Old 11-25-2014, 05:47 PM   #15
Churg
Churg's Avatar
Drives: 2014 WRB BRZ
Originally Posted by whataboutbob View Post
I'm running mine as they came right now, let me look into it and I'll get back to you.
Thanks! I've been looking for a good Monotube coilover that isn't over $3k, and this seems like the one. Not too worried about the alternate top hat/camber plate compatibility, but I definitely want to run stiffer spring rates than what is offered out of the box. Still been digging them so far?
Churg is offline   Reply With Quote
Old 11-25-2014, 05:52 PM   #16
Churg
Churg's Avatar
Originally Posted by Moto-P View Post
Bob, Churg, I just got invited to this conversation. As for the RSR Sports-i/Black-i coil-over system, as long as the coil ID/OD and lengths are the same as the supplied TI2000 Series RSR coils, they will function and mount fine. RSR does have different rate springs which can be purchased from them as well.
Upper and lower brackets and mounts too, can be made to fit things made by RSR as well.
However, all of that, basically modifications from what is sold, is at your own risk, as RSR will not warranty, advise, or help with any R&D using a 3rd party parts on the system for obvious reasons.
Ah, perfect! I'll be aiming at getting the "CR" version of the Sports-i coilovers, I just wanted to make sure that I could run slightly stiffer rates. Since my car is my DD as well, I don't see myself running more than -3.5 degrees of camber, but I definitely wanted to run in the 550-600lbs range, as far as spring rates go.
Old 11-25-2014, 06:01 PM   #17
whataboutbob
AutoX-10/10ths every run
Yep, they are still working great. I'm still tinkering with the settings to get them just right.
Build thread:Here
The Following User Says Thank You to whataboutbob For This Useful Post:
Churg (11-25-2014)
Old 11-25-2014, 08:29 PM   #18
Originally Posted by Churg View Post
@whataboutbob, would you happen to know if they support the normal spring offerings from Swift for the option of having stiffer spring rates than what they offer? And if they will work with the normal top hat/camber plate offerings from Vorshlag, Raceseng, etc.? I've reached out to them via email, but haven't gotten any response.
If you decide to get aftermarket components instead of RS*R components, we can get you the Swift springs if you specify ID, length, and rate.
We can also have RaceSeng make a compatible spring perch and bushing if you want to use their equipment. I can get the appropriate measurements from RS*R or @whataboutbob
-Mike
P.S. we can also get you the RS*R components as well.
Churg (11-25-2014), whataboutbob (11-25-2014)
Old 11-26-2014, 08:46 AM   #19
BatStig
Some say.....
BatStig's Avatar
Drives: 2007 Subaru Impreza 2.5i
@Moto-P What led you guys to go with square rates on the Club Racers, versus the staggered rates on the "Moto-Spec"?
BatStig is offline   Reply With Quote
Old 01-30-2015, 11:05 AM   #20
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
Can RS*R coilovers be rebuilt in the US or do they have to be shipped back to Japan?
***Nevermind this question. I heard back from RS*R and they do ship back to Japan for rebuilds.***
smg1138 is offline   Reply With Quote
Thoughts on Raceland Coilovers? Brody602 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 12-31-2015 02:04 PM
DC Sports Header thoughts/feedback 1086 Engine, Exhaust, Transmission 25 10-24-2015 01:52 AM
RS-R* Sports i Coilovers installed!!! eddieEndo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 12-10-2014 12:25 AM
megan racing coilovers thoughts? Ludacrits Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 03-10-2014 01:12 PM
Your thoughts on Paddle Shifter sports cars? SevenTenSplit Other Vehicles & General Automotive Discussions 69 12-23-2011 05:12 PM
