-2014), serialk11r (05-24-2015)
Old 11-27-2014, 04:09 PM   #18
KoolBRZ
KoolBRZ's Avatar
Originally Posted by ganz954 View Post
My goal is to create a rom that will give 10%-15% mileage increase.
Im not looking for performance here I just want to see if it is possible to achieve that. Dont care if the car is slow as a Prius.
Anyone have a clue how to achieve better gas mileage?
What tables should I start looking into?
By experimenting through trial and error, I've found some differences between stage 2 OFT tunes. My A/R header is only slightly unequal in length, see pic, and so I've tried tunes for both EL, and UEL headers. There are significant differences between UEL and EL header tunes. I'll show you 2 of them, see pics below. My average MPG with the version 2.062 stage 2 91 Octane EL OFT tune was only 28, yet my average for the version 2.062 stage 2 91 Octane UEL OFT tune is 30, and the pics show the reason why. the exhaust isn't opened as far, or as early with the UEL tune versus the EL tune. I've found that the EL tune is quick, but wasteful, while the UEL tune is slower, but more torquey in the low revs, and more fuel-efficient. I think the VVT, (AVCS), is where to start experimenting for better mileage, also delay the ramp up in the drive-by-wire tables to keep your foot from wasting as much fuel. I removed the proprietary pictures of the VVT tables, but you can check them yourself by opening them in RomRaider.
Last edited by KoolBRZ; 11-27-2014 at 04:15 PM. Reason: removing proprietary pictures
Old 12-01-2014, 03:16 AM   #19
Kodename47
Kodename47's Avatar
Drives: UK GT86
http://www.romraider.com/forum/viewt...p?f=15&t=11266
.: Stealth 86 :.
Kodename 47 DJ:
Old 12-02-2014, 10:08 AM   #20
ganz954
ganz954's Avatar
Drives: Subaru BRZ MT WR Blue
thanks everyone for the comments Ill definitely look into them.
ganz954 is offline   Reply With Quote
Does Turbo effect gas milage?? beesmiff07 Forced Induction 86 10-30-2014 10:25 PM
WTB: FRS/BRZ high milage cools20 Cars for Sale/Trade 0 10-13-2014 01:10 AM
Circuit Motorsports Tuning - EcuTek/RaceRom - New and Improved! Circuit Motorsports Software Tuning 7 05-20-2014 02:26 PM
At what milage did your OEM tires start to lose grip? Liquidsnake Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 01-18-2013 05:38 PM
Milage App. execoll Scion FR-S / Toyota 86 GT86 General Forum 11 09-14-2012 12:23 PM
